Displaying SOC and BTA on Scangauge
Discussion in 'Prius PHEV Plug-In Modifications' started by kiettyyyy, Nov 8, 2009.
  1. kiettyyyy
    kiettyyyy Plug-In Supply Engineer
    205
    167
    West Covina, CA
    Hey all,
    I've seen many photos with other individuals setting up their Scangauges to display both SOC and BTA on the same screen(at the same time).
    How do you do this?
    If tell my Scangauge to display SOC and BTA, only SOC will show and the BTA will be blank.
    It only displays one at a time.
    Any ideas?
    Thanks!
  2. kiettyyyy
    205
    167
    West Covina, CA
    Actually, I think I just figured it out..
    I have to use the Passive gauges, right?
  3. kaval
    kaval New Member
    Can you tell me how to do this please?
  4. Floyd2
    Floyd2 progressio per sententia
    106
    23
    Netherlands, Europe
    If two gauges have the same TXD value they will collide. So if you use 07E321CE for BTA then don't use the 07E321CE TXD for SOC. They will interfere and one of the two will not be shown.
    Instead, use a passive request for the SOC at TXD: 03C3.
    So enter these settings for SOC instead:
    TXD 03C3
    RXF 010382CB0000
    RXD 2010
    MTH 000A00020000
    NAM SOC
    Now you can watch BTA and SOC simultaniously. :)
    Good luck! Floyd
    2 people like this.
  5. epa5epa
    epa5epa Junior Member
    28
    Taiwan
    I am wonder why my Soc is blank along with Bta today till I find Floyd's posting.
    A friend in need is a friend indeed.
    Thanks! Floyd
  6. kiettyyyy
    205
    167
    West Covina, CA
    About a month ago, I spoke with Ron and James from Linear Logic regarding same RXF addresses. Currently, if two xgauges contain the same RXF match data (bytes 2 and 4, 1 and 3 are used for determining which byte in the message to match), the xgauge(arbitrarily determined) is executed first will "steal" away any data with the same RXF match from any other xgauge.
    According to Linear Logic, this will be taken care of in the next firmware release.
    Can't wait to view my custom CAN data :)
    -Kiet
