Do Prius C wheels work on a Gen 1?
Discussion in 'Generation 1 Prius Discussion' started by Chuck Wagon, Mar 7, 2015.
  1. Chuck Wagon
    Chuck Wagon New Member
    2003 Prius
    I
    If there is one nit picky thing about my wife's 2003 Gen 1, that both she and I have pointed out. It looks like the PO played bumper cars with the OEM wheels going in & out of the Starbucks drive through. Every wheel is badly curbed in some way or another. Repairing the wheels at $100-150 per wheel is not worth entertaining, since my wife doesn't really like the machined/ polished look of the OEM Gen 1 wheels anyway.
    I saw a brand new 2014 or 2015 Prius C the other day with some tasteful OEM alloys, after researching I found that the Prius C has the same 4x100 bolt pattern as our Gen 1 (Classic Prius). I like the design, and could probably score a full set with good tires for a song. But before I look deeper into this, will I run into any fitment issues with my Gen 1?
    The Prius C appears to ride on 15" wheels as opposed to the 14" size on the Gen 1 cars. I worried about my speedometer being off, and a mpg penalty for going with the 15" size, unless Toyota somehow made the 15" Prius C wheels lighter, considering those cars have less hp than our classic versions.
    I really wish I could get some Gen 3 black wheels, that I've seen out there. I believe these are the wheels that normally are covered up by a silver wheel cover. Too bad they switched to the 5-lug pattern for the 2nd & third gens.
  2. ChapmanF
    15,459
    Maybe the wheel you were looking at is the 42611-52A00 shown here for the 2012 c?
    I see that it's a 15x5J, where your original is 14x5.5JJ, and looking it up aftermarket shows it has a 39mm offset, as opposed to the original 45mm. (The 6mm offset difference is about what you'd expect taking half an inch off the width). Maybe no one will have tried it on a Gen 1, so it might be worth trying to borrow one, and make sure it doesn't interfere with the brake calipers, etc.
    The original spec tires are P175/65R14, and increasing the diameter to 15 while taking the aspect ratio down to 55 ought to give you roughly the same outer diameter and revs per mile. And looking around, 175/55R15 does seem to be a real size, there are some tires in that size ... but they are load rated around 908 pounds max.
    I looked hard into the Gen 1 tire load requirements a few years ago and the upshot was that the per-tire (front) load is 985 pounds at the car's maximum load, and 947 pounds (front) at the "normal" load used for the safety standards. The Federal Motor Vehicle Safety Standards (the easy bar to meet) says that normal load has to be <= 94% of the tire's rating, which working backwards requires a tire rating of at least 1008 pounds. To meet the higher bar of the Tire and Rim Association standard (the Gen 1 didn't, as equipped), the normal load has to be <= 88% of the tire rating, which would require a tire rating at least 1076 pounds.
    You're gonna need a bigger tire.
    -Chap
    Chuck Wagon likes this.
  3. ChapmanF
    15,459
    By the way, I was getting quotes on wheel refinishing recently, and the outfit I talked with had one price for recreating the original painted-pocket/machined-face look, and a lower price to just do the all-over-silver-paint look (which would be a lot like that c wheel). Maybe that would be an option?
    To me, taking a nice alloy wheel and spraying it silver all over just makes it look like a plastic wheel cover, but then you're not married to me.
    -Chap
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    I am glad that now I know the Gen 1 Prius has the 4x100 pattern like my C. More wheels to look for. But I want to stick to 15s.
  5. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    720
    Boulder Hybids, Boulder, CO
    If you get used Gen1 wheels from a state where they don't salt the roads they can be quite nice, but shipping could be expensive. AdoptAPart in Denver has plenty of used Gen1 wheels. (they don't use salt in most of Colorado) If you are non-local, ask them to email you pics before you buy.
  6. Chuck Wagon
    2003 Prius
    I
    Thanks for the responses guys, and thanks Chapman for putting in the leg work on the tire sizing.
    I don't mind the OE Gen 1 machined look wheels, but my wife hates to have a chrome or polished looking wheel on her car. (Yeah I have one of those 1% wife's that are picky about specific things on her car).
    I thought the solid, painted silver or gray wheel that comes on the Prius C would look clean, and potentially update my Classic Prius's look.
    Going to a 15" or larger rubber though wouldn't be an option for us though. Does anyone know of any Hybrid friendly, aftermarket wheels that look good on our cars? And will allow use of the stock tire size?
  7. Chuck Wagon
    2003 Prius
    I
    I think the Prius C wheels I saw were the 16x6 style in your link, but I didn't know they were 16's though at first glance.
    This was a pretty loaded C, that I saw that wheel on, had a sunroof and possibly leather, looked a bit more loaded than the usual Prius C's I see with either (black) steel wheels or a hub cap.
  8. kingnba6
    1,018
    242
    NY
    The C has 2 options: Steelies and Alloy wheels. Steelies are 15" and Alloys are 16". Alloys only come on the model 4, I believe.
  9. ChapmanF
    15,459
    The 42611-52A00 is a 15" alloy, and shown in the dealer parts catalog for the c. I'm sure I don't know what combination of trim level/options/magic words were needed to obtain it, but there it is. To my own taste it's nicer looking than the 16" with the hey-look-at-me twisty spokes. Here it is in the wild....
    On the other hand, it looks a lot like a Gen 1 wheel would look if you painted it all-over silver, which might be the simple option here. When I was getting wheel-refinish quotes, all-over silver was $15 less (per wheel) than redoing the silver/machine/clearcoat look. Then you'd know you had the original spec'd wheels and tires, and it should even be easy to bring back the OE look later if you want. (I'm pretty sure the OE finish steps were: 1. spray silver all over, 2. machine faces back to clean metal, 3. spray clearcoat. The all-silver option just omits some steps.)
    -Chap
  10. messenger
    messenger Junior Member
    30
    Fairfield, IA USA
    Here's a $15 solution: 2 cans of Dupli-Color wheel paint and a couple of sheet of 100 grit sandpaper.
    This paint has been on for a year a still looks fine. These wheels looked funky when I got the car with some rash and pealing original finish.
    If you are replacing you'll also want to consider wheel weight, lighter is better and these stock wheels are very light.
    Tim
