DIY HCAC bypass valve P1436 code
Discussion in 'Generation 1 Prius Discussion' started by h3hybrids, Nov 22, 2010.
  1. h3hybrids
    h3hybrids New Member
    Philadelphia, PA
    2001 Prius
    Anybody figure out how to fix the HCAC bypass valve P1436 code?
    US TSB EG015-02
    Aug. 2, 2003, M.I.L. "ON" P1436-HCAC Bypass Valve Improvement, 2001-2002 Prius.
    (road salt may cause issues with valve. possible fix is to replace the Front Exhaust Pipe Assembly if any shaft binding is evident.)
  2. Patrick Wong
    18,200
    6,472
    1. Apply high temp lube to the valve's shaft. The part gets quite hot so the lube may burn off after a while.
    2. Replace the catalytic converter (incl the HCAC chamber) with a new part.
