DIY HEADLIGHT REMOVAL AND HEADLIGHT BLACKOUT GUIDE AKA Baked Headlight
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 3rdgeargrndrr, Sep 1, 2012.
  1. 3rdgeargrndrr
    3rdgeargrndrr New Member
    I didnt see a DIY guide on removing the headlight, or maybe I didnt search enough, but here it is. I also didnt see a blackout guide either, the chrome was just getting to me, I liked the blackout look a lot better. and some cars colors schemes would be much nicer with modified headlights. Lets see them!!
    a headlight removal guide is helpful if You need to access the back of the headlight for HID install (installing a ballast)
    I am not responsible for you screwing up your car following this guide. I tried to be as thorough as possible. Please read and follow all instructions given. Use Common Sense. Nothing is too hard to perform in this guide. As in any blackout guide, there is a possibility that condensation may occur in your headlight. Pictures taken with iphone, I will try to answer questions politely but I dont guarantee my level of patience if its already been covered. Mods done to 2010 Prius 3. Should be same for all Gen3 Prius.
    Tools:
    3x Flat head screwdriver (3) you will end up destroying 2-
    10mm socket
    Phillips Screwdriver
    Primer,
    Paint,
    Oven,
    Oven mitts
    1) Open the hood, set the parking brake.
    2) Locate the side of the bumper near the wheelwell. You will see a 10mm screw and a flathead screwdriver clip. Remove the screw and turn the flathead screw to the vertical posn.
    Repeat on opposite side of bumper.
    3) Under the bumper, you will see a plastic push pin . pop this out with a flathead screw driver.
    4) Pull the bumper away gently, there is a bracket that will have tabs. You wont damage these tabs if you pull gently, they will pop out.
    5) You will see a 10mm bolt to the front on the bumper bracket, remove this,
    5) in the front of the engine bay, you will see an air deflector. Under are some push pins and 10mm bolts , remove these. Pull the bumper slightly out to give some room to remove the headlight.
    Repeat on opposite side.
    6) Remove the 10mm screws on the top portion of the headlight.
    7) Locate the metal tab to the medial portion of the headlight. Holding in the headlight.
    Bend this up with a flathead screwdriver. (It is the tab in the middle of this picture)
    8) While pulling the bumper away, Pull the headlight straight out. It should pull free quite easily with a little wiggling.
    (Sorry no pic)
    9) Disconnect all connections to lights. Remove lights and keep them in a safe place. DO NOT TOUCH THE LOW AND HIGH BEAM BULBS.
    YOU ARE NOW DONE REMOVING THE HEADLIGHTS.,
  2. 3rdgeargrndrr
    10) Preheat oven to 215 degrees. I used an old towel on top of a cookie sheet. Now might be a good time to explain this to wife.
    11) Locate screws on the back of the headlights, remove these and keep in a safe place. There are six or seven of these (I cant remember)
    (Sorry lost this pic)
    12) Place headlight in the oven, try not to let the headlight touch the sides of the oven, just in case. .
    13)”bake” for 10-15 min.
    14) Remove headlight from oven, it should be hot enough that you will need oven mitts. If you can physically hold the headlight with your bare hands it is probable not yet hot enough to pull apart too easily.
    15)Using one or two flathead screwdrivers or a putty knife, start prying apart the clear outer shield from the black housing.There will be black glue all over these screwdrivers which will be very difficult to remove.
    When there is enough space to get fingers in there, use your hands and continue using gradual constant pressure to separate the light. It should be a little difficult pulling it apart. Be careful not to break any tabs and NOT to get any black glue anywhere on the chrome or clear shield as it will be difficult to remove.
    You will now have a black housing with the chrome lighting housing and the clear shield with the bezel attached.
    16) locate 3 screws on the back of the outer bezel. Remove them and keep in a safe place
    17) If you want, you can remove the orange reflector at this point. Remember that there is just chrome under there. And very shiny.
    18) mask any areas you don’t want to spray. Here, I masked off the Orange reflector area. In Hindsight, I should have masked off the Ring surrounding the Low beam projector.
    19) Primer the bezel housing. Remember not to go too heavy, 2 – 3 light coats should do it, each coat, I sprayed from a different angle to get the whole housing covered, there are a lot of nooks and crannies in this housing. Let dry 45-60min. wet sand here if you wish.
    20) Paint the housing any color you wish. I chose gloss black, which is standard fare I think. Again 2-3 light coats and then one heavy coat should work, let dry, preferably overnight. Member sfv41901 has suggested baking these bezels again, just to ensure the paint is cured.
    21) Replace the outer housing to the clear shield. Preheat oven to 215 degrees.
    22) Place the shield back into the black light housing. This step requires a little maneuvering. I found it easiest to work from the “front” the light to the back. Align up all the tabs. Press as hard as you can to get the headlight aligned correctly.,
    23) Bake headlight again for 10-15 min. to soften the glue. Same directions as above
    24)After removing the headlight from the oven, again, squeeze the headlight together as hard as you can to get the headlight resealed and aligned.
    Replace the screws, to tighten, Again, I found it easiest to work from front to back, and retighten screws often. Ensure that they are aligned and tight.
    25) Reassembly and replacement of headlight, is opposite of disassembly and removal.
    Good luck and show off them headlights!!
    Dylan Doxey likes this.
  3. 3rdgeargrndrr
    Let the flaming commence!! :LOL:
  4. PriusCamper
    PriusCamper Senior Member
    11,190
    4,559
    Pacific Northwest, USA
    Nice work!!!
    Any way you could add more of that goopy black sealant stuff to be sure you don't get leaks?
  5. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    Nice write up. :)
    It would really help if you went in and edited the pics with some arrows or circles around the fasteners in the pics for added clarity. ;)
    Do you just have a yellow vinyl overlay on your signal/foglight lenses?
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Looks good!
    The headlight removal is basically the same as the GenII. Thanks for doing it for the GenIII!
    Prouscamper, the sealant is good enough to reuse in most cases and you shouldn't have any leaks after taking them apart and putting them together once or twice. Beyond that you should buy more sealant. TheRetrofitSource sells it for pretty cheap.
    PriusCamper likes this.
  7. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    Thanks for the guide. I used this to swap out my lights today. Very useful.
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Looks really good.
    I do have one suggestion:
    I would bake the headlight bezel (the part u painted) in the oven by it self for a while just to bake cure the paint. If it not done the paint can release fumes inside the headlight causing a smoky film on the lens when the sun beats down on it. This has been a common issue over on hidplante. If this happens it's really hard to get the film off the lens.
    Dylan Doxey, F8L and PriusCamper like this.
  9. 3rdgeargrndrr
    Yes, yellow vinyl overlay
    So I removed the high beam bulbs and yes, I noted a faint paint smell still. I will leave them out for a week or so to let the paint dry some more.
    added suggestion to the DIY guide, thanks for the headsup
  10. Joshua
    Joshua Junior Member
    56
    Atlanta, GA
    does the lack off chrome hurt the output of the lights? meaning before the light would reflect off the chrome, now all you get is what comes out the projector.
    if that makes any sense...lol
  11. pholife
    pholife Junior Member
    57
    hb
    looks great and thanks for sharing...what wheels do you have?
    thanks
  12. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Not really. There is very little useful light that comes off the chrome.
    Joshua likes this.
  13. Joshua
    56
    Atlanta, GA
    ok thanks, then I will be doing this mod once I get mine out of the shop :(
    also going to tint the tailights and I cant decide if I want to paint the hub caps or just take them off. they are there for a reason, and I dont really like the stock wheels all that much.
  14. 3rdgeargrndrr
    They are called Velox Flight. U can find them at costco or discount tire/. Americas tire. Pretty much BBS knockoffs.
    Just make sure you DONT paint the rear bezel and you will be fine. You DO need chrome reflector for the high beam.
  15. JAYSONE
    JAYSONE Junior Member
    83
    Los Angeles
    I'd like to do this mod, but there is no way I am able to do it.
    Is there any aftermarket headlights available that are already blacked out that I could just purchase instead? I'd rather take my OEM off and save them, than risk ruining them due to my lack of skills.
    If I ever decide to sell the car I would like to be able to put everything back to stock anyways.
    Thanks in advance.
  16. JAYSONE
    83
    Los Angeles
    duplicate. mods please delete
  17. peterjmc
    917
    188
    Clarksburg, MD
    I've been wanting to see what the LED headlights would look like blacked out. I just picked up a cheap LED headlight (less than $100 :) ) to play with. I'll post pics in this thread when I'm done.
    bonchang likes this.
  18. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    here....
  19. alphaprius
    alphaprius Junior Member
    Southern California
    Nice work. Thanks for the DIY. I might do this in the near future
  20. eunique
    eunique Member
    66
    89
    US
    Thanks for this...I want to try it..but question on oven baking... Did you use oven inside the kitchen? And is it safe to use same oven that you use to bake food in?
    Or do you need a dedicated oven outside?
    Did you have nasty plastic smell inside your kitchen after?
    Sorry for all the questions...just don't want to get trouble with the "boss."
    A0001 ?
    sfv41901 likes this.
