Do you save gas on electricity only?
Discussion in 'Prime Main Forum (2017-2022)' started by manoosie, Jan 28, 2018.
  1. manoosie
    manoosie Junior Member
    23
    Assume the following:
    Hybrid MPG: 54
    Electric MPG: 25
    Battery size: 8.8-kWh
    Cost per kWh: 12.5 cents (PG&E in Nor Cal; cheapest rate)
    Gallon of gas: $3.00
    Hybrid Mode:
    Cost to travel 54 miles: $3.00
    Electric Mode:
    Cost to fill up for 25 miles: 12.5 x 8.8 = $1.10
    Cost to travel 54 miles: 1.1 x 2 +..08 = $2.28
    I think the math is roughly right. So you save money, but not that much. Roughly 25%.
  2. ct89
    ct89 Active Member
    323
    266
    New England
    Even though the battery is 8.8KWh, it does not drain 100% in the 25 miles you go with each charge.
    A number of us have meters that monitor the energy required to recharge the battery and never see it hit anywhere close to 8.8KWh.
    My typical full charge is just above 6KWh. Others have reported up to about 6.3KWh...
    Using 6.3KWh, per charge, your cost to travel 54 miles is 54/25*6.3*.125 = $1.70 or about 57% of using gas.
    And, it's more fun.
    priuscatprimeguy and bwilson4web like this.
  3. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    That's a problem, you only "fill" the Prime's battery up to about 6.6 KWh. So the math comes out:
    Electric Mode:
    Cost to fill up for 25 miles: 12.5 x 6.6 = $0.825
    Cost for 1 mile = .033
    Cost to travel 54 miles: (.825 x 2) +.033 = $1.683
    So a little over half the cost. at 12.5 cents KWh.
  4. bwilson4web
    16,369
    I'm seeing 6.4kWh to fully recharge the battery closer to standard day temperatures. At temperatures under 50F (10C) there is some rolloff in EV performance but some of that is the lower tire pressure, increased rolling resistance, and denser air, higher aerodynamic drag.
    My metrics are close to the EPA numbers:
    2017 Toyota Prius Prime
    • 25 kWh/100mi - EV for 25 miles (25 kWh/(25mi/100mi)) = 6.25kWh
    • 1.9 gal/100mi - gas
    So using Huntsville Alabama rates:
    • $0.10/kWh
    • $2.30/gal regular
    The cost for 100 miles:
    • $2.50 EV = $0.10/kWh * 25kWh
    • $4.37 gas = $2.30/gal * 1.9gal
    benagi likes this.
  5. huskers
    huskers Senior Member
    2,546
    2,488
    Nebraska
    Is this going to be on the test?
  6. bisco
    52,395
    regarding the the thread title, i have saved 280 gallons of gas, over almost 6 years, and 57,000 miles.
    Prodigyplace likes this.
  7. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    yup and the grading will be on a curve:D
    Dudley1030 and walterm like this.
  8. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    Not to mention in my area there are a number (most in fact) of public chargers that are free of charge. That helps the math too!
    priuscatprimeguy likes this.
  9. priuscatprimeguy
    2,730
    2,640
    so..........no charge? how do the electrons get into the car?:confused:
  10. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    The beauty of dual-fuel: use what's best for your individual needs.
    Bob Comer and bwilson4web like this.
  11. SR-71
    SR-71 Member
    98
    108
    NC
    The best I can figure, I'm paying approximately 2.2 cents per EV mile, vs approximately 4 cents per mile on gas.
    bwilson4web likes this.
  12. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    Yes, but you're driving on infrastructure paid for mostly by the taxes other drivers pay on the purchase of gasoline and diesel fuel.
    Right now, with EVs making up such a small fraction of the total number of vehicles in use, this implicit subsidy is not a big problem and also promotes a social and environmental good. However, over the long term, just like the various tax rebates and incentives, this situation cannot last.
    It will be interesting to see how public policy evolves: tax per mile driven, per kwh consumed, or some other measure. Only time and politics will tell.
  13. Jawsch
    Jawsch Member
    34
    57
    Lexington, KY
    Thankfully, here in KY, electricity rates are ~$0.063650 (off-peak hours)
    Super cheap. I have an excel file that you can input local gas cost, and cost per kWh
    It tells me that it costs me $0.42 to travel the ~28 miles on EV only where as with gas, it would cost me $1.36 to travel that same distance.
  14. Prodigyplace
    12,681
    11,831
    Central Virginia
    The answer to the thread title is yes, you save gas on electricity only.
    Whether or not you save money by using the electricity is a different question, off-topic to the thread. This answer varies widely depending on weather conditions and electric rates.
  15. muleman
    muleman Junior Member
    56
    49
    rochester ny
    I am lucky i work 24 miles one way to work and I can plug it in here at no cost to me. So far 1078 miles on my car avg. MPG 191.8 and still have over a 1/2 tank of gas. Its been a cold month and a couple times the car would not go into EV mode (-27f)
  16. muleman
    56
    49
    rochester ny
    PS that is the highest driving score I have got so far.
    walterm and Prodigyplace like this.
  17. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    I do hope this is an open book test!
    And however we figure it, I am killing the MPG I was getting on my commute with my 4WD Tundra---12 MPG!
  18. geguia
    geguia Active Member
    210
    108
    los angeles
    F5D6891E-22C0-461E-956E-7072D4F4F35D.jpeg I have a free charger at work and my commute is 5 miles one way.
    This was a huge turn around when I had 100 mile a day round trip when I 1st got the Prius prime
    #18 geguia, Jan 30, 2018
  19. Oniki
    Oniki Active Member
    652
    499
    Colorado
    I installed PV (Solar) for my home and *EVs
    EV miles are about 0.5 cents a mile
    EV is nice
    EV+PV is awwwwesome
    #19 Oniki, Jan 30, 2018
