Do you find your right leg tense sometimes while driving?
Discussion in 'Gen 2 Prius Main Forum' started by SynergyGuy, Feb 22, 2005.
  1. SynergyGuy
    SynergyGuy New Member
    55
    After driving for some period of time I am finding my right leg (calves) to feel a bit tense. I believe this is probably due to the following two aspects:
    - The permanent attention and particularly the feather touch style that I try to apply to the gas pedal in order to obtain the most fuel economy. This requires you to constantly have your right foot lifted-up.
    - The other possible reason I'm thinking is because the right leg never gets to stretch fully (I'm 5'10'') and consequently muscles are in constant tension. Part of the ergonomics in the Prius have not accounted for tall drivers, I really wish the driver's seat could be pushed back more to allow for a more relaxed driving. This would inherently require the retractable steering wheel feature to be added.
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i cant say i feel your pain since 90+% of the time i am using cruise control for all driving conditions
  3. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    I have been putting the car in neutral instead of 'feathering', as I have never been able to feather over 40MPH. Would be good for extended 'feathering' as well. Just remember to put it back to Drive when you need to brake, or you might not get regen.
  4. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    Up to what speed Dan? I limit mine to 56 mph in neutral.
  5. ltu1542hvy
    ltu1542hvy New Member
    338
    Cotonou, Benin
    Re: Do you find your right leg tense sometimes while driving
    I do feel your pain, but for me it is more my shin (I think) that starts hurting rather than my calves. This generally happens after extended city driving. On the highway I use the cruise control, but for driving around town I generally do not, and after driving on non-highways for an extended length of time (half an hour or more) my right leg can start feeling tense and start hurting.
    - Bill
  6. DanMan32
    3,799
    26
    Tampa Bay, FL
    I don't think it really matters, or else Toyota would have designed it that you couldn't just drop it in Neutral at excessive speeds, or require a special step to accomplish. I don't consider holding it at neutral for 2 seconds 'special', the delay is only so it knows you meant 'N' and were not passing through to 'D' or 'R'. All neutral does is turn off the motors, thus they will free-spin.
  7. heliotropehead
    heliotropehead New Member
    701
    New Orleans, Louisiana
    So you're driving in neutral??
  8. LeVautRien
    LeVautRien Member
    379
    New Orleans
    I'm 6'2 and I also get some shin pains, but not calf pains.
    EDIT: But come to think of it...I get them in all cars, heh.
  9. DanMan32
    3,799
    26
    Tampa Bay, FL
    No, coasting. Can't drive in Neutral. There has been a thread on this. No different than 'feathering' to neutral, but less painful.
  10. jkash
    jkash Member
    889
    West Hills, CA
    6'3" here, and my shin is what hurts sometimes as well. Got to say I love the cruise control on the highway. Makes driving much less stressful, especially doing the 700 miles we did on Sunday.
  11. Marg
    Marg New Member
    155
    Eastern Ontario, Canada
    5'3" here, and I also get shin pain from time to time.
    My 6'4" husband never does. Go figure!
  12. Hatfield
    Hatfield New Member
    91
    San Diego, CA, US
    I notice it more in my thigh than my shin. I'm not sure if the weird throttle pedal feel is the issue. I thing a bigger issue is just that the seats are not well bolstered at the leading edge, and they don't provide very good leg support. Took some getting used to.
    I've been using the cruise control a lot lately too. I'm not sure if it's as effective as trying to feather, but it's a lot less work. My averages have gone up, too (course that might just be the engine breaking in).
  13. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    I had the same problem you describe; my leg got tense because there was no place to rest my knee. The tension comes from trying to hold my leg and foot off the pedal with no place to rest or support my knee. I'm a tall person, 6'2", and I discovered early on that I needed a cushion under my butt because the seat did not offer enough thigh support. I found a relatively thin cushion (too thick and my head was on the liner) with a rubberized backing that keeps it from sliding off the seat when I get in and out. I got two so that the front seats have matching color cushions. Solved the problem. The additonal support at the thigh allowed me to hold my foot off the pedal without straining. Cruise control is a godsend.
    I would like to see Toyota add a slight riser at the front end of the driver's seat to provide that extra thigh support. Other than that, I think the seats are comfortable.
    B
  14. Tideland Prius
    16,072
    Tense? sometimes... especially after feathering for a while =Þ
  15. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I also use cruse control a lot because I have two numb feet after back problems. Surgery took care of the pain but the sensation never came back. Makes it hard to have that light touch on the accelerator so I let the cruse control do it for me.
  16. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i agree with the thigh support problem. it seems that the front of the seat is just too low for the body angle. unlike sports cars where you recline back more, the Prius is more of a vertical position but (for me at least) leaning back makes it tough to reach the steering wheel.
    as i mentioned, i use cruise control all the time and i usually have my foot resting flat on the floor so no discomfort for me even on long trips.
  17. fred
    fred New Member
    235
    nashville
    guys! guys! guys! im shocked :crazyeyes: . i have such great respect for my fellow prius owners but fellas as matter of control never use neutral to coast. its a matter of having complete control over your car at all times.i may be in the minority nowadays on this but as a car guy who loves driving even better than...hey wait a minute i dont go that far! anyway one of the joys of driving is being always in comlete control with no surprises. neutral for me does not, will not and never has added control. its just not a good habit to get into. and what the heck does it really accomplish.ooops gotta go thyre coming for my soapbox now. :) :)
  18. sfmark
    sfmark New Member
    San Francisco, CA
    Regarding the thigh support solution - bingo!
    Got my Prius a month ago. Within a week my knees started to hurt. A lot. I may have hurt them playing softball (yes, we can do that in San Francisco in January), but they got worse whenever I drove.
    I'm 6'3". I finally realized that the seat was built for someone a lot shorter, whose legs would bend less and whose thighs would rest on the seat. I added a thigh-supporting pillow, much like Bob Allen described, and the problem went away.
    In my previous cars, this was not an issue. My Escape SUV has high enough seats that my legs are supported. I used to have a Lexus with a wonderful tilting front seat that provided great thigh support. (Which shows what Toyota can do when they try.) But the Prius seat just doesn't cut it. It's a good thing pillows are cheap.
  19. DanMan32
    3,799
    26
    Tampa Bay, FL
    The only control lost is acceleration. Still have brake and steering. I am not turning the car off, or into ig-on by holding the power button down for 5 seconds, just putting it in neutral for a short time. No worse than B mode or cruise control. I believe Manual transmission drivers do that often.
  20. KTPhil
    KTPhil Active Member
    1,379
    Back to my multiple post about using B in slow and go driving on freeways. The constant movement between brakes and gas is very tiring on my right leg (ankle and calf specifically). B mode slows me down fast enough during the 0-15-0-15mph cycling, saving me leg cramps. I also use cruise a lot on the highway. It lets me stretch my legs (there is a LOT of room for the left leg up and past the dead pedal., and folding my right knee lets me stretch my right ankle so it tires less when I DO have to brake and accel in D.
    This problem is a lot less than what I had in my Buick Regal, which cushy as it was, was one of the most uncomfortable cars I have ever driven.
