Do the rough cold starts hurt it?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Liz M, Oct 23, 2016.
  1. Liz M
    Liz M Junior Member
    Albany, NY
    I've read a bit here on the forums about the cold soak starts for the Gen IIIs----I had one episode last winter where it sounded like a helicopter when I started it, and now that the temp is crashing her this week, my engine makes a bit of an angry sound (not terrible, but mildly concerning) until I speed up enough (around 20mph).
    My question is- does this hurt the car at all? If so, what can I do differently to prevent it? Wait til the engine goes quiet to turn it off?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    How many miles on your Prius? When does the sound happen, or what commonality would you say lends to the noise and rattle other than cold ambient temps? Are you moving driveway spots?
    Best to let the Prius go through its warm up cycle before pressing the power button to turn it off.
    orenji likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Btw it does harm the engine
    Raytheeagle likes this.
  4. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    What exactly is happening?
    What exactly do you think is being harmed?
  5. bisco
    49,379
    i don't think what you're hearing is a problem. the one episode you had is best to be avoided in the future, if at all possible.
  6. tankyuong
    1,555
    660
    Central MO
    Continuous knocking will eventually blow a head gasket
  7. orenji
    orenji Senior Member
    5,884
    3,486
    Always let the ICE shut down before turning off the car. This should solve any further engine knocking.
  8. RichardScarry21
    RichardScarry21 Junior Member
    Missoula, Montana
    Synthetic Oil (I recommend Mobil 1 0W-20) helps to some degree. As the oil is going to be less fluid during the cold starts, it's not getting to all parts of the engine as quickly. Synthetic oil is quicker to get to the entire engine.
    I don't know much about that sound.
  9. Mendel Leisk
    38,648
    The one time I experienced knocking after start up was after cold-starting the previous day, and only running for a couple of seconds. This seems to be a cause-and-effect that a lot of owners experience.
    If you experience knocking at start up, I would suggest to immediately turn it off, wait a few seconds, and restart. This dispelled the knock for me, the one time I experienced it.
    And to (hopefully) avoid the situation, avoid the few-seconds-start-up-on-cold-engine.
  10. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    So, regarding letting the engine complete it's cycle and turn off before turning the entire Prius off - is this just a 'common sense / sounds like a good idea', or do we know that this is best practice and why?
    Thx,
    - P
  11. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Experience;).
  12. Mendel Leisk
    38,648
    As mentioned above: the one time I've experience this knock at start up is after running the engine cold, for just a couple of seconds. Starting up the next morning: got the knock.
