Do you park then turn off car or turn off without park
Discussion in 'Gen 4 Prius Main Forum' started by Will_Prius16, Sep 3, 2016.
  1. Will_Prius16
    Will_Prius16 Member
    127
    64
    Now in West Covina, CA
    It is much more convenient for me to hit the "start" button to power off the car when the car is still in drive mode as I leave. I don't hit the park button first before hitting the "start" button.
    Just wondering if there is any harm in doing this and what do you guys do?
  2. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    I just hit power off as well. Third Pirus, same routine. Never had any problems.
    alanclarkeau, pakitt and Will_Prius16 like this.
  3. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    There isn't a Park gear per se rather there's a parking pawl that locks the drivetrain and prevents roll. Using Power or P results in either button activating the pawl.
    What's more important is using the parking brake on an incline to prevent the car from rolling/rocking until the pawl engages. That can over time damage the pawl.
  4. JC91006
    16,470
    8,383
    I normally would use just the power button as well. But I find it doesn't shut off unless you're completely stopped for about 1 second. The park feature will make sure you car is parked and not moving.
    When I use just the button to shut down, I tend to have to press it twice because there seems to be a slight 1 second delay for the car to shut down after you stop. So if you have a press a button twice, you should just use the park button and then shut down.
    jlimgarfield, RCO and KimPrius3 like this.
  5. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    I switch off and that's it. If it were a problem it would complain.
    Done this for 7 years with gen3 and I will continue to do so on my gen4.
    RCO and alanclarkeau like this.
  6. bisco
    48,969
    i hit park, then power. but i must say, there's something to be said for getting in the habit of hitting power, then certain persons wouldn't tend to leave the car on.:whistle:
    vitiligo, RCO, ATHiker and 1 other person like this.
  7. Mendel Leisk
    38,239
    I regard the Park button as the "extra" option, for cases when I might want to leave the car running, but not in gear. Which is basically never, lol.
    And couple that with rolling the front tire into firm/stable contact with the curb (where present), per the driver's manual instruction. Especially on STEEP roads.
  8. fotomoto
    5,597
    3,771
    So. Texas
    A potential downside to habitually using the Power button is when driving other modern non-hybrid cars that now have push button start. Powering off first will leave the vehicle in gear many of which typically can't shift their electronic transmissions to P without power. That can cause a potentially dangerous situation if the vehicle begins to roll after or as the driver is getting out.
    Our push-top-start Subaru does emit a tone in this case but if the radio volume is loud, inattentive driver, etc.......
  9. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    Full Stop...Then PARK...Then POWER BUTTON To OFF.
    Colin Jones, ruby and RCO like this.
  10. Mendel Leisk
    38,239
    Nothing beats the old fool-proof systems. Typically you can't get the key out of the ignition without putting it in park. Physical impediments are great for that reason.
    Like the ill-fated Apollo 13 lunar mission: on the way back, two of the three astronauts were in the lunar lander, getting things squared away before they were going to jettison it. The third astronaut, the pilot, at the controls in the main vehicle, had taped a piece of paper over a switch, with the word "NO".
    When they were all back in the main vehicle, one asked the pilot about the note, and he explained that the switch was the one to jettison the lunar lander...
    RCO, KimPrius3 and bisco like this.
  11. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I was doing that for awhile, but I noticed a "rocking" and sometimes a jerking when I powered off the car, and didn't use the "P" button first. (especially on a slight incline/decline.)
    I figured that rocking is not good. So I went back to the 3 P's:
    1. Parking brake
    2. Park button
    3. Power button
    Old School guy.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Me too (y)
    RCO likes this.
  13. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    In my carport, I need to place it fairly accurately, and have 2 paving bricks which the front wheels will touch if I've gone forward too far. If I feel that I've touched them, I put it in neutral momentarily as it rolls back from any pressure against the bricks, but then I just POWER OFF. Normally, in the street etc I POWER OFF after I've put the park brake on.
    RCO likes this.
  14. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    I thought about doing this since it's such a complicated procedure to first press the Park button and takes so very much extra time to first press the Park button in addition to the complex and demanding procedure but then decided I could master the complexities so it's press Park press Power and done.
    RCO likes this.
  15. Mendel Leisk
    38,239
    Buttons can wear out, I'll stick with just hitting Power Button, have to do it anyway, and less work.
    RCO, alanclarkeau and kithmo like this.
  16. Coast Cruiser
    2,267
    2,571
    I tried it again this morning, on flat ground. I get a little "jerk" when pressing the power off button. I don't like that.
    The "White Knight" is telling me to go by the book:
    Parking Brake
    Park Button
    Power Off Button
    No jerk.
    There's the RIGHT way, the WRONG way, the NAVY way, and the Owner's Manual Way. :LOL:
    RCO, ruby and krmcg like this.
  17. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Tell the little jerk to stop pressing your power button and kick him out of the car :LOL:
    It shouldn't jerk if you have your foot on the brake pedal when you switch off.
    Prius Maximus, RCO, Merkey and 2 others like this.
  18. Mendel Leisk
    38,239
    I keep right foot on the regular brake, power off, then parking brake on with left foot.
    krmcg likes this.
  19. Coast Cruiser
    2,267
    2,571
    Thanks. I'm pretty positive I have my foot on the brake. Especially if I'm on a slight incline/decline. I'll experiment more, later.
    Do you guys ever use/deploy/press the parking foot brake? Obviously on a hill, it would be wise, correct?
    RCO likes this.
  20. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    That's the only time I use mine, on a hill, although if I haven't parked on a hill for some time I will occasionally operate it to stop it seizing up.
    RCO likes this.
