Do 2020 models have auto engine shut-off?
Discussion in 'Gen 4 Prius Main Forum' started by upplepop, Apr 27, 2020.
  1. upplepop
    upplepop New Member
    Philadelphia
    2020 Prius
    XLE AWD-e
    There was lots of news in mid-2019 about Toyota adding an automatic engine shut-off feature to most of their 2020 models. Does anyone know if this actually got implemented in the 2020 Prius -- specifically the AWDe?
    I am considering buying a 2020 AWDe XLE for camping, and I'm really interested in sleeping in my vehicle and leaving the engine on overnight for AC. I'm wondering if this is no longer possible with the newest models.
  2. Tideland Prius
    16,125
    If you mean the car shutting off completely, I'm not aware of that. My understanding is that "auto engine shut-off" is when the car is running and comes to a completely stop, the engine will shut down to save fuel.
    In that case, the Prius has always had this (It's a hybrid after all).
    When camping, the engine will cycle on/off as needed to keep the hybrid battery from draining. As long as there's ventilation to reduce the risk of CO build-up in the interior, it should be ok since I've heard of people doing that set up before while camping.
    *Disclaimer: It's your call to run the vehicle at night while sleeping. I take no responsibility for any action you take.
    kenoarto and krmcg like this.
    49,371
    he means the whole car shuts off after a certain amount of time with no driver input as a safety feature. there is a thread on this somewhere, and a lot of complaining from campers, but i haven't read anything recently.
    should be in 'new car features'?
  4. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Welcome, @upplepop. In a hybrid forum, "engine off" is not anything like "car off." So @Tideland Prius' response is what mine would be, too. The Prius (and all hybrids) has always shut off the engine when the car stops except in special situations.
    I guess we need some clarification as to exactly what you mean. I have never seen any mention in Toyota's literature about them shutting off the whole car. If they have started making the entire car shut off automatically, that's going to tick off a lot of campers.
    kenoarto likes this.
  5. upplepop
    upplepop New Member
    Philadelphia
    2020 Prius
    XLE AWD-e
    Bisco was correct. I'm referring to news articles that came out last year about a brand new 'feature' (never before implemented by Toyota) that would automatically shut down the engine after being left in park for an extended period of time. This was done to prevent CO2 poisoning from cars being left on in garages.
    They made the announcement in June, 2019, but details were vague. I tried to post some links to news articles, but my PriusChat account isn't permitted to post links yet. But you'll find the news articles if you Google "toyota automatic engine shut off". I wasn't able to find any updates to how this was implemented.
    jerrymildred likes this.
  6. bisco
    49,371
    found it: @Johnny Cakes
    "2019 model: End of comfortable Prius camping"
  7. jerrymildred
    11,508
    14,109
    Tampa, FL
    I had to check a couple articles before I found something specific to hybrids. Here it is: Toyota Tech Will Automatically Shut Off Engines, Apply Parking Brakes
    The relevant paragraph says, in part:
    It seems to me like it would be a simple matter for them to program a "camping" override response to the first warning. I'll bet they don't. For non-campers, it sound pretty nice since there are so many stories here of people forgetting to shut off the car.
  8. El Dobro
    El Dobro A Member
    6,978
    3,213
    My Volt has it. The car shuts down after about two hours. IIRC, someone found an override is leaving it in neutral. Possibly this may work on the Prius.
  9. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    Unfortunately, the HV battery on the Prius doesn't charge when the car is in Neutral. That would preclude using that for camping.
    jerrymildred and fuzzy1 like this.
  10. El Dobro
    El Dobro A Member
    6,978
    3,213
    So, if you hook up an inverter to the battery to run equipment, the ICE won't come on to charge the traction battery back up anymore?
  11. davecook89t
    1,057
    789
    Four Touring
    Not in Neutral. In fact, there have been many instances reported here where the HV battery was drained simply by putting the car in Neutral to go through a push-through car wash. I don't know the engineering that required designing the car that way, but that has been true of all generations of the Prius - charging occurs in P, D or B only, not in R or N.
  12. El Dobro
    El Dobro A Member
    6,978
    3,213
    Oh well, then it looks like camping in the new Prii will require powering the car up every two hours.
  13. krmcg
    2,592
    2,390
    Whittier, CA
    Maybe Carista could take care of it?
  14. fuzzy1
    10,149
    Exactly, when in Neutral.
    One reason is the need for an emergency disconnect of power flow to the drive wheels in case of an uncommanded and uncontrollable engine surge or runaway.
    Back in the old days, there were various mechanical failures (mostly in throttle mechanisms) that sometimes caused full power engine runaways. The immediate solution was simple, just press the clutch pedal to disengage power. The engine might self-destruct, but it won't force a life threatening crash.
    Modern electronic controls have greatly reduced these engine runaways, but not eliminated them. Most of the remaining cases are now known to be pilot error, pedal misapplication, but gremlins within the machine are not entirely removed, or at least no proven so. Therefore some form of power flow disengagement is still required:
    -- Manual transmissions: Press the clutch and take it out of gear.
    -- Automatic transmissions: Shift to Neutral, which takes it out of gear.
    -- Toyota HSD which has no gear shifting or complete mechanical disconnect: Shift to Neutral to kill the fields of all the Motor-Generators, rendering them inert.
    #14 fuzzy1, Apr 27, 2020
  15. davecook89t
    1,057
    789
    Four Touring
    I wonder if anyone has tried blocking the wheels, engaging the emergency brake and then putting the car in Drive and going to sleep for the night. The ICE would come on more frequently than it would in Park, but I expect it would still be off most of the time. Would that violate any local traffic laws? Would it cause the transfer case to overheat? It seems a shame if the Prius could no longer be used for camping because the car completely shuts down after a period of time in Park. I haven't seen anything in Carista that might override something like that.
  16. PianoBench
    PianoBench Member
    145
    91
    San Francisco
    The car also automatically shuts off the engine and radio in the vehicle in the event of a crash! Haha here is proof.... my car totaled video from 2018...
    edit: messed up the date.
    #16 PianoBench, Apr 28, 2020
    alanclarkeau likes this.
  17. davecook89t
    1,057
    789
    Four Touring
    :eek:, he didn't even hit the brakes, must have been totally spaced out, just kept right on cruising into the back of your car. Seeing something like that makes me want to avoid going anywhere. That's one instance where Dynamic Cruise Control on his vehicle would have saved an accident.
    robsnyder20 likes this.
  18. PianoBench
    PianoBench Member
    145
    91
    San Francisco
    The car held up really well in an accident. Because of the super low rolling resistance tires, the entire car just spun and the impact felt less than a sudden sharp braking attempt. The vehicle held up really well in that accident. I didn't even hit any panels. I was just held in the seat by the seat belts.
    If you are scared to be on the road! You should see my stash of dash cam videos. Tons of shitty drivers out there. The worse ones will tailgate you just because you are in a Prius. And if you drive a red one like me, it just makes you a bigger target. =P
  19. bisco
    49,371
    has anyone actually established whether or not toyota has added this 'feature'?
    jerrymildred and davecook89t like this.
  20. jerrymildred
    11,508
    14,109
    Tampa, FL
    I can't find it on their website -- only in 3rd party magazine articles.
