do eibach springs settle?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by StarCaller, Jun 9, 2014.
  1. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    I installed a set of eibach springs last saturday & was just wondering if they're going to get a little bit lower in the first 1000 miles or if they pretty much stay like they are now/
  2. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    Most springs settle the first time you drive them...
    Tony D likes this.
  3. StarCaller
    1,246
    697
    not true /
    on my gto with a pedders suspension package it took like a 1000 miles until it reached the final height (even if the company told me that they are the highest quality & don't settle) /
  4. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Generally speaking, you'll see the final height within 1000 miles. All springs settle.
  5. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    Wow. I've never noticed, and I've lowered hundreds of vehicles. (Used to be a mechanic)
  6. StarCaller
    1,246
    697
    how many of the vehicles did you measure later on?
  7. burstaneurysm
    469
    144
    Chicago, IL
    It's usually a negligible amount. Honestly, settling is rarely visible, but it can affect alignment, so it's better to wait for an alignment.
    Unless the springs are low quality, any settling should be a a couple mm, at best.
  8. RightOnTime
    RightOnTime Senior Member
    754
    1,624
    183
    Kidnapped in OC, CA
    Congratulations on your purchase of Eibach springs!
    Eibach springs will not settle much. Within 5 miles of driving everything should be settled in.
    In the old days, cheap springs used to sag after a while, but Tein and Eibach make quality product so there's really no need to wait. They do recommend to re-torque the bolts after 500 miles.
    I hope that answered your question :D
  9. StarCaller
    1,246
    697
    update:
    7.000 miles later & they didn't settle at all/
    nothing/
    I measured every week on the exact same parking location & they didn't settle even a 1/16 of an inch yet/
    on one hand I was hoping that they at least settle a little bit, on the other hand it shows that it's a quality product which probably doesn't need to be replaced in a couple of years because the springs are sagging////
