Disc Brake Caliper Slide Pin Grease(Lube)? Gen2
Discussion in 'Gen 2 Prius Main Forum' started by NortTexSalv04Prius, Apr 23, 2019.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Okay
    OEM Toyota 08887-80609 Caliper Slide Pin grease/lube (tube size/red color) is a Lithium soap based glycol grease /lube.
    Question
    Are there any substitution or near matches beside Toyota OEM for this product.??
    Please do not suggest any silicone based lubes/grease (plenty of that out there in local area)
    Permatex/CRC/3M are silicone based and green color from my research
    maybe
    #1 NortTexSalv04Prius, Apr 23, 2019
  2. ChapmanF
    15,450
    Careful there, I don't think -80609 is any of: lithium, soap, glycol, or red.
    08887-01206 is the red, lithium soap based glycol grease, recommended for the piston seals and boots and slide pins.
    If you don't want to own a tube of it, any time you buy a Toyota caliper rebuild kit (one kit has all the rubber parts and other fiddly bits for a pair of calipers), the kit includes a little pouch of the same grease.
    The 08887-80609 "disc brake grease" seems to be a different stuff, recommended for pad ears and shims (metal-to-metal contact areas). I think it is gray, and I am not sure of its composition. It may be a silicone, for all I know. You get a pouch of the gray stuff any time you buy a Toyota shim kit.
    (The normal brake service instructions do not have any grease added on pad ears, but just on the shims; the Teflon-like coating of the support plates is supposed to be slippery enough and not attract grit, but greasing the ears is suggested in a TSB that can be applied if the brakes rattle annoyingly.)
    For the red stuff, I think somebody on some forum somewhere had identified a Molykote product that might be the same stuff, though I don't know if you could obtain it in less than a bucket.
    -Chap
    Edit: another post from several years ago included a clarifying letter from Toyota Ireland in response to a question about the two greases.
    #2 ChapmanF, Apr 23, 2019
    Skibob and NortTexSalv04Prius like this.
  3. NortTexSalv04Prius
    915
    115
    thanks for clarification
    FYI
    Permatex synthetic silicone (green stuff from local parts stores) will apparently seize slide pins.
    chap
    What is the part number for Toyota caliper rebuild kit if you know off hand
  4. ChapmanF
    15,450
    04478-47050 (-47070 for later model Gen 2s).
    When you go directly to parts.toyota.com like that, you see list prices. Many dealers sell at discounts.
    Skibob likes this.
  5. oil_burner
    oil_burner Active Member
    249
    126
    slider pins are not particularly picky about type of grease as long as they have some. It's a hardened steel pin sealed with a rubber boot, I have used Permatex, or other synthetic greases with no issues for years.
    M in KC and Fostel like this.
  6. ChapmanF
    15,450
    In cases where manufacturers do recommend a specific grease for slide pins, it seems to be the "rubber" boot that guides their choice, rather than the steel of the pin.
    Fostel, NortTexSalv04Prius and padroo like this.
  7. Mendel Leisk
    38,649
    There are some lubes that unfortunately swell rubber, including the rubber collars on some guide pins. The (unmentionable) aftermarket lube I use does not.
    NortTexSalv04Prius likes this.
  8. ChapmanF
    15,450
    My main reason for putting quotes around "rubber" above was to serve as a reminder that there are as many chemistries of "rubber" as there are of "plastic". And different manufacturers, who are in the business of selecting the "rubber" they use, also make recommendations regarding the grease to use around that "rubber", for reasons that they know and we don't.
    I'm not hoping to make any product "unmentionable". I'm just trying to avoid the disservice to PriusChat readers that is done when questions about the recommended greases for Toyota's brakes are answered without saying what the recommended greases are.
  9. padroo
    padroo Senior Member
    2,763
    2,250
    Fostel likes this.
  10. NortTexSalv04Prius
    915
    115
    FYI
    Thank you everyone especially chapman ….
    From this thread/discussion
    I have come to the realization of several factors I will share
    Retailers/sellers almost always leverage the twist and use of wordage
    Lube ……..Grease
    The wide world of corporate marketing
    In the USA local parts stores will gladly sell you caliper lube maybe something like (Permatex 24110) synthetic (silicone based) ….this will and has seized slide pins (DO NOT ASK ME HOW I KNOW) seriously witness this firsthand and other persons have gone there too
    Silicone /synthetic caliper lube has issues with the Gen2 rubber boots and slide pins.
    I have found that Toyota rubber grease or boot grease(used on Gen 2 slide pin and brake bracket boot is Lithium soap based glycol lube (red color) Not a direct match however has some products have similar qualities like disc brake bearing grease(bearing grease) ..The Max rated temp are between 300F to 325F
    Toyota OEM parts is the best choice the majority of the time. I found this YouTube link which help me better understand my situation plus reading some product labels
  11. NortTexSalv04Prius
    915
    115
    FYI
    The typical generic "normal driving" temperature range for well balanced vehicle brakes is 100 to 200 degrees. A controlled mountain grade descent can produce brake temperatures between 200 and 400 degrees. Carlisle reports that a brake resin odor is produced at about 550 degrees and visible smoke is produced at 850 degrees.
    Additionally brake fluids with boil temps
    DOT 2 190 °C (374 °F) 140 °C (284 °F)
    DOT 3 205 °C (401 °F) 140 °C (284 °F) glycol ether
    DOT 4 230 °C (446 °F) 155 °C (311 °F)
    Wondering where the caliper slide pin temp is on high side?
    Fostel likes this.
  12. ChapmanF
    15,450
    To be honest, before my first Prius, I had pretty much one tube of silicone grease (it's a big tube, I doubt I'll ever use it up) that I would use for anything and everything around a brake. I have not heard of it seizing up a slide pin, or experienced any such problem myself. Silicones can be mightily high-temperature tolerant.
    My tube of the Toyota red is also large enough that it will likely become part of my estate.
    I go on about the Toyota rubber grease more for reasons of principle. I am not convinced that dire fates will befall anyone who uses a different type. I just think that, as long as Toyota has given a clear recommendation—and they have—people who come to PriusChat for the info have a right to be told what the recommendation is, even if we then say whatever we like about our favorite substitutes. That way readers have the info and aren't making their decisions on half the story.
    padroo likes this.
  13. padroo
    2,763
    2,250
    I agree Chap, it is important to know what the manufacturer recommends and it is also nice to know why they recommend what they do and if you should depart from their recommendation you are doing so at your own risk.
    My guess is if you are at a shop doing work they will have one type of grease they use on everything.
    Fostel likes this.
  14. Mendel Leisk
    38,649
    Interesting variation, Toyota vs Honda, for lubrication in the "faying" surfaces, between pad backs, shims and calipers contact points.
    Toyota indicates to use just a couple of dabs, of the same stuff as the caliper pins: say quarter-sized by 1~2 mm thick, between pad back and shim next to it.
    Honda recommends a continuous, edge-to-edge coating of all faying surfaces, pad back to shim, to caliper fingers. The dealerships locally would use Permatex Anti-Seize (or Honda equiv?), sometimes silver, sometimes copper.
    Either method seems to work fine.
    padroo likes this.
  15. a_gray_prius
    2,927
    782
    IL
    I think it's relevant to add the interest in an alternative because the tube is $37 (when bought at a discount!), and is too much for a single brake job.
    Fostel likes this.
  16. ChapmanF
    15,450
    Where are you finding that? Everything I've seen from Toyota has the red, lithium soap glycol "rubber grease" on the caliper pins (and piston, and rubber seals and boots) and the gray stuff on the pad backs and shims.
    When you buy the rubber parts kit, a pouch of the red stuff comes in it. When you buy a shim kit, a pouch of the gray stuff comes in it.
    I haven't run across a Toyota document that says to use the same stuff both places.
    Fair point. I bought my first Toyota in 2008, so my tube of rubber grease has cost me about twenty-eight cents per month so far, and decreasing.
    -Chap
  17. Mendel Leisk
    38,649
    I did see it "somewhere", but yeah, guilty of sloppy posting. Both 2nd and 3rd gen use two distinct descriptions, the one for pins the other for pad backs and shims. Gen 2 Repair Manual excerpt:
    I've seen a picture somewhere recently, showing 2 quarter sized blobs on the back of pad, and I thought the Lithium soap... description. Have a vague recollection it was a brake TSB.
    Anyways, sorry for the red herring.
  18. ChapmanF
    15,450
    Could have been the Corolla/Matrix TSB that I posted the other day.
    But it still says to use shim grease on the shims (says to install new shims, shim grease is supplied in a pouch in the shim kit), and lithium soap glycol grease on the pins.
    (Those are two different excerpts from the TSB; they just happened to look like A. B. C. in sequence!)
    The TSB was for Corolla/Matrix cars suffering from a pad-related groan or squeak noise; I don't think it was intended to suggest that every brake job requires a brand new shim kit. I generally reuse mine. My brakes don't make noise. :)
    #18 ChapmanF, Apr 25, 2019
  19. Fostel
    Fostel Member
    87
    25
    London
    Excel
    #19 Fostel, Oct 4, 2020
  20. ChapmanF
    15,450
    That page has been over there at Bob Is The Oil Guy for several years now, and it has been mentioned here before (for example, here).
    It has never quite been explained. It's clearly an image of some actual Toyota documentation page that's been drawn on. It hasn't been found (as far as I know) anywhere other than that specific Russian site (and now here, regrettably, where it will probably continue to mislead more people). Where it was linked on BITOG, the citations given were to "BR004-00" and "BR94-004", which look kinda sorta like Toyota document numbers but I never found such documents and I'm not aware anybody else did.
    Meanwhile, the other citations given in this thread (and others here on PriusChat) are to genuine Toyota documents that can be found, including more recent ones, and that continue to identify the red lithium-soap-based glycol grease, 08887-01206, as the correct grease, which is also the stuff that comes in the Toyota caliper rebuild kits, and inside a Toyota caliper out of the box.
    Fostel likes this.
