Do I really Need A Charger?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by kenmce, Jun 15, 2013.
  1. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Don't actually have a Pip, looking at one for my next car. Can I simply have a 120 and a 240 volt outlet run to where I want to park, plug it in like any other appliance?
  2. Frank Perkins
    Frank Perkins Member
    129
    66
    Fairfield, Connecticut
    The prius comes with a plug that you can simply connect to your 120 volt outlet. If you already have a 240 line, then you just need to install a level 2 charger.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    To be clear, the charger is on-board the car. What you guys are referring to are EVSEs. The L1 120 volt charging cord set is also an EVSE.
  4. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    What they said, except you should know the 120v EVSE cord is nice and long. I plug into an 120 plug at the front wall of my garage and can still reach the back of the car where the port is. Given the small battery and relatively short recharge time, there's no real need to spend money installing a level 2 charger and a 240v plug. Highly unlikely to see a return on investment for that.
  5. CharlesH
    2,796
    1,162
    Roseville, CA
    In summary, the plug in the car itself is a special EV charging connector. The car comes with an adapter called an EVSE which plugs into the car at one end, and a standard wall plug on the other, and contains some simple safety-related logic which communicates with the charger in the car.
  6. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  7. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Yes, pEEf is somewhat well known here and more well known as Ingineer on mynissanleaf.com. There are thousands of satisfied Leaf customers of his.
  8. bisco
    51,141
    and his L2 conversion of your L1 that comes with the car is only a few hundred dollars. although, a separate L2 is good if you don't want to pack up your evse to charge elsewhere and they are coming down in price.
  9. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I did the L2 conversion on my portable EVSE and I'm very happy with it. I charge up from empty in about 1.5 hours.
    At work we have old paddle chargers but have 120v plugs added to the paddle chargers. I have the extension from the 240 plug to plug into 120 and the EVSE recognizes that it is only charging at 120v… and so it takes 3 hours to get a full charge. Pretty convenient and a lot less expensive than a 240v hardwired EVSE on the side of my house + permit + electrician install.
    cwerdna likes this.
  10. kenmce
    1,544
    515
    NY
    It sounds like I can just run a 120 and a 240 V outlet (it's as easy to run two circuits as one) and leave it at that for now. If the next car needs more than the 120 I'm ready.
    Thanks guys!
  11. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    On that note, there are adapters from the paddle style to J1772. My Nissan Leaf Forum • View topic - Avcon charging a Leaf! was an example of discussion on this. Probably not worth the $ for a PiP though...
