do you get better mpg's if you over inflate the tires?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Mar 25, 2012.
  1. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    I heard some people over inflate their tires for better gas mileage.
    Any proof?
    Is this true or just B.S.?
    51,974
    it seems to be hit or miss. i have tried it without success, but others swear by it. i don't think there have been any controlled experiments. i keep mine a few over so i don't have to check them too often.
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The only good experiments that I have seen were based on rolling distance in a coast down test. The higher the pressure the further the tire rolled before it came to a stop. The further a tire will roll with the same energy input the better mpg will be in most circumstances. Some road surface types could alter this.
    Mythbusters gave these results from their test:
    Control, 35psi (manufacturer recomendation)
    tyres at 10psi = 3.7% increase in consumption
    tyres at 30psi = 1.2% increase in consumption
    tyres at 40psi = 6.2% decrease in consumption
    tyres at 60psi = 7.6% decrease in consumption
    MythBusters: Tire Pressure Test : Video : Discovery Channel
    Here is the test done at Ecomodder.com
    Experiment: coast down distances (rolling resistance) @ various tire pressures - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
    PSI/Distance in feet
    20 / 479.3
    25 / 524.8
    30 / 621.0
    35 / 621.0
    40 / 639.6
    45 / 687.5
    50 / 702.0
    55 / 699.3
    60 / 702.0
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Over inflating your tyres does give an increase in mpg's BUT can cause other issues depending on your jurisdiction. It can cause poor handling, increased braking in the wet, poor cornering etc, which could invalidate your insurance if it was found this caused an accident. That then opens you up to all sorts of issues. If you know the risks, then on your head be it, otherwise just keep the car psi's at the correct level and no more but certainly no less.
    I personally keep mine on the correct psi or just 1 psi over and get some good mpg's.
  5. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Never "over inflate" tires (defined as more psi cold than the max rating of your tires). The psi suggested by Toyota will not give the best performance as different tire/brand models as each will do best at different pressures. The 35/33 setting that Toyota suggests is optimized for a comfortable ride not MPG, handling, or traction.
    I buy tires that have a max rating of 51 psi (Nokian WRg2) and find that 42/40 seems to be a good compromise for my use. Yes, that does result in improved MPG and handling with no noticeable effect on traction.
    JeffD
  6. ursle
    ursle Gas miser
    1,049
    192
    NH
    It would be silly to over inflate your tires, as a matter of fact I hear you get much better traction by running them at 10-12psi, but that it's even safer to fill them with calcium chloride, never go flat, ride over anything, etc.
    Personally I inflate to 40 all around with nitrogen, the sidewall marking for highest pressure is 1/2 the bursting pressure...
  7. hobba
    hobba New Member
    85
    Estero, FL
    I've tried it as well and for a long period of time. Never found that the MPG's increased for me. Blew thru a set of Yokohama A530's in 23,000 miles. Just replaced them two weeks ago. I'm going to run normal pressure from now on. That was my experience at least.
  8. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    What was the treadwear pattern? Even, all the way across; outer edges worn; center tread worn?
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Font wars. L O L
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    And now for a serious reply. Yes I think I get slightly better MPG and handling at 42/40 psi.
    Actually I was quite surprised when I recently bought new tires to find that the tire shop had already inflated the new tires to 42 psi and recommended that for best handling and wear.
  11. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I got my Prius with Michelin LRR tires, which were initially inflated to only ~32 psi. I increased to ~44 psi, the side wall rating, after reading reports here on PC. I noticed a few mpg's improvement on level, high speed sections. On the slower, very hilly areas, not much difference.
  12. hobba
    hobba New Member
    85
    Estero, FL
    Tread wear pattern was even across the tires. Tread wear indicators were displayed and the sidewalls showed evidence of early cracking. The tires were rated for 60K miles, so I got a proration from the dealer. I was very religious in monitoring the tire pressures and keeping them inflated as I have my own air pressure tank. But it just didn't work for me at least.
  13. MJFrog
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    Bummer... Even tread wear indicates they were run within pressure tolerances...neither too low, nor too high PSI. Tough that they didn't last as long as they should have.
  14. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Then don't blame the higher pressure for the short life then. Running at a lower pressure would probably have resulted in even lower tread life (as you would probably have had more wear near the edges).
