DIY Carbon Fiber stick together with Toyota emblem
Discussion in 'Gen 2 Prius Accessories & Modifications' started by powerjo, May 20, 2011.
  1. powerjo
    powerjo Member
    112
    Hong Kong
    DIY Carbon Fiber sticker <DONE>
    1. Take photo
    2. trace in Illustrator & print out
    3. cut the carbon fiber (look) sticker
    Still need some adjustment. Will upload the finished work later ! :)
  2. powerjo
    powerjo Member
    112
    Hong Kong
    DIY work is done ! :)
  3. macmaster05
    macmaster05 Senor Member
    4,050
    727
    Nice job. You could've also used a Hasepro sticker (pre-cut). Is that 3M di-noc cf?
  4. powerjo
    powerjo Member
    112
    Hong Kong
    I asked the shop keeper would it be fitted to the emblem of my car. Her answer was "not sure" !
    So, I bought a roll of the carbon fiber sticker to make by myself. That was 1/3 price of the pre-cut ! And the roll of the sticker is 12" x 36" big !
    I can stick anywhere not just the emblem! :)
  5. kammssss
    kammssss Member
    287
    85
    SoCal
    Hello,
    Where did you buy the carbon sticker? Thanks.
  6. powerjo
    powerjo Member
    112
    Hong Kong
    Just normal car accessory shop. They hv several types. For the most expensive is 3M. Mine is cheap one but looks good in the texture.
  7. powerjo
    powerjo Member
    112
    Hong Kong
    Newly made !
      File size:
      222.5 KB
      1,114
  8. macmaster05
    4,050
    727
    Ahh man that's sweet! Did you have to disassemble it to apply the cf? I would do that on mine but I'm afraid the contrast between cf and magnetic gray won't be as dramatic.
  9. macmaster05
    4,050
    727
    I'm also thinking of wrapping my chrome grille/smile, but I don't want to remove my grille. Lazy. I cringe every time I see the front of my car...the chrome just doesn't look right.
  10. powerjo
    powerjo Member
    112
    Hong Kong
    Hi macmaster05, I didn't disassemble, just sticked directly on it. Cut the useless parts by cutter after sticked the cf. You'll need some attention to the middle part as there is a piece of black stuff stands there. :D
  11. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    can we get a better shot of that beautiful lip you got there??? :eek: :D:rockon:
  12. powerjo
    powerjo Member
    112
    Hong Kong
  13. pictone
    pictone Junior Member
    Atlanta
    I purchased a 6" x 12" piece of carbon fiber sticker from www.metrorestyling.com for $1.99 plus shipping. Popped off rear emblem by slipping a credit card underneath. Removed front emblem by unscrewing from inside the hood. Then I simply traced the existing emblem backing on to the sticker, cut the sticker with a scissor and then adhered the sticker to the original plastic backing, punching a few holes as needed. 15 minutes.
  14. LIPriusFreak
    449
    34
    Long Island, NY
  15. LIPriusFreak
    449
    34
    Long Island, NY
    the emblem stuck back on after you removed it? glue (3m tape) was still sticky?
  16. pictone
    Atlanta
    The emblems are not taped to the vehicle. They have "barbed" clips protruding from the back which are inserted into holes. For the rear emblem, if you slide a credit card under at the bottom and work it around toward one side, you will release one of the clips and the emblem will just pop off. For the front emblem, you can't do this, as it is recessed. Using a short phillips screwdriver, you can unscrew the front badge assembly from inside the hood (only two screws). You can then push the badge assembly out from behind. Once in your hands, you can easily separate the "chrome" piece from its base to get to the plastic sheet in between.
  17. LIPriusFreak
    449
    34
    Long Island, NY
    I posted my question after realizing you did this to a gen III. my emblems look glued on on my gen II
  18. macmaster05
    4,050
    727
    The 'T' emblems are only screwed in. The "Prius" "HSD" "Hybrid" and "Toyota" badges are only taped on however.
    But I'm not sure pictone's trick will work for the Gen II front and rear emblems.
  19. LIPriusFreak
    449
    34
    Long Island, NY
    would be kinda cool...I'm a fan of CF. I actually plan to wrap my roof in 3M Di-NoC
  20. macmaster05
    4,050
    727
    cf is awesome, maybe if i have time someday i'll wrap my interior with it.
