Do I need to go to a Toyota dealer to flush/replace the brake fluid?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wynn, Dec 17, 2014.
  1. Wynn
    Wynn New Member
    I searched for the answer to this, but couldn't find exactly the right one. The dealerships are so far away from me. I know it needs to have the Techwhateversomething, but if I informed a decent mechanic of that, is there a danger in having someone other than at a Toyota dealership do it?
    Thank you!
    Wynn
  2. Patrick Wong
    18,200
    6,479
    If the decent mechanic will take the time to research the brake flush procedure on techinfo.toyota.com then there won't be a problem. If the mechanic thinks that because he has 30 years of automotive experience that no new learning is required on his part, then you'll have a problem with the outcome.
