Dishwasher or regular washing?
Discussion in 'Environmental Discussion' started by burritos, Jun 18, 2006.
  1. burritos
    burritos Senior Member
    4,946
    252
    Is it better to use the dishwasher or to just wash regularly?
  2. GasGuzzler87
    GasGuzzler87 New Member
    131
    I use the dishwasher. Then again I'm no environmentalist. I do like the environment but I do not go out of my way to help. Just avoid littering and pick up trash when I do see it, try to keep from overusing electricity etc. Only litle things.
  3. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(burritos @ Jun 18 2006, 05:15 PM) [snapback]273214[/snapback]</div>
    Depends on the "load." Sometimes size DOES matter.
  4. burritos
    4,946
    252
    <div class='quotetop'>QUOTE(darelldd @ Jun 19 2006, 05:59 PM) [snapback]273642[/snapback]</div>
    I stack it to the max, but sometimes not all the food comes off some of the dishes.
  5. lilrdwgn
    lilrdwgn New Member
    32
    Winston Salem NC
    We always use the dishwasher. It is more sanitary and we bought an ASKO European model which uses 1/2 the water of an US model. Gee, sounds like a Prius and gas mileage. :) <div class='quotetop'>QUOTE(burritos @ Jun 19 2006, 07:56 PM) [snapback]273685[/snapback]</div>
  6. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    <div class='quotetop'>QUOTE(burritos @ Jun 18 2006, 07:15 PM) [snapback]273214[/snapback]</div>
    It's better for my back to use the dishwasher.
  7. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    If you fully load the dishwasher, and you have a good model, you'll almost always use less water with the dishwasher.
  8. Catskillguy
    Catskillguy New Member
    536
    Mid Hudson Valley NY
    My wife loves her dishwasher. It may not be the latest model or have all the features and dodads of a more modern one, but it gets the job done. Occasionally, it does not want to work, but usually with a little coersion, a gentle nudge, they'll get done. Some days, I'm sure she wishes she could just get rid of the old one and start fresh with a new model. But, she knows all the quirks of this one by now.
    The food is always cleaned off and the drying cycle depends on the energy that we want to use to complete the process. If we use more energy, they drying will takes less than 10 minutes, if we use the air setting, they will dry in a couple of hours.
    In case, you haven't figured it out yet, the dishwasher is ME! ;)
  9. wstander
    wstander New Member
    982
    We have all energy star appliances that use 20-50% less water than their counterparts of only 2-4 years ago.
  10. Godiva
    Godiva AmeriKan Citizen
    10,339
    I don't own a dishwasher. I do have a Dishmaster.
  11. dcoyne78
    dcoyne78 New Member
    135
    FWIW I use the dishwasher, Consumer Reports claims it is more energy efficient. In reality there are multiple dishpan methods where very little running water is used which probably are more energy efficient, but are not very convenient, maybe I'm just lazy. I do have a relatively energy efficient model, I run full loads, and don't use the heat for drying.
  12. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    Is there a commercially available dishwasher soap that doesn't pollute? Any homemade recipes for such a thing?
  13. SSimon
    SSimon Active Member
    1,426
    N/W of Chicago
    <div class='quotetop'>QUOTE(hyo silver @ Jun 27 2006, 04:17 PM) [snapback]277560[/snapback]</div>
    Trader Joes and Whole Foods have dishwashing detergent that is biodegradable. I've been using Trader Joes and I don't have any complaints. If you research the natural ingredients, you'll likely find scary information but I'm fairly certain they're less toxic then the other commerical brands that I think contain formaldehyde and petro chemicals. An added plus - not tested on laboratory animals and no animal ingredients.
  14. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    Trader Joe's carries a number of environmentally friendly cleaning products but I am not sure about dishwasher soap. I usually use the light wash and air drying on mine. It is most efficient and sanitary.
  15. ghostofjk
    ghostofjk New Member
    979
    <div class='quotetop'>QUOTE(GasGuzzler87 @ Jun 19 2006, 03:45 PM) [snapback]273632[/snapback]</div>
    :lol: B) :rolleyes:
  16. gschoen
    gschoen Member
    343
    Chicago/Wrigleyville
    2014 Prius Plug-in
    Consumer Reports stated Trader Joe's uses no chlorine or phosphates, making it enviro friendly. So did Method dish cubes, often found at Target. There might have been others I don't remember.
    If you don't rinse your dishes, on full loads, the dishwasher will use less water than you do. It uses the same water over and over for cleaning, while manual dishwashing uses constant fresh water (hot water increasing the energy usage.)
    Lowest impact, from what I've read, is to scrape your dishes as fully as possible before loading (without rinsing), using the "lowest" cycle on the dishwasher to get dishes clean (many current models have sensors, so you can set a low cycle and it will increase it if needed), and turn off the heated dry. Usually the heat from the water makes the dishes dry quickly, I use rinse aid to prevent spots. Also, using the time delay to run the dishwasher at times when its cooler or lower energy demand, such as nighttime, can lower A/C bills and reduce peak energy demand.
    I suppose the best way to use the least water is a wash tub and a rinse tub, but this isn't very sanitary (the rinse tub harbors bacteria and doesn't rise the dishes very well)
