Do I need these services?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Godawgs, Apr 7, 2026 at 11:34 AM.
  1. Godawgs
    Godawgs Junior Member
    Portland
    2018 Prius Prime
    I have a 2012 Prius with 115,000 miles. We drive about 6,000 miles per year with no plans to trade it in. When last in for service the garage recommended the following:
    Spark Plug Replacement $301
    Brake Flush $179
    Fuel Injection Service $259
    Transmission Flush $264
    Coolant Flush $235
    Inverter Coolant $199
    I had the Coolant fluish, brake flush, and inverter coolant all done at 61,000 miles on May 2017, but never the other services.
    What should I have done?
    Thanks for any advice!
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,273
    880
    Monument, Colorado USA
    All except the Fuel Injection Service....just make sure you fill up your tank with "Top Tier" gasoline and that'll keep them cleaned out for you.
    I would ask about the cost of the spark plug replacement....sounds more like a $150-200 job than $301...I'd remind them it's a 4-cylinder and easy peasy!!
    BTW, that's an excellent price for the transmission service....last I checked, my dealer charges $310 for it.
  3. Mendel Leisk
    41,928
    I won't comment on the timing, but just considering each item:
    Brake Flush $179 <Toyota USA says nothing regarding brake fluid change (presumably what they're actually doing), but Toyota Canada recommends tri-yearly or 48k kms, whichever comes first
    Fuel Injection Service $259 <Pure waste of money
    Transmission Flush $264 <Toyota USA (and Canada) say nothing regarding transasxle fluid change (presumably what they're actually doing). That said, I would do at least one. Still, that price is ridiculous, even in Canadian dollars it's ridiculous. A trasnsaxle fluid change is no more complex than an oil change, and considering there's no oil filter, the difference in supplies is trivial. I wouldn't pay over $100 USD. Make sure they're using Toyota ATF WS, from freshly opended bottles.
    Coolant Flush $235 <Presumably engine coolant change. That's about the usual full-retail price I guess. See the attached schedule to determine if it's warranted.
    Inverter Coolant $199 <Per previous comment. Heady thought: how about $200 even
    Attached is a summary of the Toyota USA maintenance schedule, extrapolated to 240k miles and 24 years.
  4. BiomedO1
    BiomedO1 Senior Member
    4,184
    2,186
    SacTown, Ca
    IMHO:
    Spark Plug Replacement $301; Due for replacement
    Brake Flush $179; No official Toyota recommendations, but other OEM specify 3-5 years. It's pretty humid in Portland. There is a couple of test you can run.
    Fuel Injection Service $259; Hard Pass - buy some over the counter injector cleaner and dump it in on your next fill-up.
    Transmission Flush $264, No official Toyota recommendations, but after 14 years and 115K miles, you should probably change it.
    Coolant Flush $235
    Inverter Coolant $199; Both coolants should probably be changed, You've reached the 10 year time interval but not the mileage interval - chemicals and oils breaks-down and get contaminated over time. If you look at the footnotes of your manual, after the first coolant change; it reverts to 50K mile intervals.
    I also have an issue with terminology - a change vs a system flush are very different procedures. One will require at least 2.5x more fluids to accomplish. I know some people don't see a difference, but billing for a flush when they are actually doing a change is, technically FRAUD. The OEM manual ONLY ask that the fluids be CHANGED; doesn't state "flush" in the documentation. Service writers will always try to sell you the expensive option; unless you correct them. That's been my experience.
    Here's a web site to get a rough price comparison. I'd ask for a service discount; if they are going to do multiple services in one visit - They're not going away and coming back, so that's saving them time and money; which should reduce your cost. Toyota Prius Spark Plug Replacement Costs
    #4 BiomedO1, Apr 7, 2026 at 12:50 PM
    Brian1954 likes this.
  5. Godawgs
    Portland
    2018 Prius Prime
    Appreciate the replies thus far. These were dealer prices so I may get a quote from an independent shop.
    ColoradoBoo likes this.
  6. ColoradoBoo
    1,273
    880
    One additional comment, some places like to do "flushes" instead of a drain and fill. Save your money, request drain and fill....transmission and coolant doesn't need flushing and, if done wrong, can actually create problems.
  7. Mendel Leisk
    41,928
    A lot times the dealerships say flush, when in fact it's a drain and fill. Virtually always.
    @Godawgs the elephant in the room: it's your car. Study the schedule (table format I posted early in infinitely easier than trying to make sense of the event-by-event format in Toyota USA's Warranty and Maintenance Booklet), make a decision as to what you're hiring them to do, get a quote.
