display codes
Discussion in 'Gen 2 Prius Main Forum' started by 2007blueprius, Jan 17, 2019.
  1. 2007blueprius
    2007blueprius Member
    461
    30
    Anybody knows how to read these? See attached IMG_20190117_124207.jpg IMG_20190117_124207.jpg IMG_20190117_124234.jpg
  2. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    I believe they are radio codes
  3. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    Code Sub-Code
    01-D5 190-55-D Absence of Registration Unit AUDIO H/U Error occurred 13 times
    01-DC 1C6-87-F Transmission Error GATEWAY Error occurred 16+ times
    01-DC 190-8B-F Transmission Error AUDIO H/U Error occurred 16+ times
    (If same sub code is recorded in other components, check harness for Power supply and communication system for all components shown by Sub-code)
    62-46 Scratched / Reversed Disc
    62-42 Disc Cannot be read (change disc, clean disc, try another)
    62-45 Eject Error (Clear DTC; Recheck DTC; Replace radio receiver)
    NOTE: There is no indication of a current indication or date and time for these codes
    To clear the DTC codes press CLEAR for 3 seconds
    To clear the current and past DTC codes, as well as the connected device names press and hold Memory clear for 3 seconds.
    2007blueprius likes this.
  4. 2007blueprius
    461
    30
    Thank you i have been trying to figure out how to clear them
