Do I have HID lights?
Discussion in 'Gen 2 Prius Technical Discussion' started by plasakow, Aug 30, 2010.
  1. plasakow
    plasakow Junior Member
    Just bought a used 2005 prius with, I beleve, the advance tech package (nav, bluetooth, leather, CD changer).
    I notice the headlights are whiter than most other cars on the road.
    Do HID lights come standard, or do I just have a hi color temp quartz?
    Thanks!!!!
  2. 2007-Prius-hybrid
    2007-Prius-hybrid New Member
    132
    NY
    HID's are in that model
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    If you have fog lights, you have HIDs.
  4. plasakow
    Thanks for the replies. A couple of followups:
    1) Is there a replacement bulb or combo bulb/ballast kit that would give me brighter beams? I commute 30 miles at night through country, deer-in-the-road, minor roads. Every lumen I can coax out of my car, the more secure both the deer and I feel.
    2) Yes, I have fog lights. I can't figure out how to turn the suckers on, though.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    the outer ring is headlights, the inner ring is foglights
    (Normally this stalk is attached to your steering column)
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    The USA section of http://priuschat.com/forums/knowled...andard-optional-equipment-some-countries.html is helpful to a lot of folks.
    Another thing one will notice w/the HIDs (if you have them), is if you turn the high beams on/off, a portion of the mechanism behind the lens moves forward or back. There isn't a 2nd set of lights (high beams) that turns on/off. My Z and my former 02 Maxima had a set of halogen high beams that'd turn on/off with the HIDs staying on, the whole time.
