Do I need to reset TPM switch after replacing the 12V battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by toyolover, Jan 13, 2014.
  1. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I recently replaced the 12v battery. Prior to the installation of the new battery, the car was left without battery for 24 hours (ie. the old battery was removed from the car.)
    Do I need to press the TPM reset switch after a new battery is installed?
  2. JC91006
    16,480
    8,397
    I don't think the tire pressure monitors are affected by a battery swap.
    toyolover likes this.
  3. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    JC91006 is correct. The batteries for TPMS are built into each valve stem and have an average life of 6 to 8 years. Most tire companies will offer a TPMS rebuild when you get new tires which replaces gaskets and/or O-rings in the assembly, but not the battery itself.
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    No, you don't need.
    the TPMS is monitored by your ECU.
  5. Bill Norton
    Bill Norton Senior Member
    1,841
    601
    MONW, Ks.
    It couldn't hurt to reset, if you have your tire pressure where you like it, measured accurately.
    The reset button then stores that pressure as the set point.
    Then if any tire goes below ~20% that pressure you get the light.
