Do you find yourself?
Discussion in 'Gen 2 Prius Main Forum' started by Jiipa, Mar 8, 2008.
  1. Jiipa
    Jiipa MGySgt USMC (Ret)
    314
    Oahu, Hawaii
    We have two cars, a 94 Camry in addition to our 08 Spectra Blue Prii. When I have to go on a short trip, less than a mile or two, I find myself deciding to take the Camry even though it has six cylinders and burns more gas only because I know these short trips will bring down the average mpg's displayed on the MFD.
    Does anyone else do this? Or is this a newbie thing that I will get over?
  2. John CCP
    John CCP New Member
    59
    Old Orchard Beach, Maine
    We also have two cars: a 2004 Lexus GS430 (23 mpg) and a 2006 Prius (48 mpg). We almost always take the Prius, because of the good gas mileage. At about 40mph, if you don't hot-rod your Prius, it gets excellent mileage.
    At 70 mph, I only get about 45 or so.
  3. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    I have thought about this on occasion but end up taking the Prius. It definitely shows the need for ALL cars to have FE instrumentation.
  4. SureValla
    SureValla Member
    590
    Shelton, CT
    well on short trips the prius only gets like 25 mpg right? so equal to that of the camry so it doesnt matter what car you take... maybe im wrong?
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It's not a newbie thing, it's an example of the sort of illogical thinking to which we humans are prone. Drive the Prius.
    Tom
  6. diamondlarry
    559
    Elkhart, IN
    Even if the Prius and the Camry got identical mpg on a particular trip, the Prius will do it more cleanly.
  7. Sarge
    Sarge Senior Member
    1,301
    758
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I would disagree with this statement, since you would be assuming the Camry gets rated mileage even when running cold, which is very likely not the case. The Prius just makes it easier to be aware due to the instant fuel economy instrumentation, a feature not found in most cars.
  8. SureValla
    SureValla Member
    590
    Shelton, CT
    Yes I am, the only reason that the prius gets bad milage while cold is because the car cant go into EV mode and thus operates like any other gasoline car
  9. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    Bet the Camry gets 10 mpg for the first few miles.
  10. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    Drive the Prius.
    The Earth will thank you.
    And cut down on the short trips too.:welcome:
  11. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    I had to chuckle at the thread title. I admit, I occasionally have trouble finding myself. :p
    Seriously, I would use my ScanGauge (which I still keep on hand even after adding CAN-View to the Prius) to help compare the fuel economy the the two vehicles. I'd be pretty sure the Prius does better, but I'd like to verify it. Doesn't help the OP if he/she doesn't have a SG, though it would be a handy device to have for many reasons besides this.
    Now, on the subject of which is cleaner: Would the Prius really be cleaner on such a short trip if the ICE never has the opportunity to shut off? Is there something about the Prius' emissions system that makes it inherently cleaner than that of a vehicle with a similar ICE? I'm sure this has been addressed, but I don't recall the answer.
    Finally, I agree with Patrick: Reduce the short trips when possible. No question they're MPG killers in any car. Figure ways to combine them when you can.
  12. hill
    8,153
    A mile trip? Not raining / freezing cold? Night?
    I love to jump on my P-38 recumbent, as smug as it sounds, and as dorky as I look.
    happy daylight savings time (except you folks in AZ etc)
  13. The Root
    The Root Desert Dweller
    42
    Arizona
    Wow. Recumbent or not, 26 mph takes some serious quads.
  14. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    Yes the ICE will shut off even for short trips, at least when you're stopped at lights and such. It happens for me every day early in my commute, unless it's really cold out.
    But yeah, if I'm only going a mile or two I will either walk or combine the trip with other errands.
