Disabling DC/DC Converter Fuse Removal
Discussion in 'Gen 2 Prius Technical Discussion' started by Calle, Dec 10, 2011.
  1. Calle
    Calle New Member
    50
    NY
    Does anyone know how to disable the 12v DC-DC converter or what fuses I can remove besides the fusible link in the fuse box? I cant even find a writeup on how to remove that fuse...Any help would be appreciated
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    38
    Santa Fe, NM
    These are things not normally done. What are you trying to accomplish?
  3. Calle
    Calle New Member
    50
    NY
    I am converting the 12v system into a plugin system. In other words Im going to power the 12v system via an independent power supply. I need to know how to either disable the converter, or remove the fuse box to get at that 100a fusible link
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    To what end? Hopefully this isn't a bizarre attempt to improve mileage.
    Tom
  5. Calle
    Calle New Member
    50
    NY
    It certainly is. The 12v system utilizes between 300 and 600wh constantly. Effectively by powering this load via an independent power source would have the same effect as having a constant 300 to 600w going back into the HV battery. My estimates are between 10 and 20% fuel mileage increase. The system will contain 2 105AH 12v batteries wired to 24v, hooked up to a DC/DC converter that outputs 100 amps max at a voltage of my choosing which is adjustable. The converter is comprised of an LM317 voltage regulator using 15 outboard power transistors. This should allow for about 3-5 hours of runtime between charges.
    The reason I need to disconnect the Prius converter is so that I can run a test to verify my claims before actually implementing the system.
  6. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi Calle, it sounds like an interesting project. A 10% to 20% increase in fuel mileage would be a great result, but I suspect that might be a bit optimistic and the added weight could negate much of your gains.
    Each 105 AH deep cycle lead acid battery would typically weigh about 30 kg, so it looks like you'll be adding add least 60 kg. That about 4% of the cars weight.
    In any case I'd be interested to know how it turns out. :)
  7. richard schumacher
    7,666
    1,047
    United States
    Swag the Prius' average power output as 50 HP = 37000 W; 600/37300 = 1.6%, not "10% - 20%". Allowing for conversion efficiencies the added batteries might could increase MPGs as much as 3%, if they were weightless, but as uart suggests their weight will probably cause a net drop in MPGs.
  8. qbee42
    18,058
    3,079
    Northern Michigan
    The OP's calculations are off. The 12V system doesn't come anywhere close to consuming that percentage of total Prius power. Just guessing from a back of the envelope calculation, but I suspect this modification is going to cost mileage, not improve it.
    Tom
  9. seilerts
    3,326
    1,519
    38
    Santa Fe, NM
    300W sounds about right in the steady state, given the HV battery quiescent current of 1.x amps at 2xxV. Not all of that is DC converter. 210 amp-hours of deep cycle lead acid and your downconverter will add, what 150 lbs?
    Before doing anything, stick a clamp ammeter over the DC converter line and see what the current is after the car has been in Ready for 10 minutes.
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    My "back of the envelope" calculations give much the same result as yours Tom. A lot depends upon what speed you're traveling, the energy savings are more significant at low speed pulse and glide, but I'm figuring about 3% gain due supplied power and about 3% loss due to the increased weight.
    Additionally the energy to charge the 12V batteries is not generally free, and the charge/discharge cycle efficiency of lead acid not that great. For a typical battery charger I'm figuring about 0.8 KW hr at the wall (power outlet) for each hour of driving. Costing this at the average US rate and converting this cost into gasoline I get an effective cost of about 1.8 to 2 miles range. This corresponds to perhaps a further 3% loss.
    So, even if you ignore the upfront costs of the conversion, I'm estimating about +3% -3% -3%, so about a 3% negative impact on the overall economy. Maybe if your drive is mostly low speed pulse and glide you'd do somewhat better, break even or come out slightly ahead.
  11. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    I do not see the point of charging one 12V 35AH battery with two 12V 105AH batteries connected in series to give 24V then regulating this back to 12V. Why not put them in parallel and save the weight and losses of the regulator. If my calculations are correct 2x105+35 divided by 4hours gives a 12V load of a constant 60amps witch is wildly over estimated. I have not checked the average 12V load on the Prius but would be surprised if it was over 20a and in the configuration above would give 12hours of operation.
  12. thatguy
    thatguy New Member
    Virginia
    My 2005 Prius draws about 240W from the HV battery in READY mode with all accessories off. While stopped in drive with the brakes, HID lights, radio, and the cabin fan on low it draws about 400W. When gliding below 41 mph and not commanding any power into or out of MG1 or MG2 I often see currents out of the battery near 800W.
    I'm not sure where that power is going, or even if those values are right, but given that the 12V system powers many critical parts of the car I suggest being careful about severing the HV-12V link. The car is known to do weird things when the 12V line sags, and there are several large and bursty power draws that can come on suddenly.
    List of major subsytems that use the 12V:
    http://priuschat.com/forums/gen-iii...at-does-really-feed-directly.html#post1342183
    Analyzing off-grid solar-battery systems a few years ago I was surprised to discover how expensive batteries really are. When I calculated in the wear-and-tear of use I found that most deep-cycle lead-acid batteries cost about $0.40 per kWh of throughput over their lifetime. This means that if you can get grid power at $0.15 / kWh and you store it in lead-acid batteries it already costs $0.55 / kWh. You may want to consider this revised cost in your estimate. At the moment each gallon of gas costs me about $3.20 and yields 11.6-12.2 kWh. Thus each kWh costs about $0.26-0.28. This makes gasoline more expensive than grid power but cheaper than grid power stored in lead-acid batteries. Note that this only applies to lead-acids, other types of batteries have very different characteristics
    The Gen II Prius burns about 230 grams of gasoline per kWh in its most efficient range of operation. Assuming we are operating in a less efficient regime lets say that we are burning 240 g/kWh. A US gallon of 87 octane gasoline is about 3785mL * 0.739 g/mL = ~2800g so our Prius will extract about 2800 / 240 = 11.6 kWh per gallon. At 50 MPG that works out to 11.6 / 50 = 232 Whr/mile. With the Torque app on my phone altering my driving habits I have been able to get about 57 MPG sustained over multiple tanks. Assuming I manage 230 g/kWh this works out to 214 Whr/mile.
    If you are driving at 60 mph it takes you 1 minute to drive a mile. In that minute the electronics have used somewhere between 240 and 800W thus 240 / 60 to 800 / 60 = 4 to 13 W*hr/mile. The 12V electrical load is 4 / 230 to 13 / 230 = 1.7% to 5.6% of the power used by the car. If you replaced that power without adding any weight the largest improvement you could expect at 60 mph is somewhere between 2 and 5%, or 1-2.5 mpg. If you spend a lot of time in stop-and-go traffic that depletes your HV pack and makes your engine run inefficiently this mod could make a bigger difference but I don't know how to quantify that.
    If the majority of your time is spent at speed altering driving habits, training yourself to use Torque, getting an engine block heater, or getting LRR tires hold more promise than supplying the 12V system with grid power stored in lead-acid.
    2 people like this.
  13. Patrick Wong
    18,210
    6,513
    You would have to remove the clear plastic cover over the fusible link box, then physically break the 100A DC/DC fusible link.
    After you decide that breaking that fusible link was a bad idea, then you would have to remove the main relay/fuse box so that you will have access to replace the fusible link assembly. Other posters have written in detail about how to do this.
    Usually the DC/DC fusible link is broken as the result of a botched jump start. You are the first poster that I have seen who wants to proactively do this to a car that is working fine.
  14. Britprius
    5,194
    1,922
    Thatguy When the Prius is stopped in drive if you look at the MFD you will find that it is putting power out to the wheels, witch are not driven by the 12v supply. The HID's use 70watts plus about 30watts for the front and rear side lights, or 8amps the fan and radio another 5amps. The extra wattage when gliding cannot be being used by the 12v battery that has know other function than running the computers and other electric pumps on an intermittent basis hence my estimate of 20amps as an average load, but as Patrick stated the idea does not stand.
  15. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I agree, some things you can reduce 12v power consumption from like replacing lamps for LEDs as I have and fitting a little trickle charger for the 12v battery while I am charging the plugin kit, I am sure this helped FE but remember one of the highest current consuming items on the list is the brake fluid compressor, not something you might want to save power from. Just a thought would the system give a fault code if the fuse was pulled?
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    To put it simply without breaking out the calculator your project is flawed by
    one major Prius peculiarity. And that's sooner or later at the end of the Inverter substitute battery charge that 12 volt line will sag due to various super current draws it see's.
    The Prius hates that B+ sag and see its as a major issue and throws every CEL it has including breaking & drive ability issues. Your super reliable car becomes instantly very testy. One of those events on a very busy highway at speed and that extra mileage will quickly become not worth it not to mention scare the crap out of you.
    Nice try though. Maybe a bank of car stereo supercaps to switch in if it bottoms out but if it see's that sag all bets are off.
  17. qbee42
    18,058
    3,079
    Northern Michigan
    If you see this, it means you are not pressing firmly on the brake. Press firmly and the Prius will stop simulating automatic transmission creep. The MFD will then indicate zero power to the wheels.
    Tom
  18. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Someone in another forum did this kind of "mild plug-in" with a 14V deep cycle battery and claimed good results. YMMV of course.
  19. Britprius
    5,194
    1,922
    Another way might be to spoof the sense wire voltage to say 14.2V that might shut down the 12V inverter and let the 12v systems run on the batteries.
  20. Calle
    Calle New Member
    50
    NY
    I appreciate everyones input, but I am surprised to see that no one calculated a noticeable gain. I know personally of another Prius owner who successfully did this sort of conversion and experienced a 7% increase in highway driving replacing only part of the draw. I have already conducted several load tests, and these are the following draws that are present on the 12V system and ultimately on the traction battery. These numbers are not even taking into account the conversion loss (converting 220VDC into 12VDC) which is over 20% in the Prius due to an inefficient inverter.
    Loads in Amps @ 12V Nominal
    Base Draw - 15A (180w)
    This is a constant draw whether in park or in drive, motion or stopped. This load is made up of all of the sensors, computers, and other electronics in the car such as the MFD.
    Headlights w/Parking Lights - 9A (108w)
    The constant draw of the headlights and parking lamps is 9A, however, each time they are turned on, there is a draw of about 20A that lasts for about a minute. The control ballasts are not 100% efficient, and the parking lights make up the rest of this load.
    Heater/A/C Blower motor - 2A to 12A (24w to 144w)
    Temperature and/or A/C button status has no effect on this draw. Basically, you are drawing 2 amps from the lowest setting, and about 1 amp additional for each higher setting.
    Front Wipers - 13A instantaneous, 3A avg on "Low", 12A avg on "High"
    Each time the wipers travel across the windshield, there is a current draw of upwards of 13 amps. On the lowest setting, this is equal to a constant 3A draw and on the highest setting this is a 12 amp draw.
    Rear Defrost - 13A continuous
    The rear defroster uses 13 amps steady while on.
    Fog Lights - 10A
    If you have fogs, they use about 10amps.
    Stereo - 2A to 10A continuous
    If the stereo is on, but on a low volume setting, it will draw about 2amps. At the highest volume setting with lots of bass, you are looking at a continuous draw of about 10 amps. Even though my stereo is technically 180watts, it will never draw that. That is under a peak condition. At a volume level of MAX, I was not able to draw more than 10 amps max spike.
    Brakes - 0 - 30A, 1A continuous
    The brake accumulator does not draw any power unless brakes are applied, and during this instance, you can draw up to 30 amps. I average this out to a 1A continuous draw.
    Obviously, this conversion will have the LEAST affect during daytime highway in mild climates. This is because you are not using the brake accumulator, headlights, heater/AC, defroster, etc.
    Now, I live in New York and have a mix of highway and local driving often in the cold and dark. So lets say I am driving home from work on a cold rainy night, this is my power draw:
    Base Load - 15A
    Wipers - 5A
    Heater - 3A
    Headlights - 9A
    Stereo on Low - 2A
    TOTAL: ~34A @ 13.9V = 472 watts
    In order for the Prius DC-DC Converter to supply 472 watts, it has to draw about 600 watts constantly out of the traction battery. This is approximately 2.7 amps at 220V nominal.
    To give you an idea of how much power this is, the load I just detailed would drain the ENTIRE traction battery in about one hour. (1.3kw battery can provide 650watts for one hour, not 1.3kw)
    Yes, the batteries will weigh about 75 lbs, but that is NOT NEARLY equivalent to a 600whr load. In any case, for this, I have removed the spare tire, jack, and large black bin from the trunk easily countering this weight gain. The converter I've built only weighs about 5 lbs.
    So given that, the question remains, what would be the resultant MPG increase if the Prius traction battery were to have an additional 600whr available to it?
    600whr is almost HALF of the traction battery capacity.
    Its draw results in the loss of 1% SOC every 2 minutes-in other words, every 10 minutes, your SOC drops 5% and the ICE has to regenerate this loss ultimately. Think about when you are waiting in the drive thru, or at a light, your SOC drops, and the ICE has to recharge it.
    Without writing out the long drawn out math to calculate this, a CONSERVATIVE estimate is 10% based on the condition I presented above and the results of a previous test.
    Someone had gone into the cost of the KWH's by having to recharge the system at home. Let me make this clear upfront-the purpose of this project is not as a long term solution or a money saving idea. It is simply to find out what the resulting MPG increase would be by not having the Prius 12V draw. Yes, obviously if the system gets me 5MPG extra, it has to be countered with the cost of the batteries every 2 years along with how much it costs me to charge the batteries from my wall. The question I am trying to answer is simply what would my MPG increase be?
    To begin my project, I am going to disable the Prius converter this weekend and power the car from nothing but batteries and then do the same test WITH the converter. I will test different loads at different speeds and different driving types.
    someone had mentioned the sense lead. You are incorrect. The only thing the sense lead does is monitor the voltage drop between the battery and the converter. Based on this drop, the computer will either tell the converter to supply 14V or 13.3V if the battery is charged. The converter in no way supplies a dedicated current to the battery. The battery draws what it needs. The sense lead can easily be fooled, and would not throw any codes as long as it senses voltage.
    2 people like this.
