DIY battery charger from old cordless power tools?
Discussion in 'Gen 2 Prius Main Forum' started by MarkySparky, Mar 12, 2025.
Tags:
  1. MarkySparky
    MarkySparky Junior Member
    30
    I was just thinking what would feasibility be to take some old cordless power tool battery chargers and modify them to be used for charging 7.2 v(nominal) Prius battery modules. Would probably need some modification of regulator circuit to set maximum voltage and current. The older ones from 9 to 12 volt tools can often be had for nothing. I'll have to dig out an old one and experiment. Has anyone else done so already? It might be a cheap way to charge multiple modules at once.
  2. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    Dreams, dreams...
    What current are you going to charge the modules with and what voltage?
    There are homemade devices. For example, one of them.
    DIY Grid Reconditioning Charger | PriusChat
    #2 MAX2, Mar 12, 2025
