Do Outside Door Lock Buttons Wear Out
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Warcat, Aug 15, 2021.
  1. Warcat
    Warcat New Member
    I have a 2006 Toyota Prius with the smart key. Recently the outside door lock button on the front driver's side door has stopped working. I am the only one who drives it, and so this is the button that gets the most use. To lock the car, I have to use the passenger side button or the hatch, or use the lock button on the fob. If it does need to be replaced, can someone please tell me where I can find a replacement? I searched online, but cannot find anything. Thanks!
  2. JC91006
    16,827
    8,600
    How do you get in the car? does it unlock?
    You can lock the car with the lock/unlock switch next to the power window switches, press it when you exit the car
  3. Warcat
    Warcat New Member
    Yes, the car unlocks just fine. I touch inside the door handle and it unlocks with no problems. Also, the left door lock button has started to work, but it is very spotty. I replaced the battery in the fob, but that did not seem to help.
    52,368
    how is the 12v health?
    you could ask a dealer parts department
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    The thing that usually fails is the "solenoid" actuator that actually moves the lock mechanism.
    But it is hard to tell that while it is in it's "intermittant" phase.
  6. dolj
    dolj Senior Member
    8,553
    4,343
    Wellington, New Zealand
    Seeing as the door locks fine from the other lock buttons, it is not likely to be the door actuator.
    The button going faulty is looking like the most likely culprit although I can't recall anyone else reporting such a failure.
    Have you tried your local Toyota parts department?
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    Sure. If and only IF that test result is consistent and repeatable.
    When mine failed, it was not.......and exhibited several different results over the first couple of weeks.
  8. Warcat
    Warcat New Member
    Now it's started working fine again. Who knows? Electronics just act wiggy sometimes, I guess.
