Do grass lawns help global warming?
Discussion in 'Environmental Discussion' started by burritos, Apr 4, 2007.
  1. burritos
    burritos Senior Member
    4,946
    253
    Waste of water yes. They absorb CO2, better than asphalt no?
  2. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(burritos @ Apr 4 2007, 12:40 AM) [snapback]417482[/snapback]</div>
    Probably depends upon how much energy it takes to move the water from the source to the spigot (assuming that it must be watered to grow well). Then the amount of CO2 released in the cutting of the grass. If the grass is bagged then there's the CO2 cost of the bag (assuming it's plastic) and the transportation of the grass to a landfill (if it's not composted). Could be a wash. It obviously depends on the answers to the above questions (and probably more that I didn't think of).
  3. CMonster
    CMonster Member
    115
    Charlotte, NC
    Better than asphalt, yes. Grass filters CO2, allows rain water to filter back in to the ground, and doesn't contribute to the Urban Heat Island effect. Green roofs are pretty interesting for the same reasons.
    Still, high maintenance golf course type lawns have obvious drawbacks, so I prefer a more natural meadow style lawn.
    If you aren't familiar with Urban Heat Islands, you can read more on Wikipedia here.
  4. SSimon
    SSimon Active Member
    1,426
    N/W of Chicago
    Grass lawns are virtually useless, providing a mono culture that's of no use for wildlife and if they have short root systems, don't do much by way of co2 sequestering. I'm too lazy to research, but I'm wondering if the amount of CO2 sequestered by grass is dependent on the above ground mass of the grass. If we mow the grass to and inch or two, wouldn't less CO2 be sequestered?
    I located this link concerning turf grass and CO2....
    http://www.eia.doe.gov/oiaf/1605/vr01data/chapter4.html
    An exerpt......
    "Exelon (formerly Commonwealth Edison and PECO) reported on its Illinois Prairie Grass Plantings project, in which native prairie grasses are planted on various properties in the utility’s State system. In contrast to conventional turf grass, the deep root systems of native Illinois prairie grasses afford environmental benefits that include reducing soil erosion and downstream flooding and eliminating the need for irrigation, fertilizers, pesticides, and herbicides. In addition, the deeper root systems sequester more carbon dioxide. The project claimed responsibility for the sequestration of 658 metric tons carbon dioxide in 2001. In another project, Exelon reused wood utility poles that are structurally sound in order to avoid the harvesting of trees to manufacture new utility poles. The utility pole reuse project was reported to have sequestered 753 metric tons carbon dioxide in 2001"
    Are turf grasses better than impermeable asphalt, yes. Do they allow for an improved environment, sequester as much CO2, stabilize banks, recharge groundwater effectively, prevent erosion, feed and provide habitat for wildlife, and do their deep root systems help filter pollutants from rain water, no. For the latter scenario, plant a native grass and forb plant community on half of your lawn and dump the gas mower. Tripp brought up a point that was right on. An hour of running your lawn mower is equivalent to driving you car for 100 miles.
  5. burritos
    4,946
    253
    <div class='quotetop'>QUOTE(SSimon @ Apr 4 2007, 11:35 AM) [snapback]417649[/snapback]</div>
    I always thought this, but then I took my 11 mo old to the local community park and had him run around on iit. It was very pleasant for the both of us. Our home lawn is shot to hell cause I rarely water it. I'm surprised I haven't heard from the HOA yet.
  6. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Climate-appropriate lawns have there place. Too often we substitute water for knowledge - thereby increasing use of fossil fuels (water pumping, mowing). The vast majority of homes, schools, churches, businesses operate phantom farms. Soil is tilled, seed sown, oil-based fertilizer applied, growing plants are tended and offending weeds are poisoned and removed and the crop is irrigated. After a couple of weeks the crop is harvested (mown), then tossed aside. Seems an incredible waste for all the effort.
    So-called gardners make increasing use of fossil fueled dust blowers that contribute to particulate matter, aerosols and noise.
    Our efforts to imitate 17th century European estates are heavily dependent on fossil fuels. Constructive alternative: greater use of climate-appropriate grasses and ground covers that require minimal pruning and irrigation. Greater use of quiet electric mowers that recharge from the grid and home photovoltaic systems.
  7. dbermanmd
    dbermanmd New Member
    8,553
    manhattan
    <div class='quotetop'>QUOTE(burritos @ Apr 4 2007, 02:40 AM) [snapback]417482[/snapback]</div>
    Obviously not - they indicate the presence of homosapians - the #1 cause of gw. So no lawns = no humans = no global warming.
    how do you measure the co2 we exhale every day?? think about 6+Billion homosapians pumping out co2 every second of every day - anyone ever measure that? perhaps population control would be best - less humans - less lawns - less energy requirements - less fossil fuel use - less meat consumption ........
    perhaps advocate knocking off all people in the top 1% of net worth/income - those are the guys with the big carbon footprints, the private jets, the tax evaders, the HUGE co2 producers - anybody calculate the net savings in co2 production doing that?
  8. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    <div class='quotetop'>QUOTE(burritos @ Apr 4 2007, 11:50 AM) [snapback]417660[/snapback]</div>
    I'm not sure what your opening lines mean. But SSimon's post relates to the areas where tall-grass prairie can live, and S. California is a different ballgame altogether. For most of the country, lawns will go dormant in hot dry weather, and spring back to life when rains come, but there may not be enough rain in Ventura County.
    Grass lawns do not reduce global warming gases because most of the carbon absorbed is released when the mowed grass decomposes. The small amount that is sequestered into the soil is more than made up for by the fossil fuel used to mow the lawn. A maintenance-free lawn made up of native landscaping is beneficial, particularly in areas where you can have good vegetation growth without irrigation (sprinklers). In fact, tall grass prairie will sequester more carbon than a forest of the same area.
    <div class='quotetop'>QUOTE(dbermanmd @ Apr 4 2007, 12:12 PM) [snapback]417676[/snapback]</div>
    Hey, he does listen to our posts! :lol: :p (Altho I still see two errors in the first paragraph :huh: )
  9. SSimon
    1,426
    N/W of Chicago
    Burritos, they now sell low-grow, low maintenance grasses for the home landscape. I wonder if your little one would like this? Here's a link...
    http://www.wildflowerfarm.com/Merchant2/me...Category_Code=E
    I don't know if this is appropriate for your area, but you may want to look into this.
    My turf is shot too. I never water or fertilize and there are icky brown patches all over. My neighbor who takes great care of his beautiful lawn, has a major grub problem. I have a butterfly, lightening bug, bee problem. Mine problem is prettier, I think. :D
  10. hill
    8,936
    A ton of our neighbors are going to THIS route:
    http://www.southwestgreens.com/turfgrass.html
    Man! They got that stuff looking pretty real. Looks great, and in southern CA where they're currently under drought / H2O restrictions, it seems like the way to go. Our association pays for lawn mowing, so those guys are being paid the same, to do less & less :lol: . I DO notice though, that dandilions WILL still grow up ... right at the boarder of the fake lawn :p . We have a few Canada Geese that refuse to fly south for winter ... and their droppings may feed regular lawns ... but sheesh! ... nasty cleanup time if you got to hose Goose s_it out of your fake grass.
  11. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    <div class='quotetop'>QUOTE(hill @ Apr 4 2007, 12:35 PM) [snapback]417694[/snapback]</div>
    How about just creating a landscape with plants native to one's region? They're evolved to thrive in just the conditions you're experiencing in your area.
    I think it's good that the landscape in different parts of the country reflects the unique environmental conditions...otherwise, everywhere we go we'd see roses and a vibrant green lawn.
    Boring!!
    I really don't understand the fascination with growing and maintaining a lawn in conditions which won't support such a fertilizer and water intensive monoculture. Then, to take it a step further and have a FAKE lawn...?!?
    What's up with this visual metaphor? Are we recalling the conditions on the East Coast of our country?
    Why on Earth would I want to sit in my back garden and gaze upon an expanse of green-colored recycled tires, formed in the shape of blades of grass?
    Yuk.
    I suspect you'd be against such a decision...these folks are probably your patient$.
  12. tripp
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(Pinto Girl @ Apr 4 2007, 03:32 PM) [snapback]417818[/snapback]</div>
    Not East Coast... English.
  13. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    Cut with one of these manual mowers and you won't be blowing out any CO2.
  14. oxnardprof
    oxnardprof Member
    250
    17
    Oxnard, CA
    I agree with several of the posts that traditional grass lawns are not beneficial due to water consumption, lawn mowing (electric or gas), herbicide and fertilizer use, etc.
    We are in the process of planning a xeriscape in the front yard, removing the lawn and replacing it with drought tolerant, noninvasive garden plants. We will convert the sprinklers to drip irrigation.
    As another poster pointed out, here in Southern California, water restrictions may become a fact of life, so it is prudent to plan for it. Even without formal restrictions, this is appropriate.
  15. Darwood
    Darwood Senior Member
    5,259
    268
    Wood ticks could be a problem with prairie grasses for an urban/suburban home.
    Ticks in the north are rampant in rural areas and Lyme disease and other tick borne diseases are all over the place. Since, we have a cabin in the rural north woods, I have to pay like 50 bucks a year on a lyme vaccine for the dog as well as about 80 bucks a year for frontline tick repellant.
    Yet, my dog still got a mild positive test for lymes last month and now we're paying 50 bucks for antibiotics for our 120 pound Weimeraner (We were expecting an 80 pound dog, as most weimeraners ussually are). This is just an unavoidable expense when you have a dog, and a cabin in the woods.
    Ticks are pretty much non existant in the city though, since ticks can't survive in short grasses.
    If people all had prairie grasses instead of a manicurd lawn, wouldn't tick populations move back in?
    Then you'd be looking at ALL dogs needed tick prevention and many humans would even get lymes.
    Also, with a big dog and two young boys, I need a "playable" yard, and tall grasses would probably not be ideal. We'd lose a ton of toys and balls in the lawn, we'd have many more mice and insects, it'd be darn tough picking up dog poop as well as cleaning up sticks, leaves, walnuts, and all the other crap my trees drop. This is also a problem for "turf". Do you know how much pee and poop comes out of a 120 pound dog? The turf would be so nasty in 1 year, I'd have to rip it up and send it to a landfill. At least now, I reuse all the yard waste I generate into mulch or compost.
    What I need to do, is reduce my lawn (convert to food producing garden) and mow the rest with an electric or manual mower. In the north, lawns do pretty good on their own, and only need occasional watering. If I installed a rainwater cystern, I'd probably collect enough for all watering needs. However, that would require bringing in heavy equipment to dig the hole which would probably not go over real good with the neighbors. Or my carbon footprint.
  16. SSimon
    1,426
    N/W of Chicago
    <div class='quotetop'>QUOTE(Darwood @ Apr 5 2007, 12:57 PM) [snapback]418308[/snapback]</div>
    ...and try to make an attempt to cut back on fertilizers, herbicides and pesticides which end up in water far, far away. As a peripheral thought, pesticides end up killing 99% of beneficial bugs and a minority of true pests. I don't think many people know this. I didn't, until I became involved with my own restoration.
    I'm not sure about ticks moving into residential prairie type installations. I do know that I worked with an 80 year old man to conduct a base line survey of our native, public grasslands who has been in the field his whole life. This past year was the first that he contracted Lyme disease and he is always in the thick of it. Dressing correctly is half of the battle but I'm sure we all don't want to be walking around our backyards in such an inconvenient manner.
    Speaking from experience, my prairie is three years old this year and I haven't encountered any type of a tick problem. I'll post if one arises this warm season. So far, my private restoration has been nothing but a pleasant experience.
  17. Darwood
    5,259
    268
    I've never used pesticides and only a couple of times used herbicides in small controlled spots (as opposed to just dousing the whole lawn with the crap. So I'm not too worried about that. As for fertilizers, I use organic fertilizer (to protect the dog and kids in the yard) once or twice a year. Usually fish emulsion (kinda smells for a day!). It's really not a whole lot. The lawn doesn't need a whole lot if you use a good mulching mower. And if you water it in properly, it doesn't not contaminate anything. It gets into the soil and is pulled up into grass.
    <div class='quotetop'>QUOTE(SSimon @ Apr 5 2007, 02:09 PM) [snapback]418315[/snapback]</div>
    But does your parcel have a route for the reintroduction of the ticks? (connections to larger natural landscapes, carrier animals like deer).
    A few homes here and there in the middle of the suburburbs/city are not going to have ticks flowing back in. But if many people go that route, they could.
    Lymes is pretty much located in the northern midwest and reside primarily on the deer ticks. No deer? no deer ticks. Deer ticks are smaller than regular ticks and much harder to notice if they are on you or your dog. I think your approach is a good one, but is probably not a good idea for everyone to switch to. If I had no dog or kids, I'd probably turn my entire yard into food producing garden space! Though I'd have to be ready with the pellet gun to fight off the overpopulation of squirrels.
  18. nerfer
    2,507
    237
    28
    <div class='quotetop'>QUOTE(Darwood @ Apr 5 2007, 01:00 PM) [snapback]418308[/snapback]</div>
    As mentioned, you still need vector species to transport the ticks around. Why can't they live in short grass too - they need a place for the eggs to hatch and then climb up and wait for a passing animal to grab onto. A lawnmower would chop up a few, but I don't think that's the reason they aren't in suburban yards, it's more of a lack of tick-carrying mammals.
    Let it go dormant. Looks a little brown, then returns to life with wetter, cooler weather with no problem. Or plant zoysia grass - grows slowly, doesn't need much water, stays green all summer, but looks like you killed it in the winter (straw-yellow).
    For fertilizing, I use natural fertilizers (limited selection available at the local Home Depot). I also bought a cheap soil-testing kit from the garden store and determined what the grass needed (mostly nitrogen in my case, because I had been using a nitrogen-poor natural fertilizer before that). Originally the lawn had some herbicides, so the weed problem wasn't bad. Now I can just go around with a screwdriver and get out the dandelions and other weeds as I see them. A properly fed lawn will resist weeds - they can only move in when the grass is weak. Figure out why the grass is weak and then the weed problem is easy to fix. I haven't used any herbicides or pesticides in years. I don't water much (usually not at all), so it doesn't look as nice as my neighbor's lawn with his in-ground sprinkler system, but I don't mind. I would like to increase the portions that are not grass, but that takes time and money up-front, the savings come later.
    I had a friend who had no grass lawn, all natural prairie or other vegetation, but when they moved they couldn't sell it (it was also when the real estate market slumped), so they ended up ripping out the prairie and putting in sod. That was sad to see.
    <div class='quotetop'>QUOTE(SSimon @ Apr 5 2007, 01:09 PM) [snapback]418315[/snapback]</div>
    Growing up on a farm, camping every year, and volunteering with a prairie-restoration group, I can't tell you how many ticks I've had on me. Not too many were attached (do a scan at the end of the day or before), but all those were wood ticks, and most were before Lyme Disease spread into this area. I haven't knowingly seen any of the smaller deer ticks. No tick diseases for me yet (knock on wood). I worked on that base-line survey too (two years ago, if it's the same one), and I got a ton of chiggers that year, but few ticks.
  19. SSimon
    1,426
    N/W of Chicago
    I just bought another batch of corn gluten for my weed problem. Supposedly, it has slow release nitrogen in it as a natural component of the corn. This isn't a quick fix solution to anything. It requires two annual applications, one in Spring and one in Fall. I don't yet know how effective it is as I just started applying it last Fall. It affects seedlings, but not mature plantings. So, manual labor is still required to rid your lawn of any mature weeds.
    <div class='quotetop'>QUOTE(nerfer @ Apr 5 2007, 02:07 PM) [snapback]418342[/snapback]</div>
    I've had a ton of ticks too, but not the Lyme carrying ones. From what I understand they are as tiny as the period at the end of this sentence so they'd be hard to see with a visual body check. Yes, it's the same study we were involved with. We were warned about chiggers so it's one of the only times I've found it acceptable to spray my ankles and legs with Deet. A friend told me that if I was inhabited by chiggers, an application of clear nail polish (or was it nail polish remover?) would extract them. Logically, it sounds like clear nail polish would work. Maybe it suffocates them. Hope this info helps for your next excursion.
  20. hill
    8,936
    <div class='quotetop'>QUOTE(Pinto Girl @ Apr 4 2007, 05:32 PM) [snapback]417818[/snapback]</div>
    Well, in So. Cal, . . . wouldn't THAT look boring (most folks don't realize the area, naturally is DESERT ... ie; rocks, tumbleweeds, a few cactus). The day our CA neighbors go THAT route, I'll stay up in Montana :p . Yea, I'd prefer fake lawn to rocks.
