Do I really get 99.9MPG with engine running?
Discussion in 'Gen 2 Prius Fuel Economy' started by mikepaul, Feb 5, 2004.
  1. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    So I'm driving around, and glance down at the Energy Monitor, and it shows the engine providing power to the wheels and to the electric motor which is sending some to the battery, at 99.9MPG.
    This is rather counter-intuitive. I'd think if the engine is running, odds are I'm using fuel. The two go together. When I'm warming the car up, I see the Consumption MPGs go down, so I know that is working properly.
    I do see MPGs between 50 and 99 all the time, going down the road as fast as 75MPH. A small downhill slope, and the MPGs shoot through the roof for a short duration. What I don't understand is how the engine can be powering the wheels and still I get 99.9MPG...
  2. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    Yes, it's possible. The requirements to move the car are at a bare minimum on a downhill run, yet the hill isn't long enough to allow the ICE to shut off. The concept is really no different than coasting downhill in a normal vehicle.
  3. olends
    olends New Member
    214
    Clifton Park, NY (near Albany)
    also at 75 mph, the ice must spin, albeit using no fuel, and under no compression, just to prevent a mechanical overspin of MG2.
    and a mechanical overspin of an electric motor= way way way above redline on an ice, and we all know over red line is BAD
  4. mikepaul
    1,763
    Columbia, SC
    I'd like an update for the display software, so the little ICE visibly vibrates when it's running. You''d pull up to a light and it'd be vibrating, then you'd feel the ICE cut off and see the display 'shut off' too.
    Just seeing the animated lines isn't quite informative enough for me...
  5. xevious
    xevious New Member
    187
    Oregon
    Another thing to keep in mind is that the display reads "99.9" whenever the calculated mileage is equal to or greater than 99.9 MPG. When in stealth mode, your instantaneous MPG is actually hovering somewhere near the outer reaches of infinity (that is, the "miles" figure is accumulating while the "gallons" stay in the tank), so the 99.9 is way off in this case.
    When the display reads 99.9 with the ICE running, your actual MPG could be 101, 120, 200, or higher. Point is, the impact on fuel consumption is minimal and (according to the ECU) you are indeed getting at least 99.9 MPG.
    tanglefoot likes this.
  6. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    I actually got a surprise on the way home yesterday. I was driving a downhill stretch of road that I had always asumed that the engine had cut off due to the maxing out of the graph, and the steepness of the grade. I was surprised to find out when I switched over to the energy monitor to find the engine running, and supplying power, electric motor running, supplying power, AND power being drawn off of the battery. The climate control system was off, as I only run it just enough to clear the windshield in the mornings.
  7. jeffrey
    jeffrey New Member
    94
    Now that its warming up a bit here in New England, I've noticed that on my consumption screen I've actually received three five minute periods of 99.9mpg in the last couple days. Generally I seem to get five minute intervals of just over or under 50, ranging from a low of 35ish (first five minutes of the run) to fairly steady five minute blocks of 45-55. Then, all of a sudden, I'll get a block of 99.9. I guess I'm wondering why not 85, or 75, or 95. It seems I don't get any blocks of anything much over 55 or so, unless I get one of these (relatively new) 99.9 anomolies.
    Anyone have any thoughts, or observe anyting similar?
    Peace :)
  8. cybele
    cybele New Member
    406
    Los Angeles
    I get intermittant blocks of 60, 75 or something that I figure is 85 or 90. I guess it all depends on the math. Those are usually stretches where I get a lot of 99.9 and then a few brief periods of acceleration to get to cruising or coasting speed (which is why I guess it would average to less than 99.9).
    But it's much warmer here ... my morning commute starts at anywhere between 48 to 55 degrees and then in the evening it's usually around 55 to 70 degrees. I do much better on my evening commute, even though it's pretty much uphill.
  9. daniel
    14,487
    1,519
    Spokane, WA
    I was cruising around a parking lot for ten minutes at 6 mph, hoping someone would leave so I could park. As it was a rare warm (35-degree) day and the car was warmed up and the heater was off because the bright sun was keeping the cab warm, the car stayed in stealth mode the entire 10 minutes. By the time I gave up and left, I had two 5-minute segments of 100 mpg and my battery was at about half.
    It was cool because it was the first time I'd been able to turn the heater off, and so was the first time I'd seen extended stealth mode.
    I wonder if pedestrians can tell that the engine is not running. My dealer tells me there are 4 other 2004 Prius in Fargo. I've never seen any of them.
  10. USK
    USK New Member
    24
    Choshi, Japan
    I think ,
    it shows the engine providing power to the wheels and to the electric motor which is sending some to the battery.
    There are the two occasions.
    The One is the full power with bad mpg.
    The next is the high speed (over 42 mph ) motor mode when the engine start to need with no power because the THS System limitation.
    It may be over 150 mpg. in Japanese monitor about over 65 Km/L , so not 99.9.
    _______________________
    USK Bordeaux mica 2001
    20,668.29 miles / 353.55 ga. = avg. 58.5 mpg 3/5/04
  11. JasonS
    JasonS Jason Siegel
    53
    Is it possible your screen got "stuck?" On one trip the mileage wouldn't update for a minute or two even when I revved the engine or came to a stop.
  12. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    Hi Guys.
    The mileage will climb to very high numbers when 99.9 shows. That number is what Toyota chose to limit the display.
    My DynoDash SPD will show the ACTUAL MILEAGE at any time. (DashDyno isn't hybrid capable, standard OBDII only.)
    I got it before I got my 2004 Prius.
    I am going to buy this one. Tachyon H1 OBDII Scan Tool for Toyota Hybrids | Tachyon Technologies
    My Mini VCI won't work anymore, can't connect to ECU.
    I was surprised to see over 7000 mpg showing, momentarily until the calculations showed 6000 mpg + in EV mode.
    The mpg will jump all around like this until the engine resumes power output. Then it goes to a "normal" MPG.
    Over 41 mph , engine spinning, on slow down will get 250 mpg up and down mpg in EV mode, coasting or regenerating, the engine is spinning and not driving the car.
    I don't know what actually happens when the engine does this.
    Maybe the engine valves are cut off making the engine not pump air and not causing pumping losses.
    I haven't seen info this does happen though.
    It is amazing they actually spin the engine like this!
    It doesn't seem to slow the car quicker than when I am in a coasting mode.
    Keep up the GOOD Mileage
  13. bisco
    52,393
    what is the actual mileage when your sitting with the engine running? and when your gliding with the engine off? tia!
  14. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    (It has been 11 years since anyone typed in this thread)
  15. bisco
    52,393
    did we break a record?:cool:
  16. Mendel Leisk
    41,907
    When did Priuschat start??
  17. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    "Founded in 2003, PriusChat has been the go-to spot for Prius, hybrid, and EV discussion for over 10 years."
  18. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    There's an approximately 2+ mile portion of my 18 mile commute to work every morning, where, coming down a rather very long downward slope at 50mph produces a reading of 99.9mpg on my MFD with the engine running, so, this is entirely possible under similar conditions :)
    Huh?
  19. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    There is a section of the M54 motorway that on odd occasions I drive where for over 5 miles at 70 mph in cruise control where I register a continuous 99.9 mpg. The strange thing is some of this distance appears to be up hill, but I think this must be an optical illusion.
    There is a stretch of the M62 where this is readily done for well over 7 miles coming down off the Saddleworth moors towards Manchester. This however is most definitely a down hill run. This motorway is the highest motorway in the UK.
    John
    Data Daedalus likes this.
  20. bisco
    52,393
    i have been getting 999 mpg on 65% of my driving.
