Dismounting interior lights in 2008
Discussion in 'Gen 2 Prius Main Forum' started by ksor, Jul 27, 2019.
  1. ksor
    ksor Junior Member
    46
    Aarhus V, Denmark
    I'm trying to dismount the light panel and found these plastic buttons under the clear light panel and got them out.
    Too I found 2 screws "under" the box for my glasses ... but still the whole panel will not come off - the end towards the front is still stuck - what do I miss here ?
  2. ksor
    ksor Junior Member
    46
    Aarhus V, Denmark
    No one have any ideas ?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    You got any pics of the issues or areas?
    Pics always get a good response and help us out to visualize the issues and then share our experience:).
    Maybe try that route and see if others chime in ;).
    Good luck and keep us posted (y).
  4. jessiejosco
    jessiejosco Member
    62
    Its been some time since I pulled mine down but I seem to recall it snaps into the roof as well as the screws. Just pull down on it.
  5. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    You didn't need to remove the "buttons" under the lens. Just the 2 screws inside the sunglass holder and yank. There are two push-in studs at the leading edge and two at the trailing edge. If your overhead console has never been down before, they can be awfully tight. By about the third time you take it down, they're not so tight.
    ScottHz likes this.
  6. ksor
    ksor Junior Member
    46
    Aarhus V, Denmark
    > egg_salad
    Sorry for my late reaction ... I got no message on your reply - but thx anyway !
    I finally got it out - and as you says 2 push-studs for and back and 2 screws in the sunglass holder.
    Anyone here knows the RAL color code for the "gray" plastic ?
    It can NOT be judged from the photo here - take a look at ebay ... there are many different variations of the "gray" color" on that part. My guess is RAL 7040.
