Do I need a new big Battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BlackBeauty 09, Sep 6, 2019.
  1. BlackBeauty 09
    BlackBeauty 09 Junior Member
    17
    beaverton, oregon
    My Prius is currently at the dealership. I was driving on the freeway when my dashboard went tilt and the red triangle plus 20 other lights came on. I got to the dealership and they told me that the battery is probably needing to be replaced. I call bs on that as it has 132k miles, just had it serviced and they saw no problems. The battery/ monitor is showing 5-6 bars consistently. I recently started practicing better Prius gas pedal skills and have gotten the mileage to 40.2 mpg.
    I don't know what the dtc's are at this time
    Any thoughts or questions I should be asking?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Have you checked for recalls and prior maintenance history by running the VIN at http://toyota.com/owners
    Please report here what has or hasn't been serviced since the car rolled off the lot.
    If you are paying for a diagnostic inspection (or not depending on the dealership), they should offer with your repair quote a print out of the OBD2 scan with the DTCs that were reported. If those DTCs have associated INFs, you can also request such. Needed terminology might include, INF or "detailed code", and also known as "subcodes".
    jerrymildred and Raytheeagle like this.
  3. JC91006
    16,493
    8,403
    It would not surprise me if a 2009 with 132k miles had a failed HV battery. It's 10 years old and has a ton of miles on it. If this would be a California car, it may still be under the CARB 10 years/150k miles warranty
    The good news is these cars last quite long and should get you to 200k miles with ease.
  4. Moving Right Along
    Moving Right Along Senior Member
    690
    541
    Thus far, failed HV batteries on 09 models have been exceedingly rare. However, rare does not mean impossible and you may have just gotten unlucky. Typically, MPG will go down and you’ll see more dramatic battery charge swings if the battery is dying. Since those did not happen for you, it’s possible that one module got out of sync
  5. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    I'd call that, "We're not sure yet." That's not something you replace unless you are sure and there's no reason to not be sure. But, if it's actually under the CARB warranty and they want to replace it, go for it!! :)
  6. BlackBeauty 09
    17
    beaverton, oregon
    Thank you. I got the P0A93 code do you know anything about that. water pump needing to be replaced. Is there a way that a mechanic can give a wrong code? This was at the dealership
  7. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Quite doubtful a mistake has been made, and the inverter pump repair will cost less than a new HV battery :whistle:
    The DIY fix could be in the $100 range, and some time spent wrenching.
    There was a recall on the "inverter pump assembly", and your vehicle may or not be covered (is your VIN # listed?)
    Per a previous suggestion posted above, did try entering the vehicle VIN at http://www.toyota.com/owners/web/pages/resources/recalls - to check which recalls (or dealer maintenance related visits) have already been preformed, if that is technically difficult for you, then ask the dealer if your vehicle qualifies for "Toyota 12V-536 (C0U)" or any other safety recalls.
    Skibob, jerrymildred and Raytheeagle like this.
  8. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    OP is in Oregon not CA. Don’t know what the rule is for Oregon
    JC91006 likes this.
  9. JC91006
    16,493
    8,403
    I actually don't know which states follow the California CARB warranty, if Oregon is one of them, then the warranty would apply. But seeing we are at the tail end of 2019, I doubt it'll be under the 10 year mark.
