DIY disaster - Need Help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dsleighton, Jul 5, 2010.
  1. dsleighton
    dsleighton Junior Member
    Connecticut
    Hi everyone,
    Multi-year lurker and beneficiary, but first time poster. I have done a lot of DIY projects on my 2005, and yesterday I did two, which has led me to a major problem. First, what I did:
    I read a thread regarding cleaning of the HV battery fan. First I disconnected the auxillery battery, and then I took apart the back seat area casing, carpeting, etc, disconnected the two plugs for the blower, and cleaned it with an air compressor. BTW - I have 98,000 on this car and there was only a light coating of dust - don't waste your time :). Like an idiot, I moved on to the next job without testing for a restart.
    Next job was the auto-leveling headlight issue. I took out the sensor and opened it, only to find sludge instead of springs. After a lot of cleaning, I got the terminals relatively clean and replaced the 'springs' with ball-point pen springs. I noticed major corrosion inside the piece, and two small corroded leads on the cover piece actually broke off. I re-attached and connected the sensor.
    Now, the Prius will drive with the HV battery, but the ICE won't start! I read codes P0000 and U0100 with the scanguage II, and as others have mentioned, the gas level blinks at 1 pip and then all pips. The red triangle appears with the car/exclamation point on the MFD, and strangely, the temperature outside reads as "E." My coolant temp reads at 31 degrees F.
    The aux battery needs to be replaced (11.4v at rest), and I thought that disconnecting it may have been the last straw. However, I also tried to jump the Prius with my Rav4 this morning with no luck (scanguage read 13.8v on the Prius while connected to the running Rav4.)
    I have checked all the clip-in connections I made while cleaning the blower fan, the headlight sensor, and the aux battery. At this point my only guess is that the headlight sensor is causing the problem, though that seems ridiculous because a. It was already non-functional, and b. It's an exposed part and could be damaged while driving; would seem like a major design flaw, and some Prius don't even have it.
    Gas is actually at about 4 pips and SOC is roughly 55.0. All dealerships are closed today, so I'd have to wait. Please help if you think you have anything useful - I'm hoping Patrick will take a stab at this :)!
    Frustrated and anxious,
    Dave
  2. Patrick Wong
    18,200
    6,471
    Hi Dave,
    I wouldn't worry about the headlight sensor for now. Your no-start problem is more serious than that. Here are the items that need to be checked:
    1. Traction battery fan: recheck any wiring harness connectors that you had removed. Make sure that the plastic locks have engaged.
    2. 12V battery: Disconnect the negative battery terminal cable at the body for a few minutes so that the logged DTC has a chance to clear. While waiting, check the tightness of the positive terminal cable connector at the battery. Then reconnect the negative terminal cable and make sure it is tight, both at the battery and at the body. Try to make the car READY.
    3. If unsuccessful, try to jump-start again.
    4. Your ScanGauge is useless with respect to reading the logged DTC, so don't bother with that. (If your car had engine ECU DTC, the Scan Gauge would probably be able to retrieve them. However your car probably has DTC logged by the hybrid vehicle or traction battery ECUs.)
    5. If steps 1 - 3 do not yield positive results, you'll probably have to have the car towed-in to the dealer. Good luck.
  3. dsleighton
    Connecticut
    done.
    I did so, and the same situation occurred, plus the following: The MFD briefly gave a message like "The transmission lock position is abnormal..." but the entire screen went blank after about 1.5 seconds. I then tried to shut the car down by pressing START again, and everything fired up (with the same problems as before.) I wish I had a chance to read that message, but will try again and see if I can get it to replicate. Don't want to work for too long though and deplete the traction battery
  4. Patrick Wong
    18,200
    6,471
    I think that one problem is your 12V battery. You might try disconnecting the negative cable once more, and insulate the loose end (use electrical tape, a Baggie, etc.) from ground.
    Then try to jumpstart your car while the 12V battery is out of the picture. Hook the positive jump cable to the battery positive terminal; and the negative jump cable to a bare metal ground on the Prius body. The other side of the cable goes to your RAV4's battery.
    Make sure that the terminal polarity is correct (positive to positive; negative to negative <ground or body>) and that the jump connections are sound. What happens?
  5. dsleighton
    Connecticut
    Tried as you suggested and removed the terminals from the prius battery. Hooked up directly to the Rav4 (with + to + and -Rav4 to frame on the Prius. Ran the Rav4 at 2000rpm for a minute, and cabin bulbs, etc are on in Prius. Went to start, and exact same sequence comes up. Strangely, does not seem to be the battery then. Also, there are only 2 hookups on the HV fan, very simple and obvious; those are snapped in. I checked around for other areas or connections I may have knocked loose, but found none. It seems the only thing would be the headlight sensor... but why would it's malfunction impair the starting of the ICE? Does it carry other information as well, and maybe I broke a circuit? Has anyone run a Gen II with that sensor totally removed?
    I'm baffled.
  6. kenmce
    kenmce High Voltage Member
    1,527
    502
    NY
    We have three possible points of failure here:
    1.) Harness associated with HV battery fan.
    This is basically just a 12 volt blower motor that the car doesn't use that much. I would expect the car to start and run no matter what its condition. I don't know what the car would do if it wanted that fan and couldn't find it, but you ought to be able to start the ICE before it got fussy.
    2.) Headlight sensor.
    I know from personal experience that the car will start and run regardless of the headlight leveling sensor. It will give you a light and a message, but the car starts and runs just fine, so it's not that.
    3.) 12 volt acessory battery.
    I have seen reports of squirrely behavior that trace back to a bad 12 volt battery. The various computers that run the car all rely on it. This is my chief suspect.
    P.S. One you get the carpeted panels out, is there any empty space in the area around that blower?
  7. dsleighton
    Connecticut
    Ken - there is enough space to get your hands in to take out nuts, etc. Maybe you could smuggle a beer bottle in there but its not very roomy. What are your thoughts on the jumping procedure where I bypassed the 12v battery and went to another running vehicle?
  8. Patrick Wong
    18,200
    6,471
    One other item to check: how about the orange traction battery interlock switch on the driver's side of the traction battery case. Did you remove or otherwise disturb that interlock switch while working on removing the hatch trim and the battery vent fan?
    When the switch is installed, the handle has to be pivoted 90 degrees then slid, to lock in place. If the interlock switch is properly installed, then I'm out of ideas besides having your car towed to the Toyota dealership tomorrow morning.
  9. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Here is a picture of the switch I took recently:
    Good luck! :)
  10. dsleighton
    Connecticut
    Thanks for the ideas, guys. I also thought about that switch, but its on the opposite side of where the fan is, and it looks fine and secure. Additionally, the car can drive using the HV battery, so I would assume that's double confirmation its connected. Will get a tow to dealer today and update when I found out. My guess is that the low 12v battery may have given an error message into the hybrid system that needs to be cleared and that I can't with just a scanguage. I simply didn't do anything complicated, nor did I drive around the car in this state, so I just can't imagine the problem being severe. At least I hope!
  11. Patrick Wong
    18,200
    6,471
    An error code logged by the skid control or airbag ECU needs to be cleared using the Toyota diagnostic laptop or else a jumper wire on the DLC3 socket. However error codes logged by the engine, hybrid vehicle, and traction battery ECUs should be cleared when you remove 12V power, assuming that the underlying cause has been resolved.
    I'm puzzled by the symptoms that you listed in your OP: "...strangely, the temperature outside reads as "E." My coolant temp reads at 31 degrees F." I don't know what would cause those symptoms, assuming your ambient air temp is well above freezing.
  12. 2009Prius
    2,705
    510
    63
    This may not have anything to do with the non start problem but I think it is better to use a vacuum as opposed to compressed air (risking dusts blown to wrong places).
  13. dsleighton
    Connecticut
    Thanks 2009 - I removed the assembly completely so dust was only being blown onto my driveway :)
    Patrick - agreed; its a strange thing. I don't know if it matters, but originally, I disconnected the positive connectors to the 12v battery, not the negative cable (this seemed quicker). Though, as you said, everything should have cleared after a minute with no 12v power, and should have been ready to go when connected to my 12v Rav4 source. One more thing - you mentioned "An error code logged by the skid control." I find it unlikely, but after doing the work, I went to move the Prius and forgot to disengage the parking brake; I noticed the VSC light come on.... again, I doubt this as well.
    Oh well, flatbed just left and hopefully I'll hear something from the dealership in a few hours.
  14. Patrick Wong
    18,200
    6,471
    Disconnecting the positive connector to the 12V battery is significant only from a safety perspective: if your wrench shorts to the body then you'll cause a big spark.
    If I had known that the VSC light was on I would have given you instructions on how to clear the skid control ECU DTC, which involves shorting pins 4 and 13 on the DLC3 connector. However that should not have prevented the engine from running.
  15. dsleighton
    Connecticut
    By positive terminal I meant the plastic snaps, and I agree the whole connection could be dangerous (it also would be a lot more hastle I think).
    *UPDATE* Got a call from the dealer - they said nothing major seems to be broken/damaged, etc, and that they would probably need a few hours to clear codes and do diagnostic tests. The hybrid specialist speculated that a short my have blown a fuse, or something of that nature. Got the impression they figured it to be something of a minimal nature (I realize typing this subjects me to the possibility of Murphy's Law) Will update again when I hear more details.
  16. dsleighton
    Connecticut
    Just got back from dealer, and the culprit was a blown 15A fuse (coded as 3091 C. Interestingly, this also cured a small problem I was having. About a month ago, my auto driver side window would go full up and then lower to half height consistently, no matter how far it lifted initially (as long as it was on 'auto up.') This no longer occurs...
    I snuck by at only 181.31, much lower than my fears, though much greater than a $1 fuse costs. Wish I knew more; this has been a strange series of events.
  17. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Very interesting thread, thanks.
    I'm glad to hear your car is back to normal.
    I am curious to know what circuits the problematic fuse was inline with.
  18. kenmce
    1,527
    502
    NY
    I'm confused about why it manifested only after you worked on the car. What does this fuse control?
    I figure $80 for the tow, $1.31 for the fuse, and $ 100 for knowing what to check.
  19. 2009Prius
    2,705
    510
    63
    or for having invested $10000 in Toyota scan tool to extract the DTCs. ;)
  20. 2009Prius
    2,705
    510
    63
    Glad to know that the car is fine and at least it did not cost too much.
    I wonder if the fuse was blown a month ago causing the window behaving strangely but the computer wouldn't realize that until it got reset by disconnecting the 12V battery during the DIY. Waiting for the experts...
