Do Yaris door sill protectors fit a 2016 Prius C?
Discussion in 'Prius c Accessories and Modifications' started by priusmatty, Jul 1, 2016.
  1. priusmatty
    priusmatty Active Member
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Anyone know? Thanks.
  2. djdawn
    djdawn Active Member
    256
    116
    Escondido, CA
    2014 Prius c
    Any particular ones you're looking at? Normally I'd assume no and get the Aqua/C sill protectors. Is there a huge price difference between the Yaris ones and the C? I'd assume the Yaris types would have Vios or Yaris branding on them as well.
  3. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Well, the only C ones I can find are illuminated, and I do not want that. I just want simple door sill protectors, but I cannot seem to find any. Good point on the Yaris branding: I would not want that.
  4. djdawn
    256
    116
    Escondido, CA
    2014 Prius c
    Could not wire the led portion of it, just tuck the wires under the wire routing things at the side of the car. Leaves the option open in case you wanted to do it later.
  5. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Ok. What are the wire routings at the side of the car?
  6. djdawn
    256
    116
    Escondido, CA
    2014 Prius c
    I don't know the official and of them, but they cover up the tubes (wiper fluid?) that run to the back, as well as some other wires. On the driver side, it's that same cover that connects to the footwell covers, that are just below the fuse panel.
    priusmatty likes this.
