DIY replace ac compressor?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nate16, Apr 17, 2017.
  1. nate16
    nate16 Junior Member
    40
    peabody, ma
    It's getting hot out and I've had a dead AC compressor since I bought the vehicle. Anyone have any guides to DIY this? Not trying to spend 2-4k at the dealership.
  2. mjoo
    mjoo Senior Member
    1,127
    1,317
    Michigan
    I've had a friend work on his A/C system before. He first had the shop pump out the refridgerant and oil. Then we worked on replacing what was leaking - the dryer assembly.
    If you don't know what's leaking You'd need a mechanic add the special die first. Make sure it's compatible with the Prius's compressor oil. From what I read on here a completely new system would cost thousands in time and money.
  3. TPK
    TPK New Member
    Australia
    i-Tech
    To get to the compressor and replace it, does the dash need to be removed?
    My dealer has told me that it willtake at least 12 hours in labour to replace the compressor.
    Thoughts?
  4. ChapmanF
    15,662
    The compressor isn't located in the dash.
    Any chance the dealer could have been talking about the evaporator?
    -Chap
  5. Mendel Leisk
    38,735
    No offense, but if you're not sure where the compressor is, I'd at least call the dealership and get an assessment and quote.
    I wouldn't take this on myself, it requires specialized equipment, Repair Manual info.
  6. TPK
    TPK New Member
    Australia
    i-Tech
    Apparently the dash has to be removed to replace the TX valve? 12 hours just seems excessive to me? But that’s just my opinion.
  7. ChapmanF
    15,662
    TPK wasn't the OP. Tagged on to the thread....
  8. Mendel Leisk
    38,735
    Ah woops. Apologies to @TPK . :oops:
