Do-it-yourself changing oil on the 2004 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by steve10brink, Dec 9, 2003.
  1. steve10brink
    steve10brink New Member
    Los Alamos, NM
    In looking through the owners manual on my new 2004 Prius I could not find anything about changing the oil yourself. Has anyone done this yet and, if so, are there any extra things to do? Is the oil filter difficult to remove?
    Thanks,
    Steve
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    There are a couple things...
    Word is that the filter is no problem.
    There is a special 'crush washer' that you need, and you'll need to get the right filter, of course.
    John1701A documented his experience with his own oil change on the 2004-YG
    http://autos.groups.yahoo.com/group/2004-p...s/message/18321
    --evan
  3. Jerry P
    Jerry P Member
    322
    Waterford, PA
    2021 Prius
    XLE AWD-e
    I have changed my oil already - went to Mobil 1 synthetic- and it is one of the easiest cars I have done. The filter is the same one used on the Corolla and Echo, Toyota 90915-YZZA2. You may notice a slight difference in the mounting end of the filter from one you buy here and the Japanese one that comes on the car. Parts dept. said that US made filter is slightly different at the mounting end but it is the right one to use. I'd recommend using only genuine Toyota filters, at least during your 60K engine warranty period. Also, save your oil receipt and mark the mileage and date in a maintenance log book. I am going to install a Fumoto drain valve on mine. This is a neat little valve that eliminates the possibility of stripping out the threads on the oil pan plug. Be sure to replace the 'crush washer' on the drain plug. It is designed for single use and may leak if not replaced.
    While you're under the car, take a look at how well sealed all the components are underneath. The build quality of the Prius is beautiful!
  4. green4evr2003
    green4evr2003 New Member
    32
    Pittsburgh, PA
    Changing Oil: Soo-o-o-o, can anyone please post the number of the American-manufactured (well, China, Mexico, Sri Lanka, etc.) replacement oil filter?
    Bruce Webster
    Green4evr2003
  5. Jerry P
    Jerry P Member
    322
    Waterford, PA
    2021 Prius
    XLE AWD-e
    90915-YZZA2
  6. texassalsa04
    texassalsa04 New Member
    123
    Dallas, Texas
    Jerry P...
    "...I am going to install a Fumoto drain valve on mine..." Jerry, have you installed the Fumoto Drain Valve on your Prius yet? I wonder how it looks after you installed it, whether the lever is in an ideal position so as to not get knocked on with rocks and such. Please keep us posted.
    I am seriously considering the purchase of the Fumoto valve.
    Thanks,
    Tony.
  7. Jerry P
    Jerry P Member
    322
    Waterford, PA
    2021 Prius
    XLE AWD-e
    Yes...I put it on Saturday. My oil level was a little too high so I drained it all and installed the valve. The angle of the drain hole is ideal. The valve does not extend much below the level of the oil pan and the handle is pointed towards the back of the car so stones and road debris shouldn't affect it. It locks in place anyway so I don't think there would be a problem anyway. I think it's a good investment.
  8. texassalsa04
    123
    Dallas, Texas
    Jerry P...
    Thanks for the response. If you can snap a picture to show us, that will be great!
  9. ammiels
    ammiels New Member
    121
    brewster, ny
    Fram sells a Gizmo for+/- $12 that purports to do the same thing. When the weather gets warmer here I will look into it. Peace, Ammiel
  10. FredWB
    FredWB New Member
    331
    San Diego, Colli-fornya
    The Fumoto sounds like a great deal. Especially when the gasket is $3.99 each! Do you have to order the valve online?
  11. green4evr2003
    32
    Pittsburgh, PA
    Where can I purchase the Fumoto drain valve? Is the "gizmo" mfd by Fram a suitable replacement or is it a CHEAP imitation?
  12. Jerry P
    Jerry P Member
    322
    Waterford, PA
    2021 Prius
    XLE AWD-e
    Fumoto.com is their site. I haven't seen them in any auto parts stores. The Fram item might be just as good but Fumoto has a reputation as being the best so I went with them.
  13. davidbw
    davidbw Member
    110
    29
    In front of my computer
    I believe their website is fumotovalve.com, not fumoto.com.
  14. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Hopefully with my next oil change in 1,850 miles I'll be able to add photos to my documentation. Doing that the first 2 times with my 2004 was completely out of the question... in an unheated garage during this winter here in Minnesota.
    It's pretty darn easy, once you see where everything is and what tools are needed.
  15. green4evr2003
    32
    Pittsburgh, PA
    Finally found the Fumotovalve.com web page. Can someone please tell me which is the corect model number?
    Bruce Webster
  16. Doug
    Doug Junior Member
    33
    Indiana
    2013 Prius Plug-in
    Is it the F103 Fumoto valve that you bought? I just want to make sure I order the right one since their web page didn't say for a Prius exactly. Changing the oil to synthetic by myself should cost less than $20.00 but having the dealer do it would be over $50.00 I believe.
    Is the oil filter by Toyota better than a Fram?
  17. green4evr2003
    32
    Pittsburgh, PA
    Doug: My last posting was a question. I was trying to find out which Fumoto drain valve is the correct one. So far no one has answered my post.
    Bruce Webster
  18. green4evr2003
    32
    Pittsburgh, PA
    This one's for FredW8 regarding the necessity of purchasing the crush washer - I trust that's what he was talking about when he referred to a price of $3.99. I bought a replacement filter for my '04 Prius the other day and they gace me the crush washer at no cost. The filter was just a trifle over $5.00.
  19. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Last time I bought the crush washer I paid $0.99 per at Tustin Toyota.
    I need to do a change today. Going to try a Fram Tough Guard filter - but I need to get the crush washer. Anyone tried changing and reusing the old washer?
  20. tochatihu
    tochatihu Senior Member
    9,059
    3,529
    Kunming Yunnan China
    2001 Prius
    <div class='quotetop'>QUOTE(htmlspinnr\";p=\"76273)</div>
    Not I. Obviously not the recommended thing, but if you are willing to look down there afterwards to confirm not dripping, you may get away with it (just this once). Please do not overtorque the drain bolt to compensate.
    Um, if you are going out to buy this Fram filter, ask them for a fiber washer that is about 11 mm inside and about 20 mm outside.
