Do I need to turn on AC for heat?
Discussion in 'Prime Main Forum (2017-2022)' started by mister2cool, Nov 11, 2019.
  1. mister2cool
    mister2cool Member
    98
    52
    New Jersey
    2020 Prius Prime
    Traditional cars don't require AC enabled to have heat. Even my older Gen 2 didn't need AC for heat as it used electric heater in conjunction with ICE heat.
    I think heat is produced by heat pump on the prime so do I need to have AC enabled while on Auto setting for heat?
  2. Tideland Prius
    16,658
    A/C is independent of the heater. It just tells the car to run the compressor (for cooling in the summer or for dehumidification in the winter). The heater is triggered by the temperature difference between your set temperature and the outside temperature.
    (i.e. you can leave it at 70°F and when you drive from the desert to the top of a ski resort, it will change from cooling to heating automatically and independent of whether you have the A/C light on or off)
  3. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    The car thinks for you.
    Data Daedalus and elementnomore like this.
  4. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    So, in the winter does it make any difference if the AC light is on? The heat works without it, but does it do anything different with it on? Does it actually dehumidify?
  5. mister2cool
    mister2cool Member
    98
    52
    New Jersey
    2020 Prius Prime
    In a traditional car, yes having the AC light on it works to dehumidify. With the head pump in the prime, I am not sure if the compressor needs to be running to produce heat when the car is in EV mode.
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    Wait... if you have A/C OFF, would it be cooling in this example? You said, A/C ON is for cooling in the summer or for dehumidification in the winter... I thought I had this sorted out. But now, I am confused again.o_Oo_Oo_O
  7. Trollbait
    12,787
    With a heat pump, that is a very good question. For cars without a heat pump, turning off the A/C tells the system not to use the compressor. Since a heat pump is basically A/C running in reverse, does turning off A/C tell the system not use the compressor even for heat?
    Assuming the engine isn't on, I guess that answers the about question.
    The heat pump design in the Prime can do some dehumidifying. It can cool down incoming air to dry it, and them heat it back up, as there are two condensing/expansion coils in the dash instead of just one. Revisiting my question, does having the A/C light off mean the system will bypass the drying coil to provide more heat? Normally the heat pump has to heat air it just cooled down. I think there is a humidity sensor, so it is probably all done automatically.
    The dehumidifying by heat pump is limited though. Which is why when the defroster is turned on, engine comes on. During that operation all the heat pumps efforts go into drying the air, and the engine is needed for heat. In another car, turning on defrost cancels the A/C off, and turning it off again, usually means foggy windows.
  8. Mendel Leisk
    42,165
    On third gen at least, monitoring the AC compressor usage with a ScanGuage: when vent mode was set to Heat/Defog, the AC would sometimes activate (even though AC light was not on, stealth AC).
    I believe the cabin temp sensor incorporates a humidity sensor as well? I believe the car's monitoring humidity and cabin temp? It would commonly run AC when temps were moderate and it was raining (the main time I'd use Heat/Defog). If temps dropped to near freezing and/or the air was fairly dry, it wouldn't activate AC.
  9. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    I think there is supposedly a sensor near the forward camera that checks if the windshield is foggy.
  10. Mendel Leisk
    42,165
    Yeah, from 4th Gen Prius Repair Manual:
    meeder likes this.
  11. Salamander_King
    11,024
    8,976
    New England
    For the last two years, I kept my car with AUTO 70F with A/C ON all the time throughout the year. I never had to fiddle with any of the manual buttons to adjust my temperature or defogging function except occasionally turning on the front defroster in a morning. This took care of heating, cooling and dehumidification year around. However, it caused using quite bit of traction battery SOC for HVAC functions. In winter, my A/C load ratio could get as high as 30-40%.
    Then @Tideland Prius told me that A/C ON was not needed for the heat pump. And I discovered, even with A/C OFF, if the direction of the airflow is to WINDOW, then the electric compressor would turn ON automatically either in AUTO setting or Manual setting. I have been using manual A/C OFF with fan speed set appropriately and switch airflow to Window (compressor ON for dehumidification) or to Cabin (compressor OFF but heat kept on). With this setting so far, my A/C load ratio has been below 10%. But it has not been super cold yet. I will have to see how it works in middle of winter.
    #11 Salamander_King, Nov 12, 2019
    Data Daedalus likes this.
  12. Tideland Prius
    16,658
    If you're in AUTO mode, then the A/C light on just means that you're allowing the climate control to use the compressor as needed. Depending on the situation, it may not be running all the time. If you live in a place that's dry enough (and don't track in enough snow when you step into the car and the snow melts to generate enough humidity), then you might be fine keeping it off (although again, if it's on and it's dry, it won't be running anyway). If you live in a place where humidity is high or where the snow is denser (wetter) and the windows get fogged up more easily, it's better to leave it on so you're not constantly fiddling with the defroster.
    If you're in manual mode, it will make a difference since if the light is on, then it's always running.
    Dang it, I thought I could get away by skipping a few parts lol.
    Well if the A/C is off in the summer, you're just venting and not really cooling lol. Why you gotta be so pedantic? :LOL:
    Salamander_King likes this.
  13. bisco
    52,677
    it's good to have simple, user friendly systems :cool:
  14. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    Do we know if it actually dehumidifies while heating in EV mode with the AC light on. You describe the way we expect it to work, but my question remains does it actually operate differently? Is there any way to tell?
    I wish I could control when the heat is on, because often if it's cold outside and warm in the car I want cool air but no heat. Usually it seems to do that, but I don't trust it, and heating would be a waste of energy when I don't want it. I know I can set the temperature to Low, but that's a lot of clicks, and then I have to set it back when I park so the remote AC button works for heating.
    Dehimidifying when it's not needed would be a big energy penalty, given how much energy the heat pump seems to use in defroster mode. Maybe the humidity sensor works so well that it's perfectly seamless and I've never noticed it. But Toyota software and climate control isn't that way. Things like the primitive way it calculates range of the "climate score" don't give me high confidence.
  15. Salamander_King
    11,024
    8,976
    New England
    Yes, I want that too.
    At least, for cooling, we know A/C OFF means OFF. Thanks for clarifying this @Tideland Prius;)
    What we need is Heat ON/OFF button. In fact not just Heat but Heat Pump ON/OFF button. During winter, I want to heat only from ICE not from the heat pump if I can select that mode.
  16. Tideland Prius
    16,658
    You’re gonna have to trust me when I say my windows fog up when it’s off (and definitely fog up when I enter a parkade if it’s off. I parked in one underground one today and the windows never fogged up. The mirrors did so I had to turn on the heated mirrors.
    that’s the whole point of automatic climate control.
    I might’ve missed the discussion but why is that? Do we know it doesn’t do that (or some sort of blend between engine and heat pump)? I’d imagine the stronger the request for heat, the more likely it’ll use engine heat.
  17. Salamander_King
    11,024
    8,976
    New England
    I know this is not for everyone. But since Toyota designed the PRIME (and entire lines of Prius) with a focus on fuel efficiency, the car tris to keep the ICE off as much as possible. Many PRIME owners want that even that means using battery power to heat the cabin using the heat pump which results in reduced EV range. In my case, for my daily drives during winter, ICE comes on anyway because it is too cold and I have too long to drive or I have to use defroster, etc, etc. On top of it, in my case, running PRIME in HV mode costs less than running in EV mode especially in winter. So, if ICE is going to run anyway and it is actually going to save money by doing so, I want to utilize as much of wasted heat as possible by using only the ICE generated heat and not waste valuable battery power on heat pump which I know it to be not very effective in heating the cabin in our winter temperature. If I had a heat pump ON/OFF switch, I think I can control this process more effectively than how the car handles it in the AUTO setting.
    #17 Salamander_King, Nov 12, 2019
    E-GINO likes this.
  18. Tideland Prius
    16,658
    Right but if you just start in HV mode (with a drained battery), then it wouldn’t be a problem.
    Do you still fully charge even though the engine runs in the morning?
  19. Salamander_King
    11,024
    8,976
    New England
    I assumed the car uses ICE heat if it is available. What I don't know is if it ever switches to the heat pump after ICE cools down or when I switch to EV mode. There is no indicator I can check on the heat pump operation. From reading this thread, it seems I may be able to get that info from Scan Guage. I don't think Hybrid Assistance has that information displayed.
    Yap. I have been saving the EV mode for my afternoon commute back home. This is when the heat pump operates and shortens the range. I had my HVAC on 70F AUTO with A/C ON all the time for those winters. This year, I am planning to switch EV/HV during both morning and afternoon to see if that decreases the heat pump use and extends the EV range despite not in one contiguous drive.
    Tideland Prius likes this.
  20. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    Yes, I think it will turn the heat pump back on if you switch to EV mode once the heater core cools down. If you're in HV mode and it goes to EV for a while, it will use residual heat and then turn the engine on again when it needs more heat, so using the heat in HV mode will cause the engine to run more than it might otherwise need to.
