Disappearing P3009
Discussion in 'Generation 1 Prius Discussion' started by Josey, Sep 10, 2020.
  1. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    Yeah, my 2003 threw a P3009 twice last week, and now won't do it again... I'm just thinking that if that's the case maybe I have an "early stage" issue that if I can find now might head off a worse issue later? IDK.
    Right, so it's HV voltage leak which could be anywhere in the system, and if I owned a megger (which I don't) would be way easier to get a handle on. (I have feelers out for borrowing a megger).
    Trying to keep this short:
    - the car is not being driven much these days. I went to starting it up to run just for the sake of keeping the batteries "exercised" and charged. The first time it set was just KOER just sitting idling in the driveway, obviously in Park. Pulled and cleared codes. Next day took it for a drive (10 mins or so). No code set during the drive. Parked, put it in park. The code set again. (Sigh). Cleared codes.
    - That was over a week ago. Since then I have driven it a good 50 miles. No codes. More than once I've let it sit KOEO for 5 mins. No codes. I've let it idle more than once in Park KOER 5 mins, and no codes. Last one was KOER in neutral (annoying because it yells at you leaving it in neutral) for 5 mins and no codes.
    - The only thing I have not done is sit w it in reverse for a few minutes. However, A) it didn't set in reverse, only in Park, and B) it's always parked nose in and has to go in reverse first thing to drive it, so it's now been in reverse the last few drive cycles without coding out.
    Anyway, if any of that rings a bell with anyone, I'd appreciate hearing about it. I think the lack of problems in D, N or R leave the most likely thing in the HV battery. But I'm not pulling it out to hunt a ghost. It is a Dorman reman battery, unfortunately. It was replaced under warranty a year ago July. So it's been in the car (and fine) for about 14 mos. Of course, as a Dorman reman, that doesn't mean a whole lot...
    Other codes I got, but I doubt connect to a P3009:
    C1259 - HV regen problem which I understand as derivative of some other problem - ?
    C1521
    C1522 - both 1521 and 22 steering motor. IDK what that's about but I've got no triangle for PS system. I'll look at that at some point.
  2. ChapmanF
    15,407
    C1259 is just the brake ECU rogering some code reported by the HV ECU. That would have been your P3009.
    Sometimes there can be deteriorated insulation, or a track of gloop in the battery, that becomes detectably conductive when the humidity is higher, and not when it's a little drier.
    Josey likes this.
  3. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    Thanks v much. I'll keep track of the humidity too. (So many variables!)
    I'm sure this is out, but I've been wondering about my shifter, except that I don't understand how it works (and my internet searches have not helped me figure it out). It's got to be a part of the HV system in some way b/c the HV battery only gets charge in P D B - as I understand it. So in some respect it must be an HV switch of some kind. But in all of the P3009 threads / web pages I've reviewed it's never mentioned. I've just been led to wonder because mine is "sloppy" - just feels worn and "loose." Sometimes I'll start the car and just the jolt of the ICE starting will will actually click the shifter up a little - like it's being snapped into full P position or something because the sloppy lever didn't put the sloppy switch exactly where it needs to be. So it all just led me to think about whatever it is as an electrical switch rather than gear selector. Electricals are not my strong suit, but bad contacts are not exactly rocket science and do wreak havoc on electrical flows.
    In any case, as I said, I'd imagine that's not a thing. But it would just be nice for the computer to make up its mind as to whether I have an issue or not. I'll give it time...
  4. Trombone
    Trombone Member
    193
    67
    Allentown, Pennsylvania
    2002 Prius
    What's KOEO and KOER---radio stations west of the Mississippi?
  5. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    I'm actually east of the Mississippi :LOL:
    KO = Key On
    EO = Engine Off (not in "Ready" on a Prius)
    ER = Engine Running
  6. ChapmanF
    15,407
    The Gen 1 shifter is partly mechanical—only the part that 'parks' and 'unparks' the transmission. That's done with a mechanical cable that runs to the transmission and swings a lever that moves the parking pawl. Because of that mechanical cable connection, the motion of the tranny when the engine starts can indeed wiggle the shifter a little.
    Nothing else about it is much different from a game controller. It provides some ordinary, low-voltage, signal inputs to the Hybrid Vehicle ECU, telling it how you would like the car to act, and the hybrid vehicle ECU coordinates the engine and the inverter to make it act that way.
    For redundancy, the shifter connections to the ECU include not only a set of ON/OFF signals for the different shift positions, but also a single low-voltage analog signal that has to be in a certain voltage range for each position. The ECU isn't taking any orders unless both signals match.
    The New Car Features manual (more info) is kind of a must-read if how this car works interests you.
  7. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    Awesome. Thanks! I did actually buy a FSM, but went cheap, bought a PDF copy via ebay or something and later found out it's missing tons and tons of pages, including a lot of the diag stuff. But the NCF also sounds like something I want.
  8. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    Just an update that it's now been almost 6 mos and and IDK how many miles (couple thousand?) no further problems. I still have no explanation, but it's not humidity as the worst of it in VA comes in July & August. Mine does seem to have a small 12V parasitic draw, and my personal/historical experience with this car has been that 12V problems = warning lights. I have been making sure that the car does not sit and is driven every couple/few days.
    Just reminds me of when I brought up the issue of "phantom problems" associated with 12V issues in another thread which was met with some skepticism (Need info on replacing the 12 volt battery, 2003 | PriusChat). But when I referred to phantom problems this is what I meant. If there's an HV leak, then there's an HV leak. Period. It can't heal itself. (Unless it's Christine, but I don't drive it long distances in reverse as I don't like to run down the HV battery that much ;-). So, to me, these were phantom codes.
    I've owned the car for a little over 2 years and the only funky times have been when the 12V is run down.
    Of course, I'm putting a jinx on myself - the car will code out again tomorrow so I'm vigorously knocking on wood.
    Hanging on with 286k likes this.
  9. dbstoo
    dbstoo Senior Member
    1,320
    698
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I had a similar problem with my 2002 at somewhere around 160,000 miles. The trouble was intermittent.
    When I finally took it to the dealer they found two of the HV battery modules were leaking. The electrolyte was conductive, and shorting to the frame underneath the battery pack. I was told that it was intermittent because vibration disturbed the electrolyte enough that it would sometimes short and sometimes not. I opted for a replacement battery pack (installed) for $1800.
    Dan
    Josey likes this.
  10. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    I'm back just reporting that up until yesterday, I haven't had any further troubles.
    But yesterday it threw the triangle again for P3000/P3009. This time it was while driving - about 3 mi / 3 mins into a drive. I cleared it and then today it did it again just a little bit farther into the drive (more like 5 mi / 5 mins). Today was about a 26 mi round trip. The code tripped on the way. I read and cleared before the return leg, and then drove all the way back home without the code returning.
    The car does run normally through all of this. No noticeable differences whatsoever. Guess I'll just keep waiting to see what happens.
  11. ChapmanF
    15,407
    P3009 can be logged as soon as one conductive path has formed between body metal and somewhere in the high voltage system. This will give you the warning and the code, and means you should be extra careful with PPE if you open the battery or any of the high-voltage system for inspection. (Often, people are kind of cavalier about their gloves and such, trusting the various safeties designed into the system, but a known leak changes the odds on that.) Other than that, with only one such conductive path, nothing much else happens.
    In conditions where one conductive path can have formed, additional paths may be on the way to forming.
    By waiting long enough with one known conductive path, sometimes a person can see what happens when a second conductive path forms between body metal and somewhere else in the high voltage system.
    By following up on P3009 kind of diligently, a person can avoid seeing that.
  12. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    Thanks, but before I go on any hunts for conductive paths I think I'll wait to see whether the computer waits another year to randomly detect another HV leak problem. That is, unless there is some simple way to check things which, as far as I know there is not. As far as I know, if the code sets while in Park this points toward the battery. If not, then it could also be in the MG2 windings or even fluid. Or whatever else. Either way, the last time it randomly set and disappeared was almost a year ago. So for now, I'm waiting.
  13. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    LOL. The computer did literally wait another year (after the first year, so now its 2 years). And the same thing popped up. The car sat a little too long. Threw a P3009. Until I drove it long enough. And then it goes away. In between ... NOTHING! No triangles. It just runs and drives fine with no warning lights or error codes.
    But I'll just have to chase down the phantom now, I think. (Even though it's both real and unreal).
    I'm in Central VA where it's now very hot and humid. But there's no easy link to humidity. Currently humidity is high, but it's recently been higher than it is now and no triangles in the worse periods.
    I can't fuss with it right now b/c I'm on my way out of town. When I'm back I will follow along on the Art's Auto beginning diag procedure (2001-2003 Toyota Prius P3009) even though it's ambiguous about time in each stage.
    In the meantime I'm actually just in search of the nitty-gritty, highly technical info on how the computer monitors for HV leaks. In other words, we're talking about the computer measuring volts vs volts or ohms here or there or whatever. Does anyone know what the formula or algorithm or equation - or whatever - is for when and why the computer decides that some volts or ohms or whatever is out of spec?
  14. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    Probably more just by way of info, though observations/suggestions are welcome...
    I was out of town for about 10 days which is far longer than I ever leave it under normal circumstances. I took it out today on a "long enough" errand to give it a decent drive (15 miles or so, though I went the "long way" to extend it). It coded out within a couple of minutes on the way out. I got to my destination, cleared codes and started out fresh for home. It again coded out within a couple of minutes. When I got home I cleared again and ran it through the steps as described by Art's Automotive here. LOL. Nothing. Five mins KOEO. (Much longer than it took to set each time today). Five mins KOEN and then KOER. So then I drove it another 10 mins or so and still nothing.
    And then (a couple of hours later)... we had a wicked thunderstorm. It was mid-90s today and horridly humid. The storm dropped the temps something like 15-20F in the space of a few mins. I ended up having to go out in it for a minute and saw that the interior windows were all fogged up on the inside. (For comparison, our convertible with a history of a leaky top had no interior condensation...)
    So, perhaps I am off base, but my thinking at the moment is that I have a small water leak someplace to the interior. (It has to be small b/c there are no wet spots and car has no musty or moldy smell and I've never seen the interior windows fog up before, etc.) High humidity alone has never seemed to trigger these "episodes." But perhaps if it's been both rainy and humid, it leaks a little, I end up with condensation inside of the car, including the HV battery case and that is enough to trigger the code. Then I drive it, the battery gets all hot and cooks off the excess moisture. So the moisture disappears and the code disappears.
    IDK, it's all I've got at the moment. The code is gone again so I've got no testing strategy. But I'm going hunting for some water intrusion, I think.
  15. ronlewis
    ronlewis Active Member
    865
    178
    texas
    2001 Prius
    You'll get better advice than mine, but I would say that I had similar codes on one of mine and it ended up being a loose connector among the group of connectors mounted together just left of the main fuse box on the driver's side of the engine compartment. That car had been wrecked on that corner, and some combination of the body shop not squeezing the connector back together and/or it having broken clips, I forget, kept triggering a triangle. Otherwise ran OK, IIRC. I was lucky to stumble on the loose connector.
  16. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    That's great info Ron, thanks. Easy enough for me to take look. I drove it again today and it was fine. No warning lights.
  17. ttou68
    ttou68 Active Member
    345
    203
    Gen 2 are known for leak around rear taillight area..
    Josey likes this.
  18. Stock808
    Stock808 Junior Member
    Hawaii
    2001 Prius
    Bump.. Having the same issue. Do you still have your 1st Gen Prius? Did you managed to resolve the issue.
    I'm gonna check the ECU Connector to the battery and the service plug, check fuses.
    Noticed also my 12V battery is a lead-acid not a AGM (car was second-hand not new)
  19. ChapmanF
    15,407
    I just noticed this question went by several months ago with nobody answering it. It's a little tricky: how exactly do you test for a breach of isolation between two systems, without your test being an isolation breach?
    The battery is high-voltage DC, of course, but it's connected to the battery ECU, which goes and adds a weird little recognizable AC waveform on top of that. I think Klingons designed it.
    The ECU watches for any recognizable sign of that waveform turning up elsewhere in the car.
    In places where the manual, or PID descriptions, talk about that test, you run across the words "short wave". A little Japanese-English translation oddity, that, because many English speakers will hear "short wave" and think about a certain band of radio frequencies, but this term in the manual is just used to mean a certain wave, that's used in checking for shorts.
    Jakob likes this.
  20. dbstoo
    1,320
    698
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    That's pretty clever. Sort of like an X10 signal over the power lines. Easily generated and detected.
