Do I need an "old" functioning key fob for the chicken dance to work?
Discussion in 'Gen 2 Prius Main Forum' started by Joe Wall, Jun 13, 2022.
  1. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    I'm getting frustrated because I've tried the chicken dance 2-3 days which doesn't work. My old key fobs do not work. I've been using the manual key because both do not work. I just purchased a new fob on Amazon which is not working. Any advice? Can I still program my key fob using "the chicken dance"? Thanks!
    #1 Joe Wall, Jun 13, 2022
  2. PriusCamper
    PriusCamper Senior Member
    11,109
    4,522
    Pacific Northwest, USA
    Chicken dance only works with fobs that are brand new and not connected to an existing vehicle. There used to be a guy on Ebay who could wipe used fobs to make them work like new. Not sure where they went, but I think Ebay kicked him out for selling that type of service because it wasn't a product?
    Alternatively it's possible that too many fobs have been registered into the system and the service in Toyota Techstream that prepares the vehicle for a new owner will wipe those away so there's room for a new FOB.
    Kaptainkid1 likes this.
  3. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    I purchased a new fob online I just got and it is not working to do the "chicken dance".
  4. PriusCamper
    11,109
    4,522
    So you have no fobs that make your car run? OR do you have one Fob? I'm confused because the manual key only opens the door, it doesn't start the car? Are you able to start the car with that Fob?
  5. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Yes manual but unlock and lock from key fob dont work. It starts with the old fob
  6. PriusCamper
    11,109
    4,522
    Ok, got it... And you've tried it with this valet key button in both positions:
    Also how many previous owners of the vehicle?
    As in is there any way of knowing how many fobs have been added to the car in the past?
  7. Kaptainkid1
    Kaptainkid1 Active Member
    308
    243
    Los Angeles
    To add a new SKS Key fob to your Prius you would need a working SKS Key fob programed and working to your Prius. That means opening and closing the door remotely. Open's door without using the key and just by proximity function for SKS special keys. If you open the door with a key and slide the keyfob into the fob slot that means only the magnetic key tag is programmed and none of the smart key functions are programmed. Therefore you can not chicken dance a new blank SKS Key fob. Unfortunately you will need someone to programmed the new sks key fob.
    SM-A526U ?
    #7 Kaptainkid1, Jun 13, 2022
  8. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Locksmith will do it for $50 I guess
  9. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Why does my new fob and all my other 2 fobs have weak signals? Locksmith said try different batteries
  10. bisco
    49,537
    certainly, the battery voltage is important. a new battery should measure 3.3v without load.
    beyond that, it's hard to determine why a signal is weak. it may be interference in your area, but trying it somewhere far off would be a good test if you ever take a trip.
    or maybe voltage to the ecu is weak.
  11. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Im frustrated bc locksmith couldnt figure it out.
  12. bisco
    49,537
    unfortunately, that is outside of his area of expertise, even a dealer probably couldn't figure it out if there aren't any codes.
    another possibility is a weak 12v battery
  13. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Batteries were dead so Ill try reprogramming it.
    ColoradoCrow and bisco like this.
  14. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Got it thx!
  15. bisco
    49,537
    congrats!
  16. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    I think the batteries plus hitting the key button in helped.
