Do the brakes need adjusting?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Drifter, Jan 2, 2007.
  1. Drifter
    Drifter Member
    102
    chicago area
    When I brought my prius in for an oil change last week the service writer said "wow, we've never adjusted your brakes before, we'll have to do that." I thought I had read that the brakes were self adjusting on the prius, though I'm not sure about that, and I haven't had any problems with them so I told him no, I'd have it done later. Is this something that needs to be done occaisionally? I never had the brakes on my previous car adjusted, though I could see needing it once in a while with the prius since the brake pads are supposed to last so much longer. I just hit 25000 miles and that was all this guy was basing his suggestion on, he didn't actually look at the brakes or anything. Should I have this done either at the dealership or at the shop I got brakes for my last car at, or was he just trying to make some extra money off of me?
  2. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    No adjustment needed. Keep your money. Buy some ice cream :) .
    Wayne
  3. tochatihu
    tochatihu Senior Member
    9,060
    3,529
    Kunming Yunnan China
    2001 Prius
    Front disk brakes are entirely self-adjusting. The shoe-drum clearance on the rear brakes is adjusted automatically by applying brakes while driving backwards. This system, while in wide use and certainly clever, may get the shoes too close. They can be reset manually but it is not necessarily the case that you needed it.
    Anybody who is about to participate in a fuel economy contest out to first make sure that the shoes are well clear of the drums, and them not put the brakes on in reverse because this will 'readjust' them. After winning, you can hit the brakes while reversing and get the shoes in close again.
  4. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :) There's a small possibility that the parking brake cable may need adjusting after many uses. Seems that over time the cable may stretch a little, but adjustment of the disc front and drum rear brakes should NOT need dealer adjustment.
    As previously posted "Keep your money."
  5. Drifter
    Drifter Member
    102
    chicago area
    Thanks for the replies. It seemed fishy to me. When I mentioned that I thought they were self adjusting brakes the service writer made some comment about how toyotas aren't like american cars and when I said I'd get it done somewhere else later (after asking if was going to charge me for the adjustment) he said I wouldn't find anyone who would adjust them for free. I don't mind paying for work my car needs, but I wasn't going to be bullied into something that didn't even make sense.
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(Drifter @ Jan 2 2007, 02:15 PM) [snapback]369659[/snapback]</div>
    I can't remember when brakes weren't self-adjusting. Sounds like your Toyota dealer is either greedy or ignorant. I'd find another shop.
  7. klevitsky
    klevitsky Junior Member
    34
    I'm a little confused:
    If the brakes did need adjusting on a 2005 with 25,000 miles, wouldn't it be covered by the 3y/36,000 warranty on the car, thus negating any greed on the dealer's side? Or does it cross into some other category, like wear and tear? Perhaps my understanding of the warranty is flawed, but I thought if anything goes wrong with the car (outside negligence, accidents, etc) the dealer has to keep the car in shape until the warranty runs out. Unless they can show that something you did, way out of spec for average drivers, to cause the malfunction.
    Help me out, thanks.
  8. malorn
    malorn Senior Member
    4,281
    59
    &quot;Somewhere in Flyover Country&quot;
    <div class='quotetop'>QUOTE(Drifter @ Jan 2 2007, 08:46 AM) [snapback]369549[/snapback]</div>
    Brakes do NOT need adjusting and cleaning. My stores do NOT sell that maintenance item.
  9. Drifter
    Drifter Member
    102
    chicago area
    <div class='quotetop'>QUOTE(klevitsky @ Jan 3 2007, 12:14 PM) [snapback]370093[/snapback]</div>
    This would be considered a general maintainence thing, like oil changes, and would not be covered under warranty. I didn't even ask how much he was going to charge, just IF he was going to charge me to do it, and I said no.
    As far as looking for a new dealer, this is already the second one I am trying out. I got into a near shouting match with the service writer at the first one when he insisted I was doing major damage to my tires when I asked them to be inflated to 38/36 and then told me they couldn't do the oil change if I only let them put in (and charge me for) three quarts of oil. Of course as I was walking out someone else assured me that my requests could be met. I'm not giving up on this dealership yet but if I do I think I'll just start going to Jiffy Lube. Thats where we bring our other car and have never had a problem. I just didn't think they would have enough prius experience back in 2005, but there are more priuses out there now.
  10. JimN
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(Drifter @ Jan 3 2007, 04:46 PM) [snapback]370340[/snapback]</div>
    The consensus here is 3.5 quarts of oil. My tp is 42/40. Wonder what my dealer will say.
  11. trilect
    trilect New Member
    26
    Not sure if this applies to the prius or not but in my past experiance all cars with self adjusting brakes could need manual adjusting depending on the driving habits of the owner.
    What I have always done was to adjust the brake adjusters (special tool used) until the tire was locked and back the adjuster off 5 or 6 clicks.
    If you notice that you have little emergency brake left or that the front disk brake pads are wearing fast it may be time to adjust the rear brakes on your car. I usually adjust all my cars rear brakes every 12000 miles or so.
  12. Charles Suitt
    1,637
    16
    Dallas TX
    <_< I do recall that a brake adjustment was made on my 2004 Prius [now up-traded to a 2007 Touring]. I had commented on a 'clunk' sound in the rear when brakeing at low speeds as I pulled to a full stop.
    My Dealer's Service Dept. made NO CHARGE for that adjustment. The 'clunking' stopped.
  13. viking31
    viking31 Member
    515
    22
    West Central Florida
    <div class='quotetop'>QUOTE(Drifter @ Jan 2 2007, 09:46 AM) [snapback]369549[/snapback]</div>
    We don't need no stinkin' friction brakes on a Prius!
    Seriously though, many people have posted how their mechanics were surprised by how LITTLE wear the brakes get in the Prius.
    If your dealer must check and adjust the brakes then make sure he also checks the Van Dusen pump and replace the muffler bearings too ;-).
    Rick
    #4 2006
  14. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(viking31 @ Jan 5 2007, 09:40 AM) [snapback]371307[/snapback]</div>
    But insist that he show you the parts he installed and the parts he removed.
    Not that I don't trust that dealer, mind you.
    Dave M.
  15. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    My shop wants to rotate the veeblefetzer. What do you think. I thought it was self rotating.
  16. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    If you never use the parking brake, perhaps true. I use my parking brake all the time, and the shoes are right in spec. You know the old saying: use it or lose it
    <div class='quotetop'>QUOTE(malorn @ Jan 3 2007, 11:32 AM) [snapback]370110[/snapback]</div>
    Not unless you were dumb enough - like I was - to special order a very expensive 2000 GMC Sierra SLT extended cab 4wd to tow a 6,800 lb camper: towing package, 4.10 gears, G80, etc.
    Never mind the knocking, oil burning 5.3 Vortec V8. Never mind the chattering G80 locking rear end. And you can even ignore the parking brake pedal return spring that went SPROING and broke the VERY FIRST TIME I USED IT!!
    :angry:
    You can even pretend my rear axle pinion seal didn't spring a leak one week after I got the truck, leaving a puddle of gear oil in my garage. Or how both rear seals were shot after 3 years, good 'ole American Axle & Manufacturing axle.
    What really got to me were the four wheel disk brakes, how the rear calipers managed to seize after the first year, ruining the pads. That was a "maintenance" issue not a warranty issue, around $260.
    There was no mention of any requirement to clean and lube the caliper slide pins/sleeves, despite having road salt here in winter. I guess I should have been able to use my psychic ability to detect the seized caliper.
    Oh, and never mind that the joke known as the "drum in hat" parking brake needed adjustment every 6-8 months or it wouldn't hold. I was told it was my fault, as you're not supposed to use the parking brake all the time.
    Oh, maybe it should be renamed "emergency brake" or "accessory not actually perfected just yet?"
    The "drum in hat" shoes managed to wear out at 68,000km, conveniently off warranty. Another $600. I noticed a couple of years after I got my truck, GM switched to rear drums on most of their half tons.
  17. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    the rear brakes are supposed to be self adjusting.
    "supposed"
    in actual usage, generally they're not. perfectly anyway.
    if you use your parking brake all the time you're not gonna break anything. in fact, you'll prevent breaking the mechanism, for all you northerners.
    now the easiest way to tell if you're in adjustment or not, is to jack up the wheel you want to check. spin it. if it spins free, you're good for one criterion. if you hear a very light drag sound, you're still ok for now. reach back along the axle and feel for the e-brake cable. it's somewhat flexible and is not attached to metal brake lines. it's not a hydraulic part. it runs into the back of the drum on the lower half of the drum. spin the wheel, then pull on that housing (not yank on it, just flex it) to tighten the cable. the wheel should stop. if these criteria are met for both rear wheels you're in perfect adjustment for the brake end.
    the next step is checking cable adjustment. go to your e-brake pedal and push down on it. count the clicks. it should be no less than 5 and no more than 14 with normal force used on the regular brake pedal. ideally, 5-6.
    typically the adjust is a "clean and adjust" where a light sandpaper is used to remove glazing from the drum and shoe surfaces. it's your call. however, out of adjustment rear brakes directly affect front brake pad wear. just fyi. i know that's about 5 times more than you were asking for :lol:
  18. John in LB
    John in LB Life is good
    399
    27
    Orange County
    I can attest that you definitely need to adjust the back brake drums. At 18,000 miles and hardly ever using the emergency brake - they were way out of adjustment.
    The way I could tell was that the emergency brake almost went to the floor when pressed. More importantly, my regular brakes where a little late in responding and felt a little grabby (I presume that's because it took a significant amount of brake fluid to fill the actuators prior to the brake pads making solid contact.)
    As some other posts indicated, I took off the wheels and the drums and adjusted the spinner by hand. Using a little bit of trial and error, I got the brake pads to rub slightly on the drum. It was pretty easy to do.
    After adjusting the brakes, the emergency brake pedal was much firmer (as galaxee said: 5 or 6 clicks did it) and did not require a cable adjustment. In addition, brake pedal feel returned to normal and was much smoother.
    Some people were asking how often you should pump the emergency brake to keep the brakes adjusted. Based on the number of teeth on the spinner (about 30) and given that each pump of the emergency brake rotates the spinner by 1 tooth, I would say that about every 200 miles you should pump the emergency brake once. If you want to do as galaxee suggests.... 3 times at one time.... then do that every 500 miles. That should keep you close to being adjusted.
    Me, personally, I like doing it by hand and plan on doing it every 10,000 miles - at the same time I am rotating the tires (I rotate every 5000 miles).
  19. richard schumacher
    7,663
    1,038
    United States
    Sounds like Yet Another good reason to always use the parking brake. It's not an "emergency" brake if you can't count on it working in an emergency.
    I was disappointed when a service writer at my favorite dealer told me today that the rear brakes are not self adjusting, and need to be manually adjusted every 5K miles, for their low low price of $30.
  20. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Wow, another thread back from the dead.
    Tom
