DIY: Inverter Pump Replacement (10-15 Prius)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Mar 25, 2019.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Due to my vehicle’s mileage (186K+), I elected to proactively replace the inverter water pump before it fails and causes irreversible damage. I used an Aisin WQT001 pump from RockAuto.
    The service manual calls for completely removing the inverter assembly but this is not necessary.
    There are quite a few different ways that you can perform this repair, but I elected to “reposition” the inverter assembly in order to gain access to the inverter pump hose and hose clamps. You can reposition the inverter after removing six 10mm bolts, disconnecting the low-voltage wiring harnesses and removing the air intake tube and box. Use a block of wood to keep the inverter secured.
    The inverter pump is secured by three 10mm bolts; two are accessed from the bottom and one is accessed from the top. Note: it MAY be easier to keep the inverter pump secured to the bracket and to just remove the entire bracket with the pump still attached. I chose to remove the pump w/o removing the bracket, but I think it was the more difficult route. Also, the electrical harness plug may not come off of the pump; I recommend keeping the plug attached and removing the inverter pump with the sub-harness still attached. Once the inverter pump is out of the car, you can try different means for removing the electrical plug.
    The labor time for this job is 3.4 hours and even with a lot of pondering and trying different ways of disassembly (this was my first time), it only took me about two hours. If I had to do this again, I can probably do it in a lot less time.
    Hope this helps.
    #1 The Critic, Mar 25, 2019
    Coots, Don Tibbetts, bisco and 9 others like this.
  2. Patrick Wong
    18,200
    6,500
    Thanks for posting about your experience.
    How about a photo of the original vs. Aisin replacement coolant pump? Any differences in appearance?
    What was the Aisin pump price from RockAuto?
  3. The Critic
    3,193
    2,330
    CA
    Unfortunately I did not take side by side photos of the two pumps. But the Aisin pump was Made in Japan and visually similar. Rockauto’s price was $81.79.
    RMB, Raytheeagle and Patrick Wong like this.
  4. Boomer Prius 2010
    Boomer Prius 2010 New Member
    Panama City Beach FL
    I found your notes helpful as I just replaced my Inverter Cooling Pump on my 2010 Prius.
    4 hours. I would estimate 2 hours to do it again - but such is the first time you do something.
    Helps (almost impossible without) to have a helper for certain things.
    After removing inverter mounting bolts and blocking up the inverter (to the rear) You need to remove the one bolt facing up from above and the hose that goes to the pump outlet (Port facing straight up - or axially).
    Getting the factory el cheapo hose clamps off can be a major challenge. Large needle nose vice grips are very helpful.
    I found it easier with the pump loose so I could vary the angle on the hose clamp. (Took out all 3 bolts. One from above, two from below).
    You will need to bend the bracket from below to get the pump out the bottom. You'll need to compress and move the radiator hose as well.
    It's tight but doable. Get the vehicle as high as practical. I used ramps and it was tight but doable.
    Connector to pump maybe quite stubborn to get off (plastic hardened). I took the next connector back off and left pigtail on pump.
    Much easier to do on bench once I get pump out.
    Start reinstall by putting in the single bolt from above to locate the pump. Do not tighten all the way down.
    The bracket that mounts to pump and provides a nut for the two bolts that mount from the bottom is a real bear.
    If I had to do it over, I would have tied wrapped it to the pump, mounted the pump, and then removed each tie wrap in turn and replaced with bolts.
    I fiddled with the bracket for 90 minutes before using a magnet to hold it in place from above (held by a helper). I could then hold the bracket down from below as I threaded bolts into the bracket. What a goofy design. I think Toyota hired some ex-GM Engine Engineer for this one :)
    Easier than removing the Inverter ? Probably a wash the first time. If I ever had to do it again, this method will be faster.
    Hope this helps,
    Boomer
    Mendel Leisk, StarCaller and CR94 like this.
  5. paperplate
    paperplate New Member
    2014 Prius Plug-in
    I had some noise which sounded as if the inverter pump was going bad. Purchased the Aisin from Rock Auto, as well as an Aisin engine water pump, as the car has 160k. Installed both today using the 2x4 inverter tilt up method, but missed connecting the inverter water pump bulkhead connector. Tried to start the car, but was presented with the red triangle of death. Turned the car off, and realized that there was a pump connection issue. Unfortuantely, after connecting the bulkhead connector, I am still getting the red triangle. Torque OBD app indicates Inverter rpm at 500 (not the normal 3350 rpm). Anyone ever run into this? If a P1314A code is thrown for a missing pump, will the ECU stay in hybrid failure mode until the code is reset? I am also am considering the idea that I have a defective new pump.
  6. tallyguy
    tallyguy New Member
    Tallahassee
    Was driving my 2010 Prius IV in town when I got the check engine light, yellow triangle, ABS light, and "Check Hybrid System" message. The car went into limp mode so I was able to get to my friend's house. Scanned the codes and got P0A93, P0A94. Did some research and was pretty sure it was the Inverter coolant pump. So I bought the Aisin from Rock Auto and went about replacing. Man, this was a PITA! I did the "tilt the inverter back" method and was able to get the old pump out from the top by myself. As noted previously, the biggest difficulty with this job is getting the top bracket back on once the new pump is in place. I tried the telescoping magnet with no luck. Then my friend made the brilliant suggestion to lash the bracket to the pump using rubber bands prior to putting the pump in place. I was able to do that and get the top bolt secured. Then I was able to get one of the bottom bolts started into the bracket being held to the pump via rubberband. Once one bottom bolt was in place, I cut the rubberbands and was able to get the second bottom bolt in place. Unfortunately, once I hooked everything back up, the P0A93 and 94 did not clear. The old pump seemed to run fine when 12 volts applied but had a bad bearing rattle when it spooled down. So, probably a good thing I replaced it. I tried clearing the codes with my ODB (Bluedriver) app but they came back immediately. Not sure if there is anything else I can do at this point other than take it to a shop. Any suggestions would be great.
  7. mjoo
    mjoo Senior Member
    1,153
    1,326
    Michigan
    Did the new pump run despite codes? Do you see turbulence in the reservoir?
    How many miles?
    SM-A536V ?
