Display question
Discussion in 'Newbie Forum' started by martin2nz, Mar 12, 2008.
  1. martin2nz
    martin2nz New Member
    2003 Prius
    Hi guys
    We are the proud owners of our 2003 Prius. New Zealand new ..imported from Japan. Very happy with her. Came with loads of extras ..6 CD, Cruise and auto lights.
    All the dash is in Japanese ..as is the MFD. Worked out most of it , but have a quick question.
    When driving to the economy display screen ..getting good results ..32kpl .. whats the little blippy thing that appears every now and again? Is it a gold star for good driving?
    Appreciate any help.
    Cheers from New Zealand
  2. seesfar
    seesfar New Member
    38
    east texas
    Welcome to priuschat. Not sure what you are seeing on MFD but if it is below 37Degress F and by outside Temp display it is a snowflake to warn of possible ice. Otherwise don't know.
  3. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    If you need help with Japanese on MFD, drop me a PM with pictures. I will translate them for you. Enjoy your Prius.
  4. martin2nz
    2003 Prius
    I've found a picture which shows the blip ...
    I assume it shows energy generated .. is that good or bad?
    Not having the user manual is a real pain!
    Thanks guys
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    Welcome!
    I think you're talking about 50Wh regeneration mark on the consumption screen.
    Please refer to John's info sheet. Also, the user guide will be helpful.
    http://john1701a.com/prius/documents/Prius_Info-Sheet_classic.pdf
    http://john1701a.com/prius/documents/Prius_User-Guide_classic.pdf
    Q: Is the regeneration mark good?
    A: It depends...
    We see very few number of the regen mark on hypermilers screen. They don't use brakes a lot. :eek:
    Of course, you have to stop at red lights and stop signs, so the regen mark is good when you have to use brake.
    Ken@Japan
  6. patsparks
    10,664
    567
    Adelaide South Australia
    You beat me to it Ken, well done.
