Do the brake pads/shoes last forever?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dilbert, Sep 2, 2012.
  1. Dilbert
    Dilbert Junior Member
    44
    Seattle
    I have had my 2nd gen since 2004 and do all the maintenance myself. I checked the brakes again at 95k after changing the oil and they are still good. I may have replaced the front pads, but I know I did not replace the shoes in the back. My records show no brake replacements. Had anyone else had this experience? The only real repairs it has needed has been the inverter water pump under warranty, and I did the regular water pump this year.
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    They don't last forever but there are many reports of them lasting way past 100,000 miles before replacement (obviously depending on use patterns).
  3. mcmoyer
    mcmoyer Junior Member
    71
    Fort Worth, TX
    Mine had 127K on it when I last checked the brake pads. Had about 40% pad left. I'm a mostly highway driver though.
  4. TN Traveler
    TN Traveler Member
    32
    31
    I just had my 65K service done and the rear pads were killed, almost to the metal, my car makes weekly trips between Bristol TN and Raleigh NC so it is a interstate cruiser. The service tech said it was common for highway runners to do that, said the perportioning? valve used the back brakes more on light application like you do at higher speeds, I don't know about that but I saw the pads and scuffed rotors, cost mo $202.00.
  5. fuzzy1
    10,149
    Some of us have achieved just over 100k miles on the original brakes of non-hybrids. But large numbers of Prius drivers have reported that and far more. It depends strongly on usage and driver style.
    xs650 likes this.
  6. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Was than on a Gen 2 or Gen 3? We have a mix of vehicles in this thread.
  7. jdenenberg
    jdenenberg EE Professor
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 Prius is at 237k miles on the original brakes, but they don't last forever even though it seems like they do.
    JeffD
    mikesarebetter likes this.
  8. Rest
    Rest Active Member
    1,210
    53
    CA
    Front brakes with always wear out faster than the rears, because they do the majority of a vehicle's stopping power. But as what was previously stated, brake wear depends strongly on usage and driver style.
  9. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    It depends on the vehicle. There are many decisions and compromises made in the design of any vehicle system. On some cars the rears are sized so they wear out first.
  10. Klaatu
    Klaatu Junior Member
    32
    17
    New Jersey
    Just replaced the rear brakes on my wife's 2007 Camry Hybrid at 117,000 miles. Front brakes still OK.
  11. mcmoyer
    71
    Fort Worth, TX
    Gen 2 - 2008 model
  12. ETC(SS)
    6,540
    I took my 06 Envoy in for brake work @ 126k since I was getting "the squeak."
    I can and do work on brakes occasionally but I have a tire guy that I trust to be honest and capable.
    My bill was $10.
    The squeak turned out to be FOD in my front caliper.
    He says I still have about 50-percent of the pads, the rotors are still true, and the fluid is still OK.
    He just did a little cleaning.
    Take Away: If you're a moron...or you drive like one...then it's unlikely that you're going to get >100k miles out of your brakes. Even in city driving, you can get a lot more wear out of your brakes if you drive green.
    Hypermiling doesn't apply just to Priuses...and it's benefits aren't just lower fuel bills.
    YMMV..... ;)
