Distance between iso-fix anchors
Discussion in 'Prius v Main Forum' started by m3rkury, Oct 6, 2017.
  1. m3rkury
    m3rkury New Member
    Warsaw, Poland
    I am searching for a new car for my growing family (now we have 3 children ages: 8, 6 and nearly 1) and we are a bit uncomfortable in our Civic (europe VIII gen hatchback) :)
    I'm wondering if Prius+ (Prius v) is a car to go for us.
    I'm worried about space for 3rd childseat in the middle.
    I don't have any Prius+ available to test in my area...
    Could anyone be so kind and measure the distance between the medial edge of inner iso-fix anchor (see picture below)?
    My Civic (which of course can't handle 3 childseats) has 34 cm (about 13,5 inches).
  2. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    The second row seats in the Prius v sold in North America are very different than those in the Prius+ and Prius v sold elsewhere.
    For accuracy, get your measurements from a European Prius+.
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    If available download the online version of the Owner’s Manual of the model and year in question. Sometimes the design restricts which positions in the rear are recommended for car seats. If the answer is not clear I would contact Toyota directly with this question. I know the Britax Baby Safe Car Seat I had in the past had fixed spacing between the latches, and the picture posted does not look like you could fit more than two, in the outer seating positions.
    BUT, in my research of the past, if your child seats offer the option to use the seat belt, the seat belt can handle far more weight than the ISO-fix, so then I would just use the belts. ISO-fix was a convenience, but the belts are stronger! I just checked ours and as Offline noted, I do believe the seats are different. The latch points are hidden behind a zippered cover. I think this is a no-no in Europe. Also, I measured about 11 inches between the latch points on the two outer seats. In between the latches across the middle seat is far wider. I also do believe that the latches only allow (technically for safety) one attachment, so that in our case only two ISO seats in the outer positions as well.
  4. Mendel Leisk
    41,882
    I've put 3 child seats in the back (on a 2010 Prius), all connecting to those strong points. It's technically possible, but now that I think about it, and engineer might frown on it, the central seat is doubling the load on the inner strong points, and connecting on a more diagonal angle.
    #4 Mendel Leisk, Oct 6, 2017
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Do check the weight limits on those ISO attachments. They aren’t/weren’t very strong. Could have been changes since my son was small. He is now twelve and weighs practically the same as me. He grew out of the limits really quick, including the seat weight that is. I do believe it is only one seat per set of latches. Some seats were fixed in width as well, like the Baby Safe. You could not latch it on the wider center even if you wanted to.
  6. Jarkko
    Jarkko Junior Member
    36
    Finland
    2012 Prius+ MPV
    57 cm.
    I have three kids (5,7, and 9), so I can tell from experience :) If we travel as whole family, then all the kids are on the second row. One seat is with hard isofix anchors, middle one is without, and the third is with kind of belt-anchros to isofix.
    The first seat is Römer Kidfix -seat, the other models I do not remember by heart.
    Isofix anchor points are hard to reach, as they are hidden inside the seat padding. In our old car (Citroen C4 Picasso) isofix mounting was just a mater of click, but with Prius+ you have to practice and even then it is a process :)
    You'll also need to think how you reach the seat belt buckets. I have there short rigid extensions.
    Here are the pictures:
    Raytheeagle likes this.
  7. m3rkury
    m3rkury New Member
    Warsaw, Poland
    Thank you all (especially Jarkko)! I'm interested in european version (Prius+).
  8. SmellyTofu
    SmellyTofu Average punter
    251
    29
    Sydney
    Just be careful with having the ISOFIX seat in too long. The zipper that reveals the ISOFIX mounting has a slight tear in the vinyl/fake leather seat.
