DIY Gen 2 Prius Upgrade Mod(Planning)
Discussion in 'Prius PHEV Plug-In Modifications' started by NortTexSalv04Prius, Apr 7, 2012.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Hello
    I am planning to add a 28 module7.2volt Nimh OEM 201.6 volt to my existing Gen2 Prius. The additional pack will mean 56 total modules and 400. volt plus 100 pound. I can get a oem pack at a reasonable price. My concerns are many and I have several unresolved questions and issues. Some of these include the following:
    Wire schematic(DIY) and configure from pack to pack?
    Would this require getting a BMS?
    Would this require getting a charger?
    Parts list?
  2. planetaire
    planetaire Plug in 20 kWh 85 km/h or > 208km range
    190
    139
    France
    As far as I know, nobody has serialy connected 2 oem nimh cells.
    They where always paralleled. That's to say the + pole with the other + pole.
    Note that average voltage is not 201v but 220-230v, so you would have 450v.
    This would have been a solution in order to bypass the boost converter, which is the main power limitation in EV mode, about 22kW.
    But connecting after this boost converter would be a huge chalenge.
    Forget it..
    All the diy I saw have paralleled there nimh battery packs.
    May I suggest you having a look on hybridinterfaces.ca
    Please be very carreful. 220v dc (or 450v dc) will kill you.
    2 people like this.
  3. Flying White Dutchman
    4,374
    313
    400 volts? series?
    mm forget it!
    just do what you read that the other guys do
    if your unable because of cost then save the money right now because it will be lost.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Lithium with BMS+ is the way to go for a complete DIY. There isn't enough energy storage in adding just one extra Prius battery to make it worth the headache. Plus, the cost of used batteries has gone way up in the past 5 years. A few years ago you could get good ones for 200-300, now they are $500 and up. Basically, the cost per kWh of used NiMH is now comparable to the cost of new lithium. The issue with lithium is getting reasonably matched quality cells without paying more than $1.50 per amp hour. The stream of consciousness PHEV conversion thread has a wealth of information...you've probably read some or most of it, but I'd say it is the best source of info for the current DIY PHEV state of the art and the issues involved. http://priuschat.com/forums/prius-p...0-planing-canview-bms-conversion-lithium.html
    In the end, I think it would take you weeks if not months of work to get either a lithium system or a NiMH system up and running satisfactorily. If you are going to put that much time into the project, be sure to go all-in and do it right.
    2 people like this.
  5. NortTexSalv04Prius
    915
    115
    I have read hybridinterface aka norm dick website the pros and cons of battery chemistry .Norm states that keeping a additional pack at same exact voltage overcomes some of the issues/challenge that calcar had with their pack design....Since Prius counts amps
  6. NortTexSalv04Prius
    915
    115
    I agree that the energy density is low.. (con)
    The price on OEM pack about $850 and up .....(pro) I would spend 850 on lithuim ship cost....to my dest,,,,
    I believe dual power aka mr bigh has 4 oem pack plus on his prius
    If I have no other choice would go two (2) more OEM to make total of three ,I am just trying to keep trunk space and prefer one.(1)
  7. NortTexSalv04Prius
    915
    115
    The electrifly Triton2 charger is nice
  8. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Lithium will take up much less room. Shop around for prices. Flying White Dutchman, how much did it cost to get your cells? Note also the precautions that were built into the parallel charging process, multiple failsafes, etc.
    Some statements from NWPriusPlus that you need to take very seriously:
    "It requires significant work and prior knowledge"
    "it took me a whole year to figure out a suitable way to install and tie-in the batteries, and I also built 4 versions of my charging system."
    "By far the most difficult and risky part of the conversion is the charging operation, as has been proven by several documented battery "expansion" incidents."
    " All three batteries are fan cooled, by powerful computer case fans (full 1 amp at 12 volts, Vantec TD9238H 92mm Case Fan, 119 CFM). These are noisy, but powerful, and continue to run even after the charger shuts off, until I check the battery temps before physically unplug."
    Do not think for a moment that a single charger will just work. You need cooling, temperature probes, and timers. Even with multiple charging failsafes, people have still had explosions which have resulted in insurance writeoffs.
    It is too bad that you and Flying White Dutchman live so far apart, as you could learn a lot just by helping him finish his project.
    2 people like this.
  9. NortTexSalv04Prius
    915
    115
    You are correct several have blown aka exploded a HV pack.He also stated when charging that only with about 1.5-4.5 amps and timed charge cycle to 1-2 hour period. I think with smart chargers that set it and forget it will not work in this application.
  10. NortTexSalv04Prius
    915
    115
    FWD has already arc one of his HV relays ....
    If any thing I would seek you out in NM
    I do see charging system as obstacle....
  11. NortTexSalv04Prius
    915
    115
    Nimh charger
    300 deposit plus wait list and sign waiver
    675 plus wire harnes plus ship then hookup
    This charger is base off a Honda Insight IMA setup... thank for link seilbert
    [ame=http://www.youtube.com/watch?v=K-05W8LU9Mo&feature=autoplay&list=ULthONA4g96Y4&lf=channel&playnext=1]GC chapter 2 the control panel - YouTube[/ame]
    http://99mpg.com/Projectcars/gridcharger/
