DO GEN III SOLAR PANELS HELP MPGs?
Discussion in 'Gen 3 Prius Fuel Economy' started by doc3osh1, Nov 3, 2009.
  1. doc3osh1
    doc3osh1 New Member
    New York
    I scanned through all the MPG threads and did not see this answered, so forgive (or redirect) me if it's been covered:
    I'd like to see a somewhat complicated comparison:
    Two 2010 Prius', one with the solar-panel package and one without, each driven for at least 1 full tank of gas (preferably for a few tankfulls) in three locales:
    A. In Arizona/ Texas/ Nevada region: Sunny but hot enough to require Air Conditioning (which may reduce MPGs)
    B. In Northeast (not that sunny but not hot either-- A.C not needed)
    C. in Boulder or some similar place where it is extremely sunny but cold
    Of course ideally the same drivers would drive the cars in all three places so the driving habits would stay the same, but in any event the point is to see if the Solar Panels are "worth it", and whether they are worth it for some people (some regions) but not others... I'd imagine Toyota might find this info somewhat useful, though I have no doubt their main reason for including the panels is for marketing cache.
  2. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    I realize this won't be the technical answer you want, but since you're unlikely to find someone with two other wise identical cars to drive to all three locals to test this for you, I'll just throw in my engineer's gut and personal experience from having the panels.
    They have some minimal effect on fuel usage by reducing AC usage on hot days. But Prius AC is already very efficient, so not a big effect. They do keep the interior quite tolerable though, even on hot days, so I would say they are more than just "marketing cache".
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Now see, having lived in both Elko NV (where it snows ten months a year) and Greenwood MS, my question would be "Does it cool the car when off as well where it is humid as it does at the same temperature when it is arid?"
    Since solar only runs when the car is off, driver comfort is the only mileage effect.
  4. rachaelseven
    616
    212
    Adams, MA
    By exhausting some unwanted heat when the car is off and keeping the interior cooler, the panel undoubtedly reduces the load on the AC somewhat, since much less
    AC needs to be used to be used to bring the cabin down to a tolerable temperature. Small effect though, in the grand scheme, and I doubt you could even control the other variables in the experiment well enough to measure the effect.
  5. doc3osh1
    doc3osh1 New Member
    New York
    So here is the related question: I have heard that most sunroofs add a couple hundred pounds to the car due to the motor (though that seems like an unnecessarily heavy motor...). Since the solar package is only on models with the sunroof, does the extra weight negatively impact MPGs? (This may seem like a "picky" question, but I'm sure some Prius buyers have debated whether to get the package with the bigger (sportier looking but higher rolling resistance) wheels, and opted for smaller wheels due to fuel economy concerns...)
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Add weight to your car and what is the effect on fuel consumption?
    Add that weight to the roof and what happens to cornering speeds and body roll?
    Add both effects and you have a heavier car with more body roll so you need to go slower around corners and accelerate for longer after each corner.
    It is my belief that any gains from reduced AC use are well and truly offset by the added weight on the roof. I suspect the sunroof raises fuel consumption.
  7. doc3osh1
    doc3osh1 New Member
    New York
    How hard would it be to find out the weight difference between the solar package and non-solar package Prius?
  8. yadax3
    yadax3 Member
    237
    22
    Northern Nevada
    Don't forget to check out the way cool (IMO) moon roof that comes with the solar package. It's much more versatile than the one I used to have on my Honda Accord, so I tend to use it quite a bit.
    BTW, from what I've read on these forums I'm doing just fine with my MPG as compared to others. I average 48 mpg and I'm certainly not a conservative driver. When my husband drives my car he usually gets about 52 mpg, and harrasses me constantly about it.
  9. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Do a search, this question was beat to death 2 months ago. And to answer your question the solar roof does not very much weight to the car maybe 40-50lbs if that. So leave one 7 yr old at home and it comes out even.
    Or take the hit of a couple of tenths MPG year round.
    To me the bigger savings or advantage is being able to drive with the roof open and getting fresh air during the more moderate seasons without having to run the AC at all while driving. Yes the cooling while the car is closed is nice too but not as beneficial as having a moon roof to open and enjoy esthetically.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    There are two offsetting factors in play:
    1) The solar panels help reduce the interior temperature of the car, which reduces the initial load on the air conditioning.
    2) The solar panels add weight and create a slightly less aerodynamic roof surface.
    Both of these factors are small. No matter how you factor it, the gain or loss will be minimal. Whether you gain or lose will depend on climate and your driving profile. A Prius driven mostly at low speeds and parked in the hot sun will benefit. Drive at higher speeds in a cold climate and the panels are a complete loss.
    The solar panels are mostly a gimmick. It's a fun gimmick, which I personally like, but you would have a hard time justifying them on any rational basis.
    Tom
  11. yadax3
    yadax3 Member
    237
    22
    Northern Nevada
    I actually agree with this but I love the moon roof. :cool:
  12. qbee42
    18,058
    3,074
    Northern Michigan
    That's okay. If we had to justify everything life would be pretty boring.
    Tom
  13. dogllama
    dogllama New Member
    118
    Los Angeles
    I always forget about the panels until i come back to my car on a particularly hot day and think, "the car is not blazingly hot...sweet!"
    i haven't had great luck with MPG even driving conservatively, but i don't know to what extent the solar panel/moon roof attributes to it. I like the look, i like the functionality and think it's only a gimmick on cloudy days....
  14. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    My gut feeling is that the 62lbs of extra weight offset any minimal A/C load reduction at startup. If you use Remote A/C, you're also borrowing energy that must be repaid later as well.
    When attempting to cool a hot car, the engine is also in it's warm-up phase, which is a less efficient stage. Depending on your A/C setting, the A/C may not need to run at full blast (or near it in ECO mode) for quite as long, and that's where you'd likely see the economy boost.
    What I'm finding now in AZ is that it's still warm enough to heat the interior, but the sun is too far to the south to run the panels at peak efficency. They're also only usable from about 10am to 2-3pm, at which point the fan cycles intermittently w/ the lovely groaning of the motor starting/stopping (DC brushless). I'd like to see an ECU change to allow a lower speed vs. cycling.
    Also worth noting, it's generally cool enough outside for me to turn off A/C and open the roof/crack open the rear windows. The additional drag may offset any solar panel savings early on as well.
  15. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    I'd really like one, but don't want the nav system that you have to buy to get it. By forcing this toyota has moved it from a nice to have, to a slimy sales gimmick to sell overpriced and quickly outdated nav systems.
    I have to agree with the bulk of people, this should not change mpg very much, but living in a very hot place it would be nice to have a cooler car to get into. So not a gimmick, but really not a usefull package. I'd love a hybrid that plugs in and has fans in its sunroof that doesn't require needless nav packages. I'm sure the solar panels are a gimmick to distract us from the fact toyota won't sell us a plug in for a while.
  16. yadax3
    yadax3 Member
    237
    22
    Northern Nevada
    I should probably qualify my previous response by saying I don't really think the solar panels are just a gimmick but I do think their impact is minimal, at least in my light-colored car.
    This Summer I honestly couldn't tell whether the solar panel had been working until one day when I wanted to sit in my car and check e-mail before going into a business meeting. (BTW I think I read somewhere you shouldn't do this) In any case, the solar ventilation system kicked in after a couple of minutes and it did push the hot air around but it doesn't cool it so I became pretty uncomfortable and didn't sit there very long. That said, if I had it to do all over again I would still buy the solar package because, as I said before, the moonroof is awesome.
  17. 2010_Prius_Owner
    2010_Prius_Owner New Member
    110
    24
    Philadelphia
    The solar package will have no real impact in increasing mileage in itself, it only powers fans that bring draw air out of the vehicle. If a non solar car was parked in the summer with windows down, the interior temp would be similar. So saving fuel by not running AC is not a real point. I not having solar may choose to roll down the windows and not run the AC. Compare weight of the solar package vehicle vs one without and that could have a small impact.
    We are talking about vehicle that get between 48 to 62 mpg depending on many factors, mainly how you drive. Other factors are tire inflation, where you drive, are you running heat or AC or non, are Windows down or up and yes the temperature outside can effect temp of battery and effect efficiency.
    How you drive and tire inflation will have the greatest impact on you getting the best possible mpg at any given time.
  18. richsc
    richsc New Member
    59
    Washington DC
    I still think the solar panels could be put to other good uses, such as warming the engine on cold days, etc, which could mean they'd be useful without a moon roof, but they'll have to be more efficient. Looks like 40% solar efficiency is happening in the lab at the moment.
  19. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    The solar panels just don't make enough power to be useful for much, forget heating anything with them or charging anything really. You could trickle charge the 12V battery I'm sure, but that's not very useful is it?
