Do 12v Accessories Drain Traction Or Starting Battery When Prius "ON"?
Discussion in 'Gen 2 Prius Main Forum' started by jyl, Jul 6, 2009.
  1. jyl
    jyl New Member
    84
    Portland
    Hey all, quick question.
    When the Prius is turned ON, and a 12v accessory is plugged into the 12v accessory plug outlet (either one), does it drain the big traction battery, or the little "starting" battery (or do we call it the booting-up battery)?
    I have a 12v thermoelectric cooler that I want to take camping and leave plugged into the Prius. It draws 4 amps. I imagine the traction battery can deliver 4 amphours x 24 hours no problem, but I know the starting battery would be drained quickly.
    We're supposed to go camping for a week in the Westy Vanagon tomorrow. But it just blew both head gaskets. So, in addition to making me $2K poorer, we're scrambling to repack for a Prius camping trip. Two adults three kids - not that crazy, we'll pack light, carry a luggage pod, and there's not a ton of actual driving involved.
  2. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I've run the electric cooler in a non-Prius vehicle and been OK for a couple hours but killed the battery after 5 or so hours. I've heard the Prius 12v battery is not very big so I'd be cautious on this. I'm sure others here can provide more details than I can.
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    blew head gaskets?.. in your prius?... really?...
    you CAN run it off the 12v battery.. but it Really is easier to just leave the car in READY mode... so the big battery can feed your 12v line.. and cycle the engine on and off when necessary. expect to burn about a gallon every 10 to 12 hours... otherwise the 12v battery is 20 amps ( i faintly recall )... so... without droping below a decent starting voltage.. you'll probably only get an hour or two before forced to start the car.
    so... yeah.. leave it in READY mode.
    i used my car as a generator while i had a spark plug failure.. the car was not happy to be running but was functional.. also burnt about 2x the amount of fuel.... so worse case scenario... you'll just waste a little more fuel.
    it beats using a generator since they are loud.. and constantly on.
  4. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    He didn't blow the head gaskets in his Prius, he did in his Westfalia Vanagon. Since he can't drive it, he wants to take the Prius.
    I'm not sure, but I would suspect with the power ON in the accessory mode, it would engage the hybrid battery.
  5. V8Cobrakid
    3,790
    152
    uhhh... you don't want to drain the hybrid battery unless the engine is able to kick in to recharge it... it can't turn unless it has a charge... so.. keep it in ready mode. a 12v battery requires a jump to start the car. a drained hybrid battery requires a flat bed truck and a painful trip to your toyota dealer.
    in ready mode..... your battery gets used... but the engine can turn on and recharge it. plus.. accessory mode has a timer.. er.. does in my gen II. 30 mins i think.
    yes.. the car draws more power in ready mode... something like a couple hundred watts.. but... it's either fuel burnt or the chance of getting stranded.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I don't think the OP's question has been answered: If you have the Prius in Ready, 12V power is supplied by the HV battery. The engine will start as necessary to charge the battery as long as the shifter isn't in N.
    Tom
  7. jyl
    jyl New Member
    84
    Portland
    Okay. Leave the car "ON" (otherwise called "Ready") and the traction battery will supply the 12v battery, the ICE will run as necessary to keep everything charged. Thanks!
    Looks like we will all fit in the Prius. Minus a few non-essentials.
  8. Patrick Wong
    18,200
    6,472
    The Prius has several potential power states that it can be set to. I think it would help if we can be precise about those power states:
    IG-OFF where the vehicle is powered off.
    ACC-ON where the MFD is on, instrument panel lights are off, and you can power up the stereo. The auxiliary 12V sockets are active.
    IG-ON where the MFD is on, the instrument panel warning lights are on, and you can operate all electrical accessories including the power windows. Electrical current drain is quite high in this mode, do not leave the Prius in this condition for any lengthy period of time.
    READY where the car can be driven. In this mode the DC to DC converter is providing 13.8VDC to the 12V bus, and keeping the 12V auxiliary battery charged.
    Starting from IG-OFF, to switch to ACC-ON, press the POWER button once without depressing the brake pedal. Press the POWER button again without depressing the brake pedal to switch to IG-ON. Press the POWER button again to switch to IG-OFF.
    Depress the brake pedal while pressing the POWER button to switch from IG-OFF (or the other ON modes) to READY.
    The capacity of the 2G 12V auxiliary battery when new is in the mid 30 AH range if you have the Smart system, or 28 AH if you have a base model. The battery should not be drained below 50% capacity in the interest of maintaining a long service life. Hence if the OP wants to use a 4A load while the Prius is ACC-ON, the vehicle should be left in that state no more than four hours assuming the 12V battery is fully-charged.
    If the OP leaves the Prius READY, then the only operating constraints are the amount of available fuel, the noise produced by the ICE, and the extent to which the vehicle is emitting hydrocarbons into the campsite.
    4 people like this.
  9. jyl
    jyl New Member
    84
    Portland
    Thank you everyone and especially Patrick.
    I just got back to internet access after a week camping on Vancouver Is. Yup, a family of four plus an extra kid can go tent camping for a week in a Prius, with a 12 cu ft pod on top. The rear wheels may be jammed up in the wheelwells and every last cu inch may be filled, but it can be done.
    So, the 12v thermoelectric cooler worked okay. I left it plugged into the Prius accessory outlet most of the time, the car occasionally started up and ran for a few minutes, quieter than any generator and inaudible from any other occupied campsite (it was pretty empty), and the cooler kept milk, cream, chicken, beef, veggies, cheese, etc etc nicely refrigerated. We drove around to see the sights a lot, then the car was running anyway. At bedtime, I unplugged the cooler, nighttime temps were cool enough.
    Some info on these coolers, in case anyone is interested. They use a Peltier element with fan and heat-sink, draw about 4 amps, and given time will get the cooler interior to appx 30-35 F below outside ambient temps. So, if its 65 F the cooler will be about freezing. But it helps a lot to load it with stuff that is already cold.
    However, these things really are not designed well. The main problem is they run continuously, none of the affordable ones have a thermostat. Thus they use a smaller Peltier than they could, and even so they draw far more amp-hours than they need to. I plan to modify this cooler with a thermostat circuit and a more powerful Peltier. If that works, I plan to address the second problem, which is that they aren't the best insulated coolers, at least mine is not.
  10. jyl
    jyl New Member
    84
    Portland
    And when I get home tommorrow, I get to figure out what to do about the Vanagon. I think an engine swap is likely.
  11. Patrick Wong
    18,200
    6,472
  12. jyl
    jyl New Member
    84
    Portland
    Yes, it is a common problem. Too common. This will be the third set of head gaskets and potentially the third set of heads in 138K miles. The wasserboxer was not VW's shining moment.
    A zero-mile Ford Zetec motor for $1300 is looking tempting. Shame about the $4200 for the conversion parts.
    It is more popular to swap for a Subaru 2.2L or 2.5L motor, but with 50K-100K miles those cost what the Zetec costs fresh from Ford. And the conversion bits are just as spendy.
  13. danaceman
    danaceman New Member
    marlton nj
    Thanks, very informative. I had 2 problems last year starting my Prius. Two were after leaving on Dome lights over night. The first was a deeper discharge by leaving lights, radio on, and doors open.
    I assume that the starting battery ran down, and could not be charged because the car was off. But he dome lights can't be much of a load. 1/2 Amp???? Battery is 4 years old only. Maybe it was damaged from my first deep discharge???
  14. qbee42
    18,058
    3,074
    Northern Michigan
    Four years is a normal service life for a 12V battery in a Prius. The 12V batteries are fairly small, and fully discharging one takes some of its life.
    When you say "could not be charged because the car was off" do you mean that it could not be charged by the car? In that case, no, it could not. You should be able to recharge using an external charger attached to the battery or jump points under the hood.
    Tom
  15. jdenenberg
    jdenenberg EE Professor
    3,851
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    One additional piece of information (I have used one of these coolers for over 5 years in my 2004 Prius). It pulls about 4 amps (50 watts) from the 12v circuit which is not a problem for short time intervals in ACC mode as the 200v traction battery reliably has about 200 to 500 WattHours of energy available. Longer times (more than a couple of hours) do require that the Prius be in ready mode and in park (not neutral) or driving so that the ICE can supply the requires energy.
    A Prius ICE averages about 20-30 hp (1.5 to 2.2 kWatts) of output when cruising at highway speed. The 50 watts used by the cooler is about 2.5% of that output so you should expect to see a 2.5% reduction in MPG (1 MPG) while running the cooler on a trip.
    JeffD
    CATHIE B likes this.
  16. Patrick Wong
    18,200
    6,472
    The capacity of a new Prius 12V auxiliary battery is around 35 Ah. Since your battery is four years old its capacity has deteriorated, and might be 15-20Ah, or less by now.
    How many lights were on? The front ceiling fixture has three lamps while the rear has one and the hatch has one. The front doors have courtesy lamps as well.
    Suppose two 7W lights were on. That will draw ~1Ah. If you left the lights on from 6 PM until 7 AM the following day, that would be 13 hours or 13Ah. If you discharge the battery more than 50% of its capacity, it may not recover.
