Disappointing hwy MPG
Discussion in 'Prius c Fuel Economy' started by cyclopathic, Nov 17, 2015.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    was traveling last weekend. After stopping for gas and pulling back to interstate, "from the start" MPG was holding on at steady 38-39MPG. This is on flat surface with cruise set at 73mph, ECO on and instant consumption staying in green zone.
    and it was like that for 1.5-2hr, until we pulled to lower speed limit zone and dropped speed. Gen3 in such situation would get 6-8MPG more.
    It normally gets 58-60MPG in commute.
    51,994
  3. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    I've sometimes noticed a big step change in MPG after stopping for gaso on the highway. Never know if this is real or just the MFD. If it's real, could it be the stop puts us in a lower hybrid stage? Need to warm up and make a complete stop to get to final stage?
  4. cyclopathic
    3,292
    547
    2014 Prius c
    I don't think it was the case. We only stopped to pump gas and make a quick run to bathroom. And it wasn't like it dropped and then climbed up, the average from the start was fluctuating btw low 38 to high 39 depending on slight incline. I-85 is very flat, ESP approaching Richmond, and there wasn't wind to speak of. I think C just not very aerodynamic
  5. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
  6. bisco
    51,994
    what is the c, .29 or something?
  7. Mendel Leisk
    41,513
    73 mph is almost 120 kmh, that's getting up there, wind resistance becoming significant? I see on the Canadian highway Fuel Consumption ratings, Prius vs Prius c is 4.9 vs 5.1 liters per 100 km, which translates to 48 vs 46 mpg. Not a lot of difference, but some. The gas might also be a factor.
  8. cyclopathic
    3,292
    547
    2014 Prius c
    nope I-85, from Durham to Petersburg.
    Interstate 85 - Wikipedia, the free encyclopedia
    they (Toyota) say (lie?) .28, so 46 rating is very much inline with 48 of Gen3. Gen3 rated at .25, but also has bigger frontal area.
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    probably just the colder morning temps now. 58-60 mpg at 73 MPH is quite good.
  10. bisco
    51,994
    definitely not designed for highway speeds, but how many small commuter cars are?
    mertechperformance likes this.
  11. cyclopathic
    3,292
    547
    2014 Prius c
    Sorry for confusion I do not commute at 73MPH. Avg speed during commute in 35-40MPH range.
    In general C seems to be getting a better MPG than Gen3 at speeds <40MPH, and vice versa above.
    Funny you say it. Non-hybrid Mitsubishi Mirage is getting better than 38MPG at steady 73mph. To C's defense on 396mi tank there were 0.5mi of electric drive, just enough to cover getting in and out of gas station.
  12. Mendel Leisk
    41,513
    Yup. Not a big variation, a bit more significant on the highway:
    (From Natural Resources Canada website, showing US mpg values)
    roadrunner likes this.
  13. bisco
    51,994
    highway is the weakest part of any hybrid, imo. tough sell, if that's 99% of someone's driving.
  14. cyclopathic
    3,292
    547
    2014 Prius c
    I am thinking there is something else going on, like with rear turbulence bubble or engine getting out of efficiency zone at that load. The MPG at 60-65MPH is much better, so despite this horrid stretch the overall MPG was 51.5MPG when we got back.
    The rear turbulence bubble is an issue with C, at steady 45MPH I've observed leaves being sucked in and staying there for many seconds.
  15. Former Member 68813
    3,524
    983
    US
    sounds like the MPG display error. what was the pump MPG?
  16. cyclopathic
    3,292
    547
    2014 Prius c
    No I don't think so. Unlike Gen3 "C" has the "from the start", A-trip and B-trip MPG calculated, depending on if you are on A,B or odometer trip setting. And no "miles to empty".
    Turning ignition off resets "from the start" MPG.
  17. Mendel Leisk
    41,513
    This is a summary of the new Canadian "5-cycle" test, just the highway portion:
    The top speed during testing is 97 km/h, about 60 mph, well below the 73 mph OP had his cruise set at. Miles per gallon tends to deteriorate logarithmically as speeds climb. Within the test parameters the c's mpg starts to lag, due to aerodynamic differences. Maybe the gap increases as speeds climb further?
  18. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
  19. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    You didn't buy this gas in Florida did you? Worst state in all my travels for mpg with their gas (I frequently travel 3-4 times a year from Indiana to Florida/Southeast). I bought my prius c 6 weeks ago in Florida and 2 days later traveled home to Indiana. As soon as I got on the Interstate I got 38mpg for that tank. However, after my next fill up in Georgia, bumped up to mid 40s and since I am averaging 48-50mpg. If you go to fuelly.com and search for Davidc83, you can see my 9 fill ups and the average mpg, with the first one being the worst. I know it was a brand new car and such, but I see the low bump on my other cars/motorcycles while traveling in Florida.
  20. cyclopathic
    3,292
    547
    2014 Prius c
    If you think Florida gas is bad, go to midwest. SD, MT, etc, especially if you buy off-brand. The E85 is incredibly cheap over there, so they cheat and dilute gas with it. I was there on motorcycle in 2008? and had to pull off highway to keep engine from overheating.
    No it is not gas it was Exxon station, and as soon as speed dropped to 62-63, MPG was ~53MPG.
    And my trip to work today was 50.8mi at 49mph with 60.4mpg, same gas
