Do You "Floor" Your Accelerator Pedal Frequently?
Discussion in 'Gen 3 Prius Main Forum' started by Stangar, Aug 20, 2020.
  1. Stangar
    Stangar Active Member
    174
    174
    Palmdale, CA
    Hi All,
    I have only "floored" my accelerator pedal a couple of times on my Gen 3 in 236,000 miles. I just never need to so I don't.
    So, my question is: "Do you floor your accelerator pedal often on your Gen 3? Thanks!
    51,155
    never, but i did have to do an italian tune up when the engine wouldn't shut off
  3. fuzzy1
    10,335
    Depends on what you mean by "often". I do so you much more often than you, but still only a handful of times per year when wanting to pass quickly and cleanly.
  4. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Once in a while, when I’m doing the speed limit and know the timing of the intersections’ yellow light and ICE is above 152F.
    Sone fella floored his accelerator and got the check engine light for blown inverter and the recalled covered it!
  5. ForestBeekeeper
    ForestBeekeeper Active Member
    766
    302
    Maine
    I do it sometimes.
    1- In our nearest city there is an interstate on-ramp where they placed a stop sign right at the very end of the merging lane. From that stop sign you have less than one car length to be merged and at the flow of traffic.
    2- Sometimes in winter when there are levies of slush piled up between lanes and at intersections. I have found that when I need to push through one of those piles of slush, if I floor it before I hit the slush, I stand a better chance to pushing through the slush.
    I shift to the PWR mode, in these situations. It gives me much better response from the vehicle.
  6. Stangar
    174
    174
    Palmdale, CA
    As the OP, I believe I was expecting some "lead foots" to say that they had it on the floor from every stop sign or traffic light (until they were near or over the speed limit). Maybe Prius drivers are fairly laid back.
  7. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    Very rarely do I go press the throttle to the floor.
    FWIW I think running an engine at maximum RPM every once in a while can be a good thing for overall care and maintenace...eg the Itailian Tuneup.
    ("Blow out" carbon from the muffler, faster movement of valve train, max oil pressure, hotter spark and combusion, and more. Maximizing all the engine components to keep them ready & tested) (Plus activating your ABS brakes is also a good thing to do every so often)
    Have fun :)
    douglasjre and Aaron Vitolins like this.
  8. Majafamily
    Majafamily Member
    66
    Elk Grove, CA
    Mostly just on shorter offramps and other situations where I don't want to be the slow one merging into fast traffic. Really wish people would merge with the flow of traffic. Not coming in at 1000 mph or 5mph.
    I'd rather ride my bicycle or drive my sienna if I want to go fast! The sienna is actually fairly quick at accelerating (let's not mention turning, Prius is way better at this). I recently sold my sports car since it has been dusty for several years since we've had kids.
  9. bettergolf
    bettergolf Active Member
    478
    361
    Sanford NC
    I think that would be an "onramp".....offramp you might need to be braking. I agree people need to learn to merge with the flow of traffic, not just turn on their turn signal expect everyone to move over and let them in.
    As to the question, I do not recall ever flooring mine.
    kenoarto likes this.
  10. Solar Blue
    Solar Blue Member
    58
    28
    Columbia River Gorge
    I don't recall ever flooring it.
    Maybe I should once in a while???
    douglasjre and kenoarto like this.
  11. orenji
    orenji Senior Member
    5,886
    3,487
    Always stay below 3,000 RPM. This motor has a red line of 5,000 RPM. Excessive oil usage maybe from driving hard.
  12. fuzzy1
    10,335
    On too many of the hill climbs I travel, that would require putting on the emergency flashers and staying in the slow line of heavy trucks in the far right hill climbing lane.
    And watching numerous lightly loaded trucks zoom by to the left.
    And it would be a traffic hazard on other routes where there are not enough heavy slow trucks to provide protective cover.
  13. orenji
    5,886
    3,487
    Benefit of living in a flat area I guess.
  14. MelonPrius
    MelonPrius Senior Member
    839
    514
    Las Vegas
    I live near on-ramps to highways with very short but steep declines. If I don't have a car right in front of me and depending on the length of the decline, I'll come close to flooring the car on the steep downhill portion of the on-ramp. And then I'll ease up when I reach 65 mph.
  15. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    The only time I floor it is when I'm trying to make the yellow light and don't want to slam on my brakes to stop before the intersection. The Prius is actually very good in this kind of situation despite being a "slow car". It gets from 45 mpg to 60 mph pretty quickly in order to beat the red light. The instant electric torque really helps and there's no gear hunting like an automatic transmission. A normal car with 200 horsepower would not be any faster from 45 to 60 mph than a Prius because when you floor it, it will try to accelerate in the highest gear, have slow acceleration, then downshift to the correct gear and have maximum acceleration. That wasted time from this will make it no faster and perhaps even slower than a Prius from 45 to 60 mph. Of course in a normal car you can be in manual mode in a lower gear at a higher rpm in the power band and accelerate from 45 to 60 mph much faster than a Prius. In reality almost no one drive in manual mode in lower gears to constantly stay in the power band.
    That would kill your fuel economy and shorten the life of your engine.
    Aaron Vitolins likes this.
  16. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Mine regularly sees large loads/power settings but very rarely does the throttle pedal get pinned to the floor.
  17. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Ive always floored my accelerator in all 4 of my Prii over the years. I do a lot of highway driving, so lots of on ramps, or moving around big trucks ect.
    It isn’t good to always be flooring it, but it is good every once and a while! My Ford C-Max is actually pretty dang quick, doing 0-60 in under 8 seconds. I definitely do floor it pretty often just for fun. I never floored my Prius for fun :)
  18. abdullah arslan
    186
    78
    This was in my mind in terms of MPG and the health of the car. I mostly accelerate asap to my desired speed and then release the pedal a bit off to keep the speed or switch to cruise mode. Is this better than accelerating gently?
  19. fuzzy1
    10,335
    The whole concept of flooring it to beat a yellow light baffles me, from any perspective other than the impatience of having to wait a cycle. Are your yellow lights really that ridiculously short, violating Federal Highway Administration guidelines? 45 to 60 mph? o_O
    Last week I witnessed a near collision when the car in the adjacent lane floored it for the yellow light, while I stopped. Across the intersection, he had to slam on the brakes even harder to avoid rear ending the car in front of him.
    #19 fuzzy1, Aug 24, 2020
    bettergolf and Ed Beaty like this.
  20. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    Please let me ask, what's the average RPM when you guys during normal acceleration from 0-40. I do stop and go in Los Angeles street traffic and I experienced high acceleration to reach 40mph will reduce MPG. That's why I can get higher MPG on highway than local drive.
