Do you change your oil every 5000 or 10000?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Jan 1, 2020.
  1. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    This thread is not to discuss which is better. There is already a sticky thread going on about it.
    I am just curios myself. I have 2010 Prius III that I bought at 142k. It is now at 165k. I have been changing the oil (Mobil 1 synthetic 0W-20) and the filter (OEM) at every 5000miles.
    I didn't know the Toyota officially revised the change interval to every 10000 miles. I saw the thread just a few months ago. And I was surprised to be honest.
    My last oil change was in past October 19 (less then 3 months ago). It has been 5000 miles already. I normally go 6 months (about 1000miles per month). This time, it went by too fast because I have done two long-distance trips that claimed half of that 5000 miles. The other 2500 miles is for normal city commuting back and forth to work.
    I wonder what my fellow Prius owners do for their oil change:)
    P.S. My car doesn't burn any oil. The OCC collects just a little (2 ounces max.) at every oil change and it is not milky.
    52,790
    i would go every 10k, but since i only drive about 6k a year, i do it every spring. my mechanic thinks i'm crazy.
    Analyst likes this.
  3. frodoz737
    frodoz737 Top Wrench
    4,795
    2,560
    33
    This fellow owner (and career Mechanic) changes his Prius oil/filter at 5,000 miles using Toyota 0w-20 synthetic and Toyota filter.
  4. ASRDogman
    ASRDogman Senior Member
    8,050
    4,082
    Okay, split the difference, 7500 miles. :)
    I do 10,000. Just did mine at 190,000. It was just starting to get dark.
    Analyst likes this.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,788
    Bay Area
  6. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    5k for me. My last sampling at 5k showed “possible” coolant contamination, just enough to be detected. They recommended another sample done at 5k to rule it out. I haven’t lost any coolant that I could tell, so I’ll see what happens in about 1200 miles.
    m.wynn and TheeWood like this.
  7. fuzzy1
    10,687
    I seem to remember the announcement coming out in late 2009.
    I typically change the oil at some convenient time somewhere in the middle of those mileage ranges. No simultaneous tire rotations, I do that with my winter/summer tire and wheel swaps.
  8. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    Every 5000
    m.wynn likes this.
  9. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    1 yr comes way before 5k mi on our v, so it's once a year for us, Mobil 1 Annual Protection with Fram Ultra.
    moto g(7) power ?
  10. Mendel Leisk
    42,286
    For third gen Toyota Canada stuck with 6 months or 8000 kms (5000 miles), whichever comes first. I follow that, and we're lucky to do 8000 kms yearly, so 6 months governs.
    With fourth gen Toyota Canada's switched to be in line with the States, the longer intervals, but I would stick with the old interval. Maybe overkill; I don't care.
    m.wynn, Tim Jones and frodoz737 like this.
  11. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    In Europe we have the 15k km (~10k miles) for most of the Toyotas since around 2000, so I don’t change it more often.
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Change X < 15,000 mi or yearly.
  13. iskoos
    415
    254
    Orlando, FL
    If they announced it in 2009, how come all the Gen3 cars have 5k-mile interval programmed on the on-board computer?
    Or was it for 2010 models only not the later Gen3s?
    douglasjre likes this.
  14. bisco
    52,790
    5k maintenance, does not necessarily mean oil and filter.
    it matches your maintenance schedule, every 5k or 6 months, whichever comes first
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Reminders for tire rotations and other maintenance / inspections. Although some feel that if a shop changed their engine oil, they don't need to check it at all until it's in the shop for next oil change. See my signature for more info.
    m.wynn likes this.
  16. fuzzy1
    10,687
    So that you don't forget the other maintenance items that still need attention at that interval, including checking the oil level. Here is the 2012 Liftback's list:
    RMB likes this.
  17. iskoos
    415
    254
    Orlando, FL
    Himmm… Though the computer specifically says "Oil Maintenance Required", Maybe something like "5000mile Maintenance Required" would look better. But I see why Toyota didn't change the interval to 10000 now.
    This also reminds me that I need to rotate the tires. :)
    fuzzy1 likes this.
  18. fuzzy1
    10,687
    Up north here, tire rotation is 'free' when doing my winter tire swaps, but costs me extra labor any other time. So that is why I've separated it from the oil changes and do it at a different time.
    But this plan isn't useful in Florida ...
  19. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    It always puzzles me to see how different maintenance schedules are on different sides of the Atlantic ocean.
    Since a very long time Toyota has a 15000km (9375 miles) service interval.
    Toyota has the shortest intervals since most European and also other Asian brands use 20000 or 30000km intervals.
    Verstuurd vanaf mijn LYA-L09 met Tapatalk
  20. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    I just split the difference and change it at.7500 miles...
