Discharged HV battery to 1 bar...until exiting freeway?
Discussion in 'Gen 2 Prius Main Forum' started by Ellis Fereday, Sep 21, 2019.
  1. Ellis Fereday
    Ellis Fereday Junior Member
    26
    My gen 2 2005 Prius with 165K miles is discharging down to 1 bar after driving 45 miles on the freeway between 65-71 mph. It will struggle going up the inclines , but never charge the battery back up past 1 bar until I exit the freeway. Is this normal for a rebuilt battery? I tried 2 different battery packs and have the same documented results. This is normal driving to and from work. The car works fine when I get to the hills of Ramona and does not struggle at all( and that is a major elevation change)? The battery is close to fully charged after I get off the freeway and drive 2 miles to home. Any suggestions or advice would be appreciated at this point. I do have a warranty with the battery but I am at a loss as the same events are happening with 2 different battery packs. Just frustrated? Thank you in advance
    51,155
    no trouble codes? one bar is not right
  3. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    Whether it is normal for second-hand (aka reconditioned/rebuilt/remanufactured) batteries from the outfit from you purchased, it is hard to say, but it definitely not normal behavior for a battery is good working order.
    A good battery should operate in and around the 5-7 range, but this could vary if there is a steep climb or steep decent, for example.
    The more stories we see here of these re-whatever batteries, it is very hard to support the notion of going with a re-whatever.
    JC91006 and jerrymildred like this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    This is normal for a dying battery. This is why I never recommend a refurb unless you like fixing the same thing over and over. Believe it or not, some people don't seem to mind.
    JC91006 and dubit like this.
  5. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Yea... Paying $200-$300 for diagnostic and module replacement a couple-few time over several years is much more affordable for most people's budgets than throwing down $2K all at one on new. Especially when it comes to Gen2 Prius owners who are obnoxiously frugal... I should, I am one. :)
  6. PriusCamper
    12,064
    4,896
    It's hard to say... If you don't have any warning lights, I'd say it's a combination of driving conditions and your packs needing reconditioning as per info here: FAQ
  7. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    When is the last time you changed the plugs and air filter and cleaned the throttle body and MAS?
