Display contents of MFD are skewed
Discussion in 'Gen 2 Prius Audio and Electronics' started by ChrisA, Apr 26, 2008.
  1. ChrisA
    ChrisA New Member
    Round Rock, Texas
    Found a single hit of this question from a question in 2007, but no responses.
    My MFD (Multi Function Display) icons are displayed for all the screens correctly, but the actual touch points are skewed beneath the icon (i.e., I have to touch the screen 1/2 to 3/4 of an inch below the icon in order for it to respond).
    Does anyone know if there is a 'dispay' or 'grid' correction that the user can do to fix this condition or is this something that must be corrected by the dealer?
    Thanks
    Chris
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Hi Chris. I think there is a "tuning" program I saw once, but I can't remember the procedure. I'll look, but the dealer should be able to fix it too.
  3. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    there was a calibration function, but for the life of me, i sure can't find it, when i try to go to it all i get is a white screen
    press "on"
    press "display"
    press the upper left and lower left corners 6 times
    this will bring up the system check screen
    press "menu" on right upper corner of screen
    from the "diagnosis menu"
    touch upper left and lower right
    this will bring up the "product diagnosis screen"
    the calibration is supposed to be there, but i can't figure it out
    good luck
    don't mess around with the eprom.ram or any of that other stuff
    turning the car off or holding the display button for 3 or more seconds should exit out and bring you back to your normal prius mfd screen
  4. ChrisA
    ChrisA New Member
    Round Rock, Texas
    My display is so skewed today, I can't get into the diagnostic screen any longer (nor can I select an option on any of the screens where the touch icon is located near the bottom of the MFD...!) I have one sick display.
    Thanks for all the assistance. Might be paying a visit to the dealer to get this guy corrected.
    Chris
  5. rigormortis
    1,340
    26
    san jose, ca
    there is another way to go into the diagnostic scrreens. somethign about flashing the brake lights or headlights??? i tried it once or twice but i was never able to go into the menus and had to result to the hidden buttons
  6. blazer_5154
    blazer_5154 Heh, you said "member"
    106
    Maryland
    If my memory serves me correctly, you can hold the ODO / TRIP button while turning the headlights on / off 3 times in succession. Hope this helps.
  7. rigormortis
    1,340
    26
    san jose, ca
    isn't that for resetting the maintainaince light or seatbelts/reverse beep?
    i thought it was flashing the headlights and holding down info or display
