Distorted (over amplified??) sound with JBL
Discussion in 'Gen 3 Prius Audio and Electronics' started by mbarkh, Oct 23, 2011.
  1. mbarkh
    mbarkh Junior Member
    17
    Burbank
    Thank You to friends who made illustrations for instaling GPS and cameras.
    After long delay I got unit from China on this Friday, the units looks same as ottonavis.
    What I like -
    Screen quality very good
    Fast unit
    Bluetooth buttons works on steering wheel
    Voice command button for mute (not bad)
    Now problems
    After installing unit to dash
    1.I start unit, select E. amplifier mode and was upset
    Sound quality was bad, it’s like distorted on high frequencies (over amplified)
    After I note that cannot access sd card, so when I pressed NAVI button it give me info file not found, interesting when I connect usb flash drives to usb cables drom unit I listen USB connection SOUND but cannot access USB Flash drive.
    I went home and check sd card from headunit and usb flash drive
    Was surprised micro sd card empty no GPS software at all.
    USB Flash drive was formatted on NTFS, I formatted to FAT32 again cannot access, after formating to FAT can access files from USB FLASH DRIVE
    Micro SD card from head unit was formatted to FAT32, copied some mp3 files and the result - when I plug sd card to unit – nothing.
    Now my question
    1. Is possible to adjust sound level on JBL input or on UNIT using some service menu if its available
    I think that sound to JBL Amp higher than it should be (maybe I’m wrong)
    2. What type of file system this units reads
    3. Can I download and install US gps software (Chinese, original etc.)
    4. Is it possible to fix sd card problem upgrading firmware (BTW firmware EN-PRIMA-ARM-SLC-V1.40)
  2. prius2010II
    prius2010II Member
    269
    23
    us
    You need to contact the place you purchased your unit, unless the unit came with some kind of factory warranty. What did you pay? Buying from a US distributor/dealer might have gotten you faster delivery, US support and US warranty.
    Is the distortion with just the radio or also with the IPod and CD? An Ottonavi poster is having a similar issue but only with the radio. Ipod and CD is OK.
    Is the micro SD slot intended for music? I thought that slot was only for nav software and maps.
    You need to get your map software and navigation software from the place you purchased the unit. Ask them for a link. Otherwise you'll have to hunt for pirated software/maps.
    You might consider just returning the unit. File a paypal dispute.
  3. mschul
    mschul Junior Member
    ct
    I hate to be a downer, but I had an Ottonavi with the same issue dealing with the JBL. It sounds as if the line in to the amp is way too hot, and the sound gets very distorted. After talking with ottonavi and fishing for any software/hardware fix I gave up and sent the unit back. If it's the same or similar to Ottonavi, I don't think they quite have the bugs worked out yet to deal with the JBL amp.
    Sorry to burst your bubble...
  4. glennhl
    glennhl Member
    175
    Arizona
    I'm the person with the distorted sound from AM/FM on my Ottonavi. I'm waiting for a new replacement unit, they are out of stock right now. However, I can get excellent sound from my AM/FM if I select Internal Amp. Then when I go to IPOD/CD, I switch back to External Amp. I hardly ever listen to AM/FM, so this is fine with me. Now you guys have me scared not to get a replacement unit in case it sounds like crap all the time. Maybe they'll send me the replacement unit (I'll pay for it), then get a refund for the one I send back. The unit is so nice I would live with the way it is right now if I have to. But Ottonavi claims that the Prius units work great, we'll see.
  5. mbarkh
    17
    Burbank
    Hi thank You for reply.
    Last month when I tried to order I saw this unit only on ebay – one store was in California (I think it was ottonavi) another “Fedom” China. But it disappear from Californian store when I was ready to buy and I ordered from China.
    Why I decide to buy this unit because a lot of info on European and Russian car electronics forums and most of owners are happy with “Roadrovers”….
    Interesting that here in US (I see this on this forum) and Fedoms customer service very responsive and honest.
    Today I contacted to seller, they promise send me some new firmware upgrades. And got some new info from manufacturer about JBL.
    I’ll try make experiments and let you know.
    Interesting that from iphone via bluetooth much better probably because sound from iphone lower.
    Interesting what quality with other jbl kit like metra or other kits from Best Buy,
    On our units JBL kit just cable with 2 different connector
    And kits from Canadian store or Best Buy has some box (interesting what inside this box?)
    (It seems my device and ottonavi’s - Roadrover and model D2271 I got this info under bluetooth settings on iphone)
  6. mbarkh
    17
    Burbank
    Just now I checked something, i think its good news about sound.
    Using update.exe file I found this file on other forums it was possible see windows ce desktop, on control panel I change sound level and now I have excellent quality sound, next question how to save this, because as soon I restart system sound on wince control panel again maximum.
  7. glennhl
    glennhl Member
    175
    Arizona
    Hopefully we can fix our problem with a firmware or software update. Please keep us posted.
  8. mbarkh
    17
    Burbank
    After Firmware and MCU update the same problem.
  9. mbarkh
    17
    Burbank
    Today I did install Schosche Toyota Interface (from Bestbuy) and no more distortion.
    Schosche Toyota Interface has bad review on Internet and not adjustable but it was on local store. Next week I'll order Metra interface (I think on Metra you can adjust gain manually) Anyway some success for JBL owners. (I check only sound on USB flash drives, navigation, dvd, didnt check CD)
    Another problem on my unit - after firmware and MCU upgrade FM and AM doesn't work (I think after MCU)
    Will contact seller again on Monday. Hope buggy software.
  10. glennhl
    glennhl Member
    175
    Arizona
    Did you hook up the RCA's from the back of the unit to the Scosche adapter? What other wires did you hook up? I may try that. I assume you have to use the "internal amp" setting on the Ottonavi unit.
    Also, what is the model number of the Scosche adapter? Thanks.
  11. mbarkh
    17
    Burbank
    I use RCA Cables from unit and connect to Schosche using color code on manual
    From big connector I used only red, yellow and black wires (see picture).
    AMP wire from unit I connect to blue white.
    Interface model: Schosche TA07SR
    Unit Interface change to I-Amp
  12. evtran
    evtran New Member
    58
    Hi guys,
    Can someone from this thread send me the information on where to download the latest firmware for this unit and what steps are needed to upgrade it? I went to the product site and it wasn't very helpful (Chinese site - RoadRover). Please send it to me via PM if possible.
    Thanks for your help!
  13. evtran
    evtran New Member
    58
    Can Anyone help? Thanks.
  14. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    For what it's worth, in my experience, distorted sound from speakers is usually due to under amplification. Over amplification will simply blow your speakers. :(
