Disabling reverse beep/seatbelt beep on an 06'
Discussion in 'Gen 2 Prius Main Forum' started by Paradox, Jan 6, 2006.
  1. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I read somewhere on PC how to disable the annoying reverse beep and seatbelt beep but I guess it was for the 04/05 model. I tried the procedure on my 06' and didn't have any success. I may have very well done it wrong so if it is the same procedure please describe in detail what has to be done and if there is a new procedure for the 06' anyone have a good tech who told them how to do it yet? And if so please share it with us! :)
    Also, on a side note, anyone know if coastaletechs's EV mod works on an 06' yet?
  2. Kestrel
    Kestrel Bird geek
    59
    SF Bay Area, CA
  3. priusblue
    priusblue New Member
    152
    I disabled the reverse beep on my '06 the day I got it. The procedure I got from http://john1701a.com/ (the user guide partway down the home page for HSD) worked great. I'm not sure if this is the same procedure listed on this site, but probably so. It helps to have 2 people, I think. The seat belt thing doesn't bother me since I usually buckle up before I start the car, so I haven't yet disabled that.
  4. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    16
    Racine, Wisconsin
    Just as a safety reminder.....
    The reason the beep exists "inside" the cabin is to let you know that you are, in fact, in reverse gear. This may be odd at first blush but if you accidently hit the rear gear you would normally have no idea you would be in rear gear. Say a piece of clothing got ahold of the shifter and you didn't notice. The beeping would alert you to it. I personally have made the decision to leave the beeping on for that very reason. Your mileage may vary. :)
  5. 8AA
    8AA Active Member
    550
    62
    Maryland
    If you have someone help by reading the instructions, make sure that they aren't sitting in the passenger seat. Someone will probably correct me if I'm wrong, but I believe that previous posts said that having a passenger in the seat kept the "dance" from working.
    Regarding the seat belt beep, you have to do the "dance" twice, once for the driver, and then a second time for the passenger. It is also possible that the beeps will still occur, but only four or five beeps instead of continuously.
  6. priusblue
    152
    My husband was in the driver's seat and I was in the passenger seat when we disabled our reverse beep, and it worked fine. Not sure about the seatbelt thing, though.
  7. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    that's for sure. The Prius is so quiet that it's difficult to get used to. You have to be a little more alert than someone in a gas-only vehicle. I just wish that they'd give you some settings to play with so that you could make the reverse beep less annoying.
  8. Astrotoy7
    Astrotoy7 New Member
    108
    Melbourne, Australia
    This is one tiny gripe I had with my beloved 2004.... the Prii released here in Oz cant have the beeps turned off...
    I am getting used to it though, so no biggie :)
  9. frankie_delaware
    frankie_delaware Junior Member
    51
    Southern California
    I've been concerned about this, too, so I haven't decided if I want to disable the beep or not. I'm thinking the backup camera screen is a good alternatative indication (if you have that option).
    I've never felt I needed a reverse beep in my other cars, the main difference I see is that the shifter position doesn't indicate that I'm in reverse.
    The beep sure is annoying, though.
    fd
  10. jacaufie
    jacaufie New Member
    104
    Hillsboro, Oregon
    I was able to stop the reverse beep following the instructions mentioned earlier in this thread.
    The seatbelt beep, on the other hand, persists. I've toggled it to 'b-OFF' and it still beeps 4-5 times. As someone mentioned, I think this is an improvement over continuous beeping but still annoying. What is the car, my mother? I *always* wear my seatbelts and feel naked if I don't. :)
    I will look for that electrical connector in the back of the seat to see if I can *really* disable it.
  11. Tideland Prius
    16,151
    I still can't disable the driver's seatbelt beep and enable the passenger seatbelt beep
  12. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Thanks for the replies everyone. I'm going to give it a go later on again and see if I can get it to work...
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i think your concerns illustrate a highly unlikely scenario. to shift to a moving gear when not moving, your foot must be on the brake, otherwise it simply goes to neutral. accidently shifting to reverse is very unlikely
  14. geologyrox
    geologyrox New Member
    513
    Is there a way to make the rear beeps stop after 4-5 beeps as well? I don't mind the 'reminder' for just a moment, but I feel like an idiot in this tiny car backing out of a space with that loud beep going. I don't care too much about the seatbelt, since I wear one anyway, but it does grate on me that Toyota doesn't have this on a quick 'turn it on or off' settings panel.
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    that would be a cool option...i have not heard of that to be honest with ya. i guess if the beep wasnt so loud (frequency is also very irritating to me) i might consider living with it.
    the seatbelts still do a single beep. would be nice if backup was a three beeper or something
  16. Tideland Prius
    16,151
    Mine's the reverse. I wanted to reverse so I popped the shifter in reverse. I must've moved it too fast and it didn't register. When I let go of the brake pedal, the car moved forward. I almost hit some people walking in front of my car!
  17. OUscarb
    OUscarb Member
    167
    Sooner Land, Oklahoma
    The best way to disable the seatbelt beeps on an '06 is to use'em. Get in fasten up and walla "No Beeps"! Safer too I hear. ;)
  18. jacaufie
    jacaufie New Member
    104
    Hillsboro, Oregon
    I would never argue against using seat belts. I always use them. But I also don't need a reminder to do so.
    The point here is that I really don't need the car to beep at me as I'm reaching for the belt and pulling it across my chest to buckle it. This is annoying and unnecesary. And even 5 beeps is too much. You should be able to turn this off.
  19. duanerw
    duanerw senior member
    140
    lexington ky
    2013 Prius v wagon
    I disabled the backup beep on my 05 and unable to do it with the 06.I checked with
    the service mgr and he said if i disable it i will void the warranty.I have seen that
    posted here a few months ago and didnt believe it. now i do and will let well enough
    alone. you can do as you please but check it out first............
  20. QED
    QED New Member
    267
    Sunny Hawaii
    My salesman told me about turning off the reverse beep when I picked up my '06! <_<
    It's not clear why they enabled the option if it voids the warranty.
